| Preheat Fault Warning
| It's about GO! not SHOW! | Re: Preheat Fault Warning This should help (although the treads very confusing ):http://www.fiatforum.com/stilo-techn...ight=glow+plug
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #3 | ||
| Re: Preheat Fault Warning Hello everyone sorry about this but had the Glowplugs tested and been told they are fine, they said now it could be a memory fault the warning is still coming up every time I start the car.Could it be the memory and if so what do I do, or has anyone any other thoughts what it could be. By the way changed the front headlamp bulb hope it never goes again what a stupid design that is.
| | #4 | ||
| It's about GO! not SHOW! | Re: Preheat Fault Warning If you're sure the glow plugs really are OK then it might be heater relay (for the plugs)
| | #5 | ||
| Re: Preheat Fault Warning Hello where is this heater relay is it easy to fit and how do I test to see if it faulty thank you
| | #6 | ||
| It's about GO! not SHOW! | Re: Preheat Fault Warning It's on the bulkhead (middle top) and if you look carefully you'll notice all the heater plug wires lead back to it. Quite easy to remove, I think, but you're on your own as far as diagnosis is concerned (think it might be an Examiner job )
| ducato 1994 1.9td - oil warning light fault | bobian81 | Ducato | 0 | 24-10-2006 17:50 |
| | D-Stilo | Stilo | 27 | 23-10-2006 21:08 |
| | blackJTD | Stilo | 11 | 16-02-2005 22:41 |
| Warning lights when no fault? | hookenz | Tipo | 0 | 15-04-2004 06:05 |
