The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 19-01-2007   #1
Trader Rating: (0)
Question poorly stilo 1.6 dynamic 52 reg
beep beep beep the little yellow lights on again. this time its the injector, last time it was the ecu the time b4 that it was map sensor and yep u guessed a coil. the time b4 that it was the lamba sensor. ddddose this always happen with stilos ,were are the injectors
sandy25 is offline
Old 19-01-2007   #2
Grumpy Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
Re: poorly stilo 1.6 dynamic 52 reg
Hi
T14086 is offline
Old 19-01-2007   #3
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
PNL has donated! United Kingdom
Cool Re: poorly stilo 1.6 dynamic 52 reg
Originally Posted by T14086 View Post
Hi
Oi he wants to know where the injectors are
International man of mystery
Wit ..sarcasm you get it all from me..
PNL is offline
Old 19-01-2007   #4
Trader Rating: (0)
sandy25 is offline
Old 20-01-2007   #5
T14086's Avatar
Trader Rating: (0)
On the injector rail
T14086 is offline
Old 20-01-2007   #6
Athos's Avatar
Trader Rating: (0)
Mexico
I guess injectors are at the cilinders, one at each, right?
http://img407.imageshack.us/img407/9811/michaelgf3tz3hz3.jpg PERMAGRIM CLUB
Athos is offline
Old 23-01-2007   #7
Trader Rating: (0)
ecu problems stilo 16 52 reg
if i disconnect the battrie will it re set the ecu and how long does it need to be of for?
sandy25 is offline
Old 23-01-2007   #8
Glutton for Punishment
Rich's Avatar
Trader Rating: (1)
Rich has donated! United Kingdom
Re: ecu problems stilo 16 52 reg
Engine ECU? Airbag ECU? Body Computer?
07 Bravo TJet Sport, Maranello Red
Factory Options: Dual Zone Climate, 18" Alloys
Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates
Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion
Rich is offline
Old 23-01-2007   #9
Trader Rating: (0)
engine
sandy25 is offline
Old 23-01-2007   #10
Rich's Avatar
Trader Rating: (1)
Disconnecting the battery won't really help. If there's a persistent fault, it won't clear. If it's a one-time fault, I believe that starting the car a few times should clear it.
Why do you need to reset it? Maybe I can help
Rich is offline
Old 23-01-2007   #11
Trader Rating: (0)
be having big probles with it, had new ecu fitted start of dec,engine falt come on last week came back as number 1 injector, had new one fitted today still runs like a dog but with 11 engine falts logged on ecu.
sandy25 is offline
Old 23-01-2007   #12
Rich's Avatar
Trader Rating: (1)
Well I doubt ECU reset would cure that?!
Did FIAT fit it or did you get it from a breakers yard?
Rich is offline
Old 23-01-2007   #13
Trader Rating: (0)
fiat its going back on thursday
sandy25 is offline
Old 23-01-2007   #14
Rich's Avatar
Trader Rating: (1)
Ah well then you're sorted, kinda!
They'll need to Proxi-align it, but faults like that sound more like wiring faults than anything. One assumes they did fit a new Engine Node (ECU) as opposed to a Body Computer??
Rich is offline
Old 23-01-2007   #15
Trader Rating: (0)
was told ecu because when it first went in to garage in dec check came back as throttle something(cant remember the name of part) garage fitted a new throttle thing but could not get it going.so they sent it to fiat, after two days fiat said it was the ecu fitted every things been fine till last.wots the diffrence between an ecu and a body computer?
sandy25 is offline
(G) How many Stilos activematt Stilo 755 12-11-2007 15:17
