| | Thread Tools | Search this Thread |
| Replacing tape to aftermarket CD pin out information - advice required ![]() [img=http://img213.imageshack.us/img213/5455/stiloisoconnectionfc3.th.jpg] I have just purchased a Blaupunkt Santa Cruz MP36 cd player for my stilo. However I beleive it is not a straight forward as just plugging in the din connector and going. I think some of the wires will need swapping such as 4 and 7 as the permanent and switched lives are reversed. Also where do i get the illumination from as Pin 6 on the stilo is not connected but pin 6 on the santa cruz is the illumination. Will this come from permanent live? or switched live? Can the wires in the stilo ISO block be switched easily without any cutting? Could anyone confirm any of the above or guide me in the right direction as I would hate to knacker anything!! Many Thanks in advance
__________________ Fiat Stilo 3dr 1.6 Dynamic - pretty standard. | |||
| Re: Replacing tape to aftermarket CD pin out information - advice required where did that diagram come from? im interested in knowing the pin out for block C on the stilo side of the HU! A + B are identified but not block C.
| | #3 | ||
| Re: Replacing tape to aftermarket CD pin out information - advice required Is there a yellow and wire ya can unplug on the headunit side of the loom? If so you need to plug the yellow and red from the radio end to the red stilo end to make it think its perm feed and ignition If that makes any sence to ya I know on my alpine i could plug the yellow and red via a bullet in the loom so it just plugs into the red on the stilo side
__________________ | |||
| | #4 | ||
| Re: Replacing tape to aftermarket CD pin out information - advice required The diagram (top part) came from the Stilo manual. yep - thought it was red and yellow that needed swapping, thats what I have done and it all wrks fine. Rang Blaupunkt - very helpful! Thanks for replys.
| | #5 | |||
No problem Glad to help and been there myself before
__________________ | ||||
| | Bogbeast | Marea | 13 | 16-02-2007 22:46 |
| Urgent advice required | Notorious131 | Lets Talk FIAT | 21 | 08-12-2006 22:38 |
| | armarni | Stilo | 8 | 14-08-2006 20:38 |
| | peterp | Bravo / Brava | 0 | 27-06-2004 03:05 |
