The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 10-12-2006   #1
Trader Rating: (0)
1.6 loose connection message [rpm sensor]
Hi Guys
Got a "loose connection" error message on Friday afternoon. Was sitting at lights, car ticking over, "loose connection" error, car died?? Leave it for half an hour and it starts again. After the error appears the car will try to start (turns over) but just won't fire. I've been reading the threads about the d4 connector this morning, could this be causing my problem??
Any help would be greatly appreciated!
Darren
97 Coupe 2.0 20v Nightfire Red
D-Stilo is offline
Old 10-12-2006   #2
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
PNL has donated! United Kingdom
Cool re: 1.6 loose connection message [rpm sensor]
I'm not to smart with the electronics on the stilo but sounds like you will need examiner to pin point this fault Decks/rroppe or tech might log in later sit it out and wait a while if anyones out there and has any suggestions then fire away and help him
International man of mystery
Wit ..sarcasm you get it all from me..
PNL is offline
Old 10-12-2006   #3
Whaddya mean too old?
Deckchair5's Avatar
Trader Rating: (0)
Deckchair5 has donated! United Kingdom
Loose connection = bad connection and so often just taking a connection apart and reconnecting can do enough to brighten up the contacts and remake it good again. But contact cleaner usedd sparingly on the contacts really is the biz and well worth buying and having it handy for use at any time. Seems pricey at £4 but you'll need it lots so it's a sound investment
Which connector? Go for anything that would make your engine die and not supply fuel or ignition for a restart. Could be anything but D4 is a good start
I've had "loose connection" appear with no symptoms and then never reappear again. It's a true error though as the car has sensed wrong resistance somewhere. Getting fault code read might pinpoint area
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline
Old 10-12-2006   #4
Trader Rating: (0)
Halfords - here I come?!
D-Stilo is offline
Old 10-12-2006   #5
Trader Rating: (0)
In the past when I've had this come up its when starting it then clears but about 2 weeks later a coilpack has gone down it's done this twice over a period of several months.My battery packed up a few weeks back and the loose connection came up about a week before it died.After the coilpack's and battery were replaced the message has not come back.
jazzman is offline
Old 10-12-2006   #6
Grumpy Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
'Loose connection' doesn't automatically is a connector D4 fault (although its best place to start!!!) but could also refer to door nodes connection fault.
T14086 is offline
Old 10-12-2006   #7
Glutton for Punishment
Rich's Avatar
Trader Rating: (1)
Rich has donated! United Kingdom
For reference, "Loose Connection" can also refer to blown fuses, although in this instance I would doubt it.
Yeah, I would say D4 is a good place to start.
07 Bravo TJet Sport, Maranello Red
Factory Options: Dual Zone Climate, 18" Alloys
Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates
Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion
Rich is offline
Old 10-12-2006   #8
Trader Rating: (0)
Well, I just had the d4 connector apart. It was very dirty, gave it a blast with an air duster. Put it back together. The car has started first time about half a dozen times in a row. Going to take it for a run now to halfords for some electrical connection cleaner stuff, I'll have a go with that later. Don't want to jinx myself but the car seems to be idling better! It's defo a little higher anyway, used to sit abou 800 rpm now it's sitting at just under 1k??
Darren
D-Stilo is offline
Old 10-12-2006   #9
T14086's Avatar
Trader Rating: (0)
A further point is to wait until you get the 'check ok' message before you start the car,the battery has to power up quite a few modules/nodes when you switch ignition on aswell as turn the starter (especially cold engine) so if you wait few seconds before 'cranking' you wont get any 'false' messages.
T14086 is offline
Old 10-12-2006   #10
Trader Rating: (0)
Didn't make it to Halfords - car cut out again. 3 times in total - managed to start again each time after waiting for about 10 mins. Now though it won't do anything when I turn the key, I think the battery is drained - looks like I'll be taking the day off work to try and get it sorted. I don't even have a battery charger or jump leads!!
Darren
D-Stilo is offline
Old 10-12-2006   #11
Trader Rating: (0)
Forgot to add - the red engine symbol on the display is staying on - didn't notice this before?
Thanks Again
Darren
D-Stilo is offline
Old 10-12-2006   #12
Deckchair5's Avatar
Trader Rating: (0)
A few more things to add to your shopping list at Halfords eh
Battery charger
Jump leads
Contact cleaner
Really difficult to diagnose your symptoms from a distance but keep piling in descriptions of what happens and you may get more suggestions from diesel owners
Does it die only at tickover or does it kill like turning the ignition off?
Is the red warning on permanently now?
Do you know anyone who can read off the fault codes for you?
99 Bravo 1.2SX
Old 10-12-2006   #13
Trader Rating: (0)
I've organised to get the faults read tomorrow. Guess I should wait till after then before I go to Halfords!! It's a real pain in the arse - I'm an engineer and use my car for work!!!
There was a guy on here with examiner called Brown something? Lives just up the road from me (dundonald), haven't seen him on in a while though?
Thanks for the advice
Darren
D-Stilo is offline
Old 10-12-2006   #14
Deckchair5's Avatar
Trader Rating: (0)
You can buy basic fault code readers quite cheaply now or you can be more adventurous and rig up an interface and OBD2 connector to your laptop and read them off yourself. Both available on Ebay and worth thinking about as it's the way of the world these days
99 Bravo 1.2SX
Old 10-12-2006   #15
Trader Rating: (0)
It's obviously something I'll have to invest in. I just looked on ebay. They have obd2 to 9 pin serial, I think I need to buy the can-bus compatible one? And what software do I need?
Darren
D-Stilo is offline
(T) loose connection on 2.4 anthonytutton Stilo 25 29-09-2007 21:45
(G) To low rpm at warm idle, RPM sensor? Migaard Marea 13 29-05-2007 15:47
To low rpm at warm idle, RPM sensor? Migaard Newbie Central 2 25-05-2007 18:26
