The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 27-12-2006   #1
Trader Rating: (0)
heater fan
Hi all
Can anyone tell me how to access the heater fan unit. I think mine has packed up.
cheers
ian
ian.smith7 is offline
Old 27-12-2006   #2
Grumpy Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
Re: heater fan
Its situated at right side of heater box just to left of clutch pedal,good luck as its a swine to get out/replace.
I would strongly suggest checking fuses/connections first.
T14086 is offline
Old 27-12-2006   #3
Trader Rating: (0)
Re: heater fan
Hi TI
Thanks for your reply
Here are the things Ive checked
1. 30A fuse in the battery box
2. Relay in the battery box
3 I have checked for a 12v supply at the switch (Grey/Black full speed wire)
& shorted it to earth (Black).
All with no success. I have a 12v Supply at the switch (Grey/Black wire) which is coming through the motor. When I earth it Either to the Black wire or direct to the body the fan does not run. I have linked out the relay at the batter with a wire and when I remove the wire the 12v supply at the switch is lost. So I think it is either the motor or a high resistance connection at the motor.
ian
Old 27-12-2006   #4
T14086's Avatar
Trader Rating: (0)
Re: heater fan
Have you checked voltage at the motor connection itself?
(need to dig out diagram,i'll do it later...supposed to be decorating!!)
T14086 is offline
Old 27-12-2006   #5
T14086's Avatar
Trader Rating: (0)
Re: heater fan
Hang on i'm sure Decks already posted up heater diagrams a while back?
Here it is........
http://www.fiatforum.com/stilo-techn...ghlight=heater
T14086 is offline
Old 27-12-2006   #6
Trader Rating: (0)
Re: heater fan
I have not checked the voltage at heater fan yet cos I did not know where it was. I have one of those manuals on cd from e-bay so i have the cct diags but I found the exploded drawings giving the location a bit confusing.
I have taken the dashboard to bits looking for the motor all the while thinking "this cant be right, it doesnt make sense!" and yep it wasnt right and I wasnt doing anything sensible. So tommorrow Ill put it all back then take a different part of my car to bits.
Any tips on getting the motor out or testing in position?
apart from knowing where to look for it!
cheers
Ian
(T) Heater Fan working erratically QuickNick Bravo / Brava 0 03-07-2006 09:52
(T) Heater Fan Problem! magicmonkey Uno 5 31-01-2006 09:51
(T) Punto Fan Heater Problem trevdye Punto 5 09-01-2006 09:04
Heater fan blows fuses pinkpunto Tipo 3 28-08-2005 16:51
