| 2.4 abarth in front | Wipers Going Silly Hi guys i gotta 2.4 abarth(52 plate)not had it long have seen this post before about wipers stopping in middle of screen and having mind of their own well mines doing this now has anyone had same problem and how did you cure it.Have noticed it goes away when wipers been on for a short while its only happens really when first put wipers on (cold).Cheers.
| Glutton for Punishment | Re: Wipers Going Silly Sounds like they are struggling. I think the mechanism was changed to have new grease, one that deals with cold temperatures better. Might need the motor mechanism stripping then regreasing. Or, I might be going in the wrong direction; does this happen in auto (rain sensing) mode or in continuous wipe?
__________________ 07 Bravo TJet Sport, Maranello Red Factory Options: Dual Zone Climate, 18" Alloys Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion | ||
| | #3 | ||
| 2.4 abarth in front | Re: Wipers Going Silly it generally occurs when ever i first put wipers on has done it in both modes.Think it a common problem suprised there aint a sticky on this subject.
| | #4 | ||
| Re: Wipers Going Silly Lee, After searching through the posts I came across your post regarding the Stilo Wipers. I have a friend who (I believe) has the same issue with the wipers. Like you mention in your post the wipers stop in the middle of the screen and then after a delay continue wiping again. Oddly it appears to be perfectly timed - I forget the exact timings but the wipers will run for say 8 seconds then stop midway on the screen for about 5 seconds. I am sure they also said that after a while it does go away but I will need to double check this. Did you manage to get you problem fixed, and if so what did you do/have done to get them working again? The dealer has so far suggested replacing the wiper moters but they will not guarantee that this will fix the problem and we are hoping to get some confidence that this will work before agreeing to having this work done. Many thanks, John
| | #5 | ||
| Whaddya mean too old? | Re: Wipers Going Silly Take the cover off the wiper motor and clean off the excess grease from the contact tracks. There's usually so much excess grease in there that the contact strips lose electrical connection and the wiper stops mid stroke Have a look here for pictures http://www.fiatforum.com/stilo/10918...-sticking.html
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 16-07-2007 at 14:57. | ||
| | #6 | ||
| Re: Wipers Going Silly I have seen something similar to this on a seat ibiza and an astra at work I'd say that its a relay about to go if its that perfectly timed. My Ibiza went once and it was mechanical and it was anything but perfectly timed. I also had a problem with wipers, I'll dig out the post for you now
__________________ | |||
| | #7 | ||
| | Javad | Stilo | 5 | 25-07-2006 12:49 |
| Windscreen Wipers | philmccann | Ducato | 2 | 13-05-2006 15:11 |
| | Mr Meltdown | Bravo / Brava | 0 | 14-01-2006 21:03 |
| | LanciaMad | Punto | 4 | 19-07-2005 20:23 |
| | MagicmanUK | Cinquecento / Seicento | 6 | 13-03-2005 11:43 |
