| What oil? 1.6 02 dynamic Off to halfrauds tomorrow and need to know what oil i need, got filter already. I also need to know how much oil it holds so i can put enough back in once ive changed it. Cheers guys and gals K
| Pick a window,your leavin | Re: What oil? 1.6 02 dynamic What model is your Stilo? the sump capacity varies model to model. However I'd say go for a 4.5 or 5 litre bottle. Halfords are doing a special on Castrol GTX Magnatec at the minute. Buy 4.5l and get a 1l top up bottle, pouch, and gloves, wipes, card funnel etc free. GTX is what's going into mine tomorrow.
Last edited by ChrisMClark; 02-02-2007 at 21:36. Reason: Spelling mistakes :S | ||
| | #3 | ||
| Brain freeze | Re: What oil? 1.6 02 dynamic Make a decision as to whether your gonna go synthetic or mineral. Synthetic will last a little longer, but I wouldn't use it if you have any minor oil leaks as it tends to be a little thinner when cold. Semi-synthetic is always a safe bet. Have a look in your handbook to see what grade you should use. It will also tell you how much oil to use. Never over fill the damn thing.
__________________ Stilo JTD 115 3dr Dynamic 2002 with Skyroof, 16" Alloys, in Pitti Blue. No mods........yet | ||
| | #4 | ||
| Pick a window,your leavin | Re: What oil? 1.6 02 dynamic Spoke to a mechanic this morning, and he reackons synth oil is a bit of a gimic unless it's going in a performance engine. I stuck the GTX Mag 10w-40 in this morning.
| | #5 | ||
| It's about GO! not SHOW! | Re: What oil? 1.6 02 dynamic Fully synthetic is the way to go as long as your motor will take it. As Lobster has said if your engine’s worn or perhaps been abused then there's not much point using the more expensive oils (could even make leaks worse). On the other hand if your engines is in tip top condition then fully synthetic will keep it that way I certainly class my JTD as a performance engine
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #6 | ||
| Glutton for Punishment | Re: What oil? 1.6 02 dynamic Surely viscositiy will determine if it leaks, not if its mineral or synthetic? If I'm getting the oil done out of service I always use Castrol GTX Magnatec 10W-40 (which is semi synthetic), otherwise it gets Selenia from FIAT.
__________________ 07 Bravo TJet Sport, Maranello Red Factory Options: Dual Zone Climate, 18" Alloys Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion | ||
| | #7 | ||
| Pick a window,your leavin | Re: What oil? 1.6 02 dynamic rroope, the interesting thing is I spoke to my service centre about oil, and they don't use selenia, they use shell. You have to question wether it's worth the extra fiver when even a Fiat service centre doesn't use it!
| | #8 | |||
When I get my service done at FIAT I usually get 10-15% off so I just let them put Selenia in . Like I say, I wouldn't buy it myself if I was doing it.
__________________ 07 Bravo TJet Sport, Maranello Red Factory Options: Dual Zone Climate, 18" Alloys Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion | |||
| | #9 | ||
| Pick a window,your leavin | Re: What oil? 1.6 02 dynamic I did a full change yesterday and put 10w-40 GTX in, it's fine.
| | #10 | |||
It's this cleaning effect of the oil which can create leaks on older engines especially around existing seals. The other issue is that tolerances can only increase on an engine and never decrease. In other words there's little point in using the highest quality oil if the engines already taken on some wear.
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | |||
| | activematt | Stilo | 755 | 12-11-2007 15:17 |
