| rear door open, no lights on inside anyone has a clue about why the interior lights stay off when I open the left rear door? also, when I start the engine and the same door is open, no warning appears on the dashboard? is there a switch somewhere in the door that could be damaged? could it be changed? thanks.
__________________ Stilo 1.9 JTD, 145 BHP (re-mapped), Sassi Grey | |||
| Grumpy Forum Moderator | Re: rear door open, no lights on inside switch is in the lock mate,also worth cheking the door harness connector.
| | #3 | |||
__________________ Stilo 1.9 JTD, 145 BHP (re-mapped), Sassi Grey | ||||
| | #4 | ||
| Grumpy Forum Moderator | Re: rear door open, no lights on inside Yes it is,sorry.Often just undoing it (twist) & doing it up again will cure fault,if not then it looks like door panel off time.
| | #5 | |||
but, are you sure you have to twist this one to remove it? or is that only for the front door connector? because the rear one had a plastic bit which needed sliding up a little, and then it looked like it could get disconnected; however I did not force it, I was afraid not to break it.
| | #6 | ||
| Grumpy Forum Moderator | Re: rear door open, no lights on inside Good stuff Yes your right you lift up the retaining clip with a small flat screwdriver.
| | #7 | ||
| Re: rear door open, no lights on inside ...it was good stuff, until 2007 came... :-\ not working again, fiddled again with the connector, no luck this time; would it help using some electronics cleaning spray stuff on the male and female connectors of the door?
| | #8 | ||
| Grumpy Forum Moderator | Re: rear door open, no lights on inside You can try,there might be a open/damaged terminal in the connector.Have a look to see if there is anything obvious.
| | #9 | |||
| NobodyBlamesTheHappyGuy:D | Re: rear door open, no lights on inside
![]() Morten.
__________________ jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint. member of the 5-door massive attack. | |||
| | Drinu | Uno | 6 | 18-11-2005 10:18 |
| | MiniG | Stilo | 3 | 01-10-2005 15:05 |
| | gavoleary | Stilo | 13 | 30-09-2005 20:20 |
| | AIJ29 | Cinquecento / Seicento | 19 | 01-08-2005 13:00 |
| Panda Fantasia Rear Lights - Help! | Smileyjon | Panda (Classic) | 3 | 26-01-2004 00:14 |
