| Stilo Workshop Hi there, Latest problems with the Stilo 1.2 this week: - Radio has lost reception - anyone know how to fix this (in easy steps if possible ? I have seen threads on replacing the headunit but I have no idea how to approach this ...- Left light bulb has blown - it should be easy to fix but I know mechanics who could change a gearbox quicker !!! Forza Ferrari kimi01
| popping out | Re: Stilo Workshop there are a few different ways to change the headlight. drivers side - undo top bolt holding washer resivoir in place and push it back, which givces you enough access to the back of the headlight. passengers side- this gets a bit tricky because there are 3 ways of doing it. 1. easiest way if you have skinny arms is to remove battery cover, slide your arm through from the left side of the battery towards the back of the headlamp, remove clip, push back cover as far out of the way as you can. 2. remove battery cover, battery fusebox etc then you can either bend the battery box slightly to give you room or remove the box completely. 3. remove front bumper and the whole headlight unit. if you can't find anyone who can do it then FIAT will charge you around £20-£90
__________________ MR2 owner!!!!!!! | ||
| | DJ_Prone | Stilo | 8 | 13-02-2006 23:48 |
| | andrewsmith | Stilo | 8 | 17-01-2006 00:42 |
| | 1.8Stilo | Stilo | 59 | 23-12-2005 21:38 |
| | pc99 | Bravo / Brava | 1 | 11-12-2003 05:13 |
| | Roberto | Stilo | 0 | 14-07-2002 22:06 |
