The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 01-02-2007   #16
DubWitStilo's Avatar
Trader Rating: (0)
Re: Dangerous Stilo
ye it just judders then if I push the pedal down further it disconnects, i get beep beep beep engine failure then it ticks over but not at a normal tick over it is a bit erratic, when i push the pedal down nothing happens, as soon as i turn the key back all is dandy for a little while.
It never happens on a motorway etc only when slowing when approaching a roundabout or a turn then i put the foot down (Normally in 2nd or 3rd gear) i get the judder then loose the accelerator completely. It is rather strange.
I know its prob something simple and if I go to the fiat dealer I will prob get charged about €200 but it might be my only option.
2002 Stilo Dynamic 1.6 16v
DubWitStilo is offline
Old 01-02-2007   #17
Whaddya mean too old?
Deckchair5's Avatar
Trader Rating: (0)
Deckchair5 has donated! United Kingdom
Re: Dangerous Stilo
Sure sounds like throttle body. If you've cleaned the inlet valve out and reset the ECU then the next thing is getting the ECU throttle body update done. I think that's around £30 or 50 euros
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline
Old 08-02-2007   #18
Trader Rating: (0)
Re: Dangerous Stilo
Ok, Went to Fiat dealer thismorning and got hooked up to the examiner then was told that the throttle body is knackered and it will cost €500 to replace.
It seems like an easy part to fit so I am going to fit one myself.
Are there any fiat parts online shops where I might get this a bit cheaper??
Or Even a second hand one?
Old 08-02-2007   #19
Deckchair5's Avatar
Trader Rating: (0)
Re: Dangerous Stilo
I believe you can sometimes get refurbished throttle bodies but don't know where.
But before you do....you haven't said whether you've found out whether the ecu throttle body update has been done. There have been a few people having new throttle bodies fitted but then finding it's not cured. The fact you turn the engine off and then it's ok again is fishy. Throttle bodies don't usually do that when they've had it. I'd double check the update's been done and see if I could get the throttle relearn procedure to work, what have you got to lose? 500 euros
Have a look at these
http://www.fiatforum.com/stilo-techn...eaned-but.html
http://www.fiatforum.com/stilo-techn...ing-out-2.html
99 Bravo 1.2SX
Old 08-02-2007   #20
Trader Rating: (0)
Re: Dangerous Stilo
They never said anything about a throttle body update. They deleted all the fault codes and told me to induce the problem over the weekend, and come back Monday morning so they can stick it back on the examiner. (didn't need the weekend as it happened on the way home from the garage).
They said they are pretty sure its the throttle body but want to make sure before I pay out that much money.
I have tried everything u suggested Deckchair. I hope its not the Accelerator pedal!!
Old 08-02-2007   #21
Deckchair5's Avatar
Trader Rating: (0)
Re: Dangerous Stilo
You've got to get on to them and make sure the ECU/ throttle body update has been done. It's exactly for your symptoms. They should know all about it but then again.......
I would have expected the relevant error codes if the accelerator potentiometers were amiss
99 Bravo 1.2SX
Old 09-02-2007   #22
Trader Rating: (0)
Re: Dangerous Stilo
Ok I'll mention it to em on monday.
I will keep you posted.. Thanks again. CC
Old 13-02-2007   #23
Trader Rating: (0)
Re: Dangerous Stilo
Went back to Fiat yesterday to see what fault codes came up and to my annoyance I have a new one
P0203: Injector Circut Malfunction - Cylinder 3
P0638: Something to do with Throttle????
P1687: The latest addition to the family of errors. "Metering Oil Pump Stepping Motor Cricut Malfunction.
I have no Idea what the first and 3rd mean.
I asked about the Update and they said it wasn't done, but for such a substantial problem it was unlikely to be cured by an update.
I think the stilo will be in the Autotrader as soon as I get rid of These Fault codes.
Old 13-02-2007   #24
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
Re: Dangerous Stilo
Time to find a new dealer
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is online now
Old 13-02-2007   #25
Trader Rating: (0)
Re: Dangerous Stilo
But how could it be fine for years and just need an update all if a sudden?? It doesn't make sense...
