The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 29-01-2007   #1
Trader Rating: (0)
Pre-Heat Fault
In the last week my fault has started giving a pre-heat fault message.
It starts as normal but about 5 seconds later the fault message appears then disappears withing a minute.
Would I be right in assuming this is a faulty glow plug?
If it is, how difficult are they to replace? I have no way of knowing which is at fault so I was going to swap them one at a time until the fault msg stops.
Mike
Mike
Stilo Active 5 Door
JTD (115bhp)
XYFAS is offline
Old 29-01-2007   #2
topmark5's Avatar
Trader Rating: (0)
topmark5 has donated! United Kingdom
Re: Pre-Heat Fault
[quote=XYFAS;1000568]In the last week my fault has started giving a pre-heat fault message.
Hi I had the same fault - but took my JTD to an independant auto electricians so diagnostic kit was connected and fault was reported back to me
Turned out to be Number 2 Cyl heater plug open circuit, I bought new heater plug fitted just this one, you require long 10mm socket and 1/4 drive extension & ratchet (£7 + vat for heater plug from local motor factors) all faults now clear
The only hard bit is finding an auto electricians with the fiat diagnostic kit, I would not trust a dealer, especially after reading some of the accounts on this forum.
if you need any more info let me know
topmark5 is offline
Old 29-01-2007   #3
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
Re: Pre-Heat Fault
These are dead easy to diagnose (Examiner is a waste of time). Try this for starters. A few other useful threads can be found if you use SEARCH.
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is offline
Old 29-01-2007   #4
Grumpy Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
Re: Pre-Heat Fault
Rubbish....easy to test with multimeter! No need for auto electrician & dont believe everything you read.
T14086 is offline
(T) Engine Fault and others smify999 Stilo 12 13-10-2006 18:29
(G) Engine Fault on Stilo 16v 1.6 Aircon 2003 cazzo_man Stilo 3 25-09-2006 23:55
(T) ECU fault / coil braden Stilo 5 29-03-2005 13:14
