The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 26-01-2007   #1
Trader Rating: (0)
O/S Lower Suspension Arm
Hi Guys
Had the car MOT today and yes it failed on the above even through i had the N/S replaced at the same time as the mot, as i was advised on my last MOT that the N/S arm would need replacing.
It also showed a brakes imbalanced of 30% on the fronts, if the O/S lower suspension arm had excessive play would this cause the brake imbalanced due to the wheel moving?
Lee
leelee01 is offline
Old 26-01-2007   #2
Whaddya mean too old?
Deckchair5's Avatar
Trader Rating: (0)
Deckchair5 has donated! United Kingdom
Re: O/S Lower Suspension Arm
"It also showed a brakes imbalanced of 30% on the fronts, if the O/S lower suspension arm had excessive play would this cause the brake imbalanced due to the wheel moving?"
No not really, that's a very significant difference between the brake's efficiency from one side to the other and more likely due to factors like air in the system, seized caliper, contaminated pads etc
If the pads and discs look good then go for the easy one first and bleed the brakes, look for air particularly in the side that is showing the weakest braking power.
Does the car pull one way when you brake?
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline
Old 26-01-2007   #3
Trader Rating: (0)
Hi Decks
It stops in a straight line! its doesn't pull to either side, its was the o/s showing the imbalance according to the tester that done the test saying that my wheels are very very dirty car has been washed in a cpl of months so maybe thats the problem?
leelee01 is offline
Old 26-01-2007   #4
Deckchair5's Avatar
Trader Rating: (0)
Dirty car? I can't see how that can make a difference but 30% is a big difference, that's almost a whole pad not working properly. Like i said, do a system bleed and check for a seized caliper. Look for pad on one side much thicker than the rest through lack of use (Duh! I'm a thick pad). Usually the one you can't see so well, on the inboard side
99 Bravo 1.2SX
Old 02-02-2007   #5
Trader Rating: (0)
Hi Guys
Quick update, had the o/s lower arm replaced and that solved the imbalance problems of the front brakes its only reading 20% instead of 30%, quick question after i arrived home i found this bolt/nut in the alloy so i am guessing that this has come from the parts that have been removed to replace the arm, anybody have any ideas of where this has come from and could it cause me any probs having this removed ?
Lee
leelee01 is offline
Old 03-02-2007   #6
Deckchair5's Avatar
Trader Rating: (0)
Not sure what that is from the picture, maybe a wheel arch liner or engine under cover
20% imbalance on your front brakes is still pretty grim and very close to another MOT fail. I'd bleed the brakes for a quick and cheap possible solution. When you need them, that 20% means a lot more
99 Bravo 1.2SX
Old 04-02-2007   #7
Glutton for Punishment
Rich's Avatar
Trader Rating: (1)
Rich has donated! United Kingdom
Engine Under Tray bolt, I'm pretty certain it's one of the front ones.
07 Bravo TJet Sport, Maranello Red
Factory Options: Dual Zone Climate, 18" Alloys
Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates
Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion
Rich is offline
(T) rear suspension worn badly?? thefishdude Punto 8 15-09-2008 16:33
(T) lower suspension balljoint nightsmith Stilo 4 09-12-2006 23:42
(G) Help!!! Rear Lower Arm Problem??? coolme2k Punto 3 06-12-2006 02:55
(T) Punto rear suspension swing arm question nawtwrong Punto 5 22-06-2006 07:43
(G) Wiper Arm and Doorhandles klaus23 Punto 3 28-09-2004 11:09
