| Front Discs Just about to replace the front discs on my JTD after only 25,000 (remap -oops!) and have read somewhere about a tool to wind back the pistons.My question is do i really need this tool or can i wind back with a screwdriver like i used to on my old citroen?And if i do need it, can someone tell me where i can buy it from?Cheers
| Pick a window,your leavin | Re: Front Discs Not sure about the front pistons on a JTD, but on my 1.2 it was only the rears I needed the tool for (and yes, I mean NEED it!). All I needed on the front was a G-Clamp to push the piston back in. If you've had a remap, have you considered uprating the discs and pads? maybe EBC Turbo groove discs with green stuff pads?
| | #3 | ||
| It's about GO! not SHOW! | Re: Front Discs As ChrisMClark says it’s a doddle to retract the fronts on the JTD although in my case I used a proper retractor tool. TBH, I think that's the least of you problems if you're thinking of changing the discs. Good luck
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #4 | ||
| Pick a window,your leavin | Re: Front Discs Are Stilo discs not secured on by a single screw like other cars?
| | #5 | ||
| The modfather | No their not they are fixed in place by two bolts which double up as wheel locator's ... and the caliper piston on the front brakes can be pushed in by a G clamp ..and always watch the level in the master cylinder as the fluid rises as you retract the piston I use a hypodermic syringe to suck out excess fluid
__________________ International man of mystery ![]() Wit ..sarcasm you get it all from me.. | ||
| | #6 | ||
| T.E.D. | Re: Front Discs
__________________ Total Engineering Developments | ||
| | #7 | ||
| Re: Front Discs The actual changing pads and disks shouldn't be a problem. Like others previous, I would question why they are needed after such a low mileage? Either heavy brake footed, or they are not up to the job and you should maybe consider fitting uprated ones If you're changing them anyway it would be good advice I think.
__________________ Ciao - 1.6 Fiat Stilo, Konnichiwa - 2004 Mazda 6 2.0 D(137) TS. 2004 1.8 Vauxhall Vectra - 5 Door 1974 3.5 V8 Triumph Stag - 2 Door | |||
| | #9 | ||
| Re: Front Discs No problem doing the job,years of expertise in mechanics from buying crap cars.Wouldnt say i was that heavy on the pedal, but the extra power from the remap does make a huge difference in performance..Probably the cheap materials used by Fiat for the discs.Pad wear does seem about right for the mileage. Upgrading was a consideration but i am hoping to swap the car for the new model Bravo in the summer.Got a quote for discs and pads from Sutton Auto Factors £52.00.Not sure who makes them but they advertise Mintex gear on their website, anyone know what the quality of Mintex stuff is like? Thanks for previous replies
| | #10 | ||
| Re: Front Discs Sutton A F ! I live just around the corner.. Mintex are better than Fiat OE (which isn't difficult to be honest) I fitted them all round and they are pretty good. Need to use copper slip to eliminate squeal
| | #11 | ||
| | #12 | ||
| popping out | Re: Front Discs
__________________ MR2 owner!!!!!!! | ||
| | #14 | ||
| | #15 | ||
| Re: Front Discs Phil, Make sure you get the money first. Those Kirkby lads have a reputation round here. Hope you got a sense of humour Dan.
| | ibopasa | Marea | 5 | 12-03-2007 17:35 |
| | Dabois85 | Cinquecento / Seicento | 12 | 21-12-2006 00:38 |
| | Ems | Punto | 3 | 02-08-2005 07:38 |
| Front Brake Discs | mrhatch | Ulysse | 18 | 31-08-2004 13:03 |
| | Craig-m | Punto | 4 | 12-07-2004 14:33 |
