The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 24-12-2006   #1
KK1
Trader Rating: (0)
KK1 has donated! United Kingdom
Throttle body cleaned....but.
Hello, I was following the stilo guides for cleaning the throttle body and cleaned it this morning.
It made a hell of difference in the initial stages, but the revs have been a little eratic.
It starts at very high revs, about 1600, and then drops to about 1000, then seems to fluxuate between 700 - 1000.
Hopefully it will sort it self out, I double checked all the connections and all were ok.
Any ideas whit it would be a little eratic.
Thanks in advance.
Merry christmas and have a great new year.
KK
KK1 is offline
Old 24-12-2006   #2
Grumpy Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
Re: Throttle body cleaned....but.
There is a examiner process for learning the throttle,also I trust you have had the throttle body/MAP software update.
T14086 is offline
Old 24-12-2006   #3
KK1
Trader Rating: (0)
Yep all the updates have been done.
Seemed a little better earlier on so maybe the ecu is still learning the best settings?
KK
KK1 is offline
Old 24-12-2006   #4
T14086's Avatar
Trader Rating: (0)
If you have cleaned it then the throttle 'flap' has to learn it's new posistion...even by removing a few bits of 'sludge' the position has altered.
You could try disconnecting ECU for 10 minutes then turning ignition on fot one minute (dont start car),after this turn ignition off for one minute then start car (dont touch throttle let it idle) until cooling fan cuts in then switch off.(this process applies especially to Brava/bravo owners!)
Then take car for drive & see how it is,if its no better a throttle phase learning should be carried out.
T14086 is offline
Old 24-12-2006   #5
KK1
Trader Rating: (0)
Smile Re: Throttle body cleaned....but.
Thank you very much for the advice.
I will give it a few more days and see how it goes, if no good I will take your guidance and disconnect the ECU.
Thanks again.
KK
KK1 is offline
Old 24-12-2006   #6
T14086's Avatar
Trader Rating: (0)
Good luck,let us know how you get it
p.s.just disconnect 2 plugs on ecu so you dont have to reset clock etc
T14086 is offline
Old 25-12-2006   #7
KK1
Trader Rating: (0)
Quick question, which 2 plugs do you mean, I think you mean the two large rectangular blocks next to each other which lever off.
Please confirm.
Thanks.
Merry christmas.
KK
KK1 is offline
Old 25-12-2006   #8
T14086's Avatar
Trader Rating: (0)
Yep,on the ECU itself.
T14086 is offline
Old 25-12-2006   #9
KK1
Trader Rating: (0)
Cool, thanks for that.
I will let you know the results.
KK
KK1 is offline
Old 26-12-2006   #10
KK1
Trader Rating: (0)
UPDATE...
All is well, I think its still learning as the revs are a little eratic but gets better every time I drive it.
I will carry on driving as normal, hopefully it sorts it self out.
Anything else I can do T14086/advice.
Thanks in advance.
KK
KK1 is offline
(T) Removing coolant pipes from Throttle Body andyr Punto 1 15-08-2006 21:16
(T) Throttle body died / self learning procedure yellowstilo Stilo 1 06-06-2006 18:30
(T) Special made throttle body for Cinq/Sei + Punto 55/60/75 Tricker... Cinquecento / Seicento 15 05-03-2006 12:28
Can I use the throttle body from a Bravo/Brava? fiatritmo Tempra 0 26-02-2006 16:14
