The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 04-02-2007   #1
Trader Rating: (0)
A New Problem
GOT IN AND STARTED THE CAR BEFORE,AND HAD ANOTHER WARING POP UP ON THE DISPLAY. DAYLIGHT SENSOR FAILER/ RAINSENSOR FAILER . STOPED AND STARTED THE CAR AND IT WENT , ANYONE ELSE HAD THIS HAPPEN?
sandy25 is offline
Old 04-02-2007   #2
Whaddya mean too old?
Deckchair5's Avatar
Trader Rating: (0)
Deckchair5 has donated! United Kingdom
Re: A New Problem
It's freezing temperatures and batteries are low. If it doesn't do it on the second start up then don't worry about it. It's just saying "Hey Boss, didn't think much of the voltage then"
You see that button that says "Caps Lock?"
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline
Old 04-02-2007   #3
Trader Rating: (0)
Re: A New Problem
that better, will go and get bat cheaked out.how much is a new one ???????????
sandy25 is offline
Old 04-02-2007   #4
Pick a window,your leavin
Trader Rating: (0)
ChrisMClark has donated!
Re: A New Problem
You won't necesarily need a new battery, the cold just saps power quicker than warmer temperatures.
If you do need a new battery, they start at 39.99 from a fiat garage (that's for a 1.2) although I think that might be if you're a member of 'The Stilo Club'.
ChrisMClark is offline
Old 05-02-2007   #5
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
Re: A New Problem
If you do treat your Stilo to a new battery then whatever you do NEVER, NEVER install a cheap battery - always fit the best you can get.
Personally I wouldn't bother though. Most warning messages on the Stilo can be prefaced with the word "I think there might be a problem with....". As Deckchair has said if the message isn’t repeated then just ignore it
It also helps on many Stilos if you give the car a chance to check all systems before you engage the starter (perhaps you do anyway)
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is offline
Old 05-02-2007   #6
anthonytutton's Avatar
Trader Rating: (0)
Re: A New Problem
I have had this problem several times. But it only happens when the windows are frozen over, once thawed, normal automatic operation is reaumed...
The next time this happens i will defrost just the area of glass where the sensor is, and see if it happens again...
anthonytutton is offline
Old 05-02-2007   #7
2.4 abarth in front
lee gagg's Avatar
Trader Rating: (0)
lee gagg has donated! United Kingdom
Re: A New Problem
I had this fault once when i first started the car when window frozen over Rain detector sensor fault contact main dealer,now all i do before starting car is clear the ice from the rain sensor in the top of the windscreen jobs a good un although the wipers stopping in middle of screen bugs me though happens in both modes.
The car in front is a stilo 2.4 abarth The car thats left you for dead was a stilo 2.4 abarth
lee gagg is offline
(T) Solution to Punto 75 mk1 Engine Problem Tziallas Punto 4 24-03-2008 18:35
(G) Punto 3 door seat problem Reaver23 Punto 4 04-09-2007 12:03
(T) Injector Problem! Help! Thanks fear Bravo / Brava 4 19-11-2006 20:11
(T) Windscreen wiper motor problem Thomas P Uno 10 23-08-2006 20:04
Mid-throttle injection problem in Lancia Y10 FatNote Panda (Classic) 26 30-07-2004 18:58
