The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 19-03-2004   #1
Trader Rating: (0)
steering noises
ive noticed a kind of strange noise from the steering, its hard to describe but it sounds like a kind of whistling noise when you turn the wheel, usually when stationary or when manouevering to park. its a really low whistle it makes so im not sure if its normal or not.
something else sounds like a brake rubbing when reversing around a corner with full lock.
any thoughts on the above???
Bog Standard Fiat Stilo 1.2 16 valve Active, in Sexual Rouge, el plastique rimolla's!! ;)
MaxJam is offline
Old 19-03-2004   #2
Trader Rating: (0)
My dynamic makes a noise which is sort of a squeak/creaking when I turn the wheel fast or when it has just been started up, haven't mentioned it to the dealer yet. I think there is another post on here about the same problem and they had the steering column replaced.
Tashy is offline
Old 19-03-2004   #3
purplemonday's Avatar
Trader Rating: (0)
purplemonday has donated!
Hi MaxJam
The noise you describe sounds like the DualDrive power steering - it's electric rather than hydraulic so it only kicks in when it has to rather than running contiuously. As a result you tend to hear the motor running when stationary or manouvering.
________________________________________________
I have a drink problem...only one mouth but two hands!
1.6 Active 5 door in Crystal Green.
http://www.clubstilo.com
purplemonday is offline
Old 20-03-2004   #4
Trader Rating: (0)
Exactly as above, only if you here a whirring all the time your electric radiator fan is probably going even when the engine is cold! I've got my booked in to have this fixed!
2003 3 Door Stilo 1.2 Active, Sassy Grey, 5 disc CD Changer, Abarth boot badge, plastic wheel trims - and 42.4mpg average so far. Love it, Oh yes!
StiloBoy is offline
Old 25-03-2004   #5
Trader Rating: (0)
ive noticed a squeel when i reverse or drive forward very slowly with the wheel turned, really low though, i reckon one of the front brake pads is rubbing when the wheel turns, any ideas???
MaxJam is offline
(T) New Punto Power Steering & Engine Management Fail shotter Punto 17 30-12-2006 12:45
(T) Power Steering problem ELX(8v) 2000 reg NickT Punto 3 04-07-2004 02:03
(T) Steering Problem, any suggestions? visualcandy Punto 4 12-05-2004 12:43
(T) Seicento Power Steering? dawozere Cinquecento / Seicento 7 27-02-2004 16:30
(T) Does your Steering Wheel Make Noises?? si_ng23 Punto 3 27-02-2003 17:10
