The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 26-12-2006   #1
Trader Rating: (0)
faulty jtd coil
Guys
I've had the preheat fault coming up. Now, the car seems to be misfiring with the exhaust phutting? I've had the engine cover off and if I put pressure on the 3rd coil along, the engine starts running properly. I was going to buy a new coil to replace this one. They look easy enough to fit but I've never done it before!
Any hints or tips?
Darren
97 Coupe 2.0 20v Nightfire Red
D-Stilo is offline
Old 26-12-2006   #2
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
Exclamation Re: faulty jtd coil
Are you saying you've got a loose heater plug
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is offline
Old 26-12-2006   #3
Trader Rating: (0)
Re: faulty jtd coil
Could be?
I sprayed some electrical contact cleaning fluid on the ends of the contact but didn't make any difference. Is the plug easily replaced?
Darren
D-Stilo is offline
Old 26-12-2006   #4
Argonought's Avatar
Trader Rating: (0)
Re: faulty jtd coil
I'd screw it back in if I was you (and quickly)
I don't suppose it's even faulty but I think I'd have words with the person that fitted it
You'll almost certainly need to take it in to a specialist Fiat garage as you need quite specialised tools to access the plug and tighten it.
Once it's back in then you may well find the 'Preheat Fault' message disappears.
Old 26-12-2006   #5
Trader Rating: (0)
Re: faulty jtd coil
I just reseated the black plastic plug which connects to the top of the coil?? The coil hasn't actually been replaced, yet?
Darren
D-Stilo is offline
Old 26-12-2006   #6
Grumpy Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
Re: faulty jtd coil
Coil? preheat? ....... do you mean the connector ontop of the 'glow-plug'?
T14086 is offline
Old 26-12-2006   #7
Trader Rating: (0)
Re: faulty jtd coil
Possibly!!!
4 of them in a row across the top of the engine?
D-Stilo is offline
Old 26-12-2006   #8
Argonought's Avatar
Trader Rating: (0)
Re: faulty jtd coil
The injectors run along the top of the engine.
The glow-plugs are at the rear (at an angle) and are very difficult to get to. Each one has a lead attached and looks a little like a spark plug.
Old 26-12-2006   #9
Trader Rating: (0)
Re: faulty jtd coil
That's them, they sit at an angle? Big thick cable with plastic connector connecting across the top of each plug and a smaller, thinner material covered cable too?
Darren
D-Stilo is offline
Old 26-12-2006   #10
T14086's Avatar
Trader Rating: (0)
Re: faulty jtd coil
Sounds like you have faulty glow plug then.
T14086 is offline
Old 26-12-2006   #11
Trader Rating: (0)
Re: faulty jtd coil
Thanks for the reply T. Are these easy fitted or is it a job for a mechanic?
Darren
D-Stilo is offline
Old 26-12-2006   #12
Argonought's Avatar
Trader Rating: (0)
Re: faulty jtd coil
You can easily check which one (if any) is faulty if you can use a multimeter.
Remove the heater relay module (bolted to middle top of bulkhead), remove the 6 pin plug (with 4 thick wires attached) from underneath and then measure resistance to earth on each pin. Each one that's open circuit is defective.
Now take it to a good Fiat garage and ask them to replace each one which is faulty (you must of course tell them exactly which one/s you want replaced).
Ask them to test the duff one across a battery. If it glows like an electric fire then you’ve just asked them to remove a perfectly good one (but hopefully it will be dead )
Driving with a defective glow plug will do no harm to the engine but if you have a loose one (about to blow out) then I'd imagine this could be very dangerous
It might help to read this too
Old 26-12-2006   #13
T14086's Avatar
Trader Rating: (0)
Re: faulty jtd coil
...might aswell get them all changed at same time though,about £9 each.
T14086 is offline
Old 27-12-2006   #14
Trader Rating: (0)
Re: faulty jtd coil
The car does a lot of spluttering and there is no power. I thought driving like this would harm the engine? Local dealer is closed till Tuesday but I think I've found them on ebay for £11.99 each.
Darren
D-Stilo is offline
Old 27-12-2006   #15
Argonought's Avatar
Trader Rating: (0)
I expect it will but what's that got to do with a duff glow-plug.
They're only used to preheat the cylinders on a cold morning. Most of the time they don't do anything.
I thought you said you thought one might be loose
If it is then get if fixed pronto !!!
(T) TDi or JTD? LoBsTeR Stilo 15 22-12-2006 22:28
(T) Faulty Coil and key symbol staying on. Goldenclogg Punto 5 11-12-2006 12:11
(T) JTD 105 SX flashing coil symbol v12nut Marea 7 12-08-2006 15:12
124 spider coil overheating dougdog Spider 1 03-07-2006 19:40
(T) After Bravo JTD non-runner or JTD complete wiring harness for project... JTD Lover Bravo / Brava 2 07-12-2005 17:42