Old 13-02-2007   #26
Argonought's Avatar
Trader Rating: (0)
Re: Dangerous Stilo
I agree but many members have had this done and most seem to suggest it makes a big difference.
It's done with Examiner so if checking fault codes anyway then I don't know why they don't just do it
You should read Deckchair5's posts which cover this well.
Old 14-02-2007   #27
Deckchair5's Avatar
Trader Rating: (0)
Re: Dangerous Stilo
"But how could it be fine for years and just need an update all if a sudden?? It doesn't make sense..."
Yes I understand your thinking. The thing is that everything is fine and dandy whilst everything keeps within the set parameters planned. When things fall out of spec ( a sensor returning an out of range figure perhaps) then sometimes it just doesn't know what to do as it hasn't been planned or expected so the ECU does a sulk. This is where turning the engine off and back on again can reset things and off it goes all happy again.
Updates can fix anomolies like this as well as provide better cold starts, acceleration, smoothness and emissions for an all round better drive even if you car was not bad to start with
Your current problems do seem throttle body related but that may be connectors or wiring to the thottle body too. Error P0638 is throttle body and P1637 is generic but I think that'll be the throttle body stepper motor i.e. the same animal. The electrical tracks in the stepper motor sometimes give poor contact similar to the wiper motor and then everything gets out of phase. Equally it could be wiring to the throttle body stepper motor (idle valve)
You can check out Stilo ECU updates here
http://www.f-autronica.it/aggecu.htm
You can translate with this http://translate.google.com/translate_t
Have a look for 02 / 2003
99 Bravo 1.2SX
Old 10-01-2008   #28
Glutton for Punishment
Rich's Avatar
Trader Rating: (1)
Rich has donated! United Kingdom
Re: Dangerous Stilo
Again, one dredging up from the past, but our Stilo is suffering exactly this problem with exactly the same error codes (P0203 & P0638). We've had a new throttle body put in but it's still causing problems.
Yellow Peril, did you ever get it sorted?
07 Bravo TJet Sport, Maranello Red
Factory Options: Dual Zone Climate, 18" Alloys
Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates
Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion
Rich is offline
Old 26-07-2008   #29
Trader Rating: (0)
Talking Re: Dangerous Stilo
Hi hopefully someone can help before I pay a visit to the fiat dealer.
Nearly every day for the past 5 months I have noticed a judder coming from my Stilo when I accelerate suddenly, more recently the accelerator has cut out completely, as in the engine is still idling but when I push the accelerator nothing happens, when I restart the car all is back to normal temporarily, this has happened regularly, sometimes when I need to accelerate quickly for instance, pulling out onto a roundabout etc.
I gather the Judder I feel before it cuts completely is the accelerator disconnecting for an instant, I spoke to a fiat dealer on the phone and he was saying the Accelerator is fly by wire so when u push the pedal a sensor sends a signal to the throttle.
If anyone has had this problem and has any advise for me I would appreciate your comments.
Also I was thinking about reseting the ECU, how do I go about doing this??
This is what mine was doing and the dealers couldnt pin point the problem, i then found a guide on cleaning on this forum,(click on the guides tab) followed it and now it runs BRILLIANTLY, no juddering when pulling off, no power loss etc..
Give it a try, it only takes 10 mins!
<iframe src="http://gamercard.xbox.com/CSI%20ICOD.card" scrolling="no" frameBorder="0" height="140" width="204"></iframe>
ICOD is offline
Old 26-07-2008   #30
Trader Rating: (0)
Re: Dangerous Stilo
RICH, did you replace with new or used?
If its used did you clean the INSIDE of the body, around the butterfly etc...?
ICOD is offline
(G) Thinking of getting rid of the Stilo! Shminkypinky Stilo 34 23-05-2008 13:02
(G) Thessaloniki Greece Stilo Meeting Pics john_stil Stilo 20 03-07-2007 22:16
(G) Thinking of buying a Stilo! OzMoSiS Stilo 99 22-04-2007 16:10
(G) I bought a Stilo Abarth :) alexGS Stilo 11 31-07-2006 09:38
(G) Stilo Abarth - My humble opinion Roberto Stilo 0 14-07-2002 22:06
