The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo > Stilo > Technical
Old 30-09-2006   #1
waynem325's Avatar
Trader Rating: (0)
High oil level warning.....?
Hi all,
I've had this warning several times over the last couple of weeks and it has me a little confused.
I've had the car (2003 1.9 JTD) for about 4 months now and haven't had this warning before. The car was "apparently" serviced before i took ownership, but even though the service book was stamped i was a little suspicious when i checked the dipstick when i got home and found the oil colour very dark.
I haven't added any oil (or removed any for that matter) and each time this warning pops up i immediately check the level on the dipstick and it is spot on. Upon turning the ignition back on the warning is still there and only clears after leaving the car for an hour or 2.
The first thing that springs to mind is possibly a blocked oil filter....? But if it was serviced 4 months ago there should be no way the filter is blocked??? Which again raises my initial suspiciouns if it was at all serviced when i bought it?????
What do you reckon-is this a spurious fault or could the filter be blocked, or could it be something else?
Either way i think i'll do an oil and filter change asap (Are original Fiat filters the best option?)
Thanks in advance
Wayne
waynem325 is offline
Old 30-09-2006   #2
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
Re: High oil level warning.....?
If you have any doubts about the car being serviced properly then I'd get it sorted.
I'd move to a good fully synthetic oil and fit a Fiat filter.
Provided your JTD hasn’t been abused then it should get on very well with modern fully synthetics (mine certainly does)
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is offline
Old 30-09-2006   #3
waynem325's Avatar
Trader Rating: (0)
I always thought fully synthetic oils should be reserved for performance motors and could cause undue damage/wear to non performance use?
I always use, and I was going to use, part/semi synthetic.....?
I've never paid much attention to the full ins and outs or the whys and the wherefores etc and always try and go with the tried and tested
How long have you used fully synthetic in your Stilo Argonought?
Cheers mate
Old 30-09-2006   #4
Argonought's Avatar
Trader Rating: (0)
The point about fully synthetic is it can be risky to use them in engines which have been abused and/or poorly serviced. This is because a fully synthetic will clean your engine very thoroughly and might remove ridges of dirt collected around oil seals, pistons & cylinders etc. That's why it's important to use a fully synthetic whilst the engine is in top condition and the view seems to be that if you do then engine wear is reduced to very close to zero.
I've used Castrol Edge 0W-30 diesel in mine for about a year now and I haven't even needed to top it up. It's slightly green in colour so you know when you've got it! My JTD is NEVER noisy on startup (it used to be) and simply goes like the clappers. The only downside is that it must be one of the most expensive oils you can buy. There are cheaper fully synthetics out there and I’d simply go for something that’s recommended
Old 30-09-2006   #5
waynem325's Avatar
Trader Rating: (0)
http://cgi.ebay.co.uk/Castrol-Edge-T...QQcmdZViewItem
Is this about right for a 4 litre container of the stuff? When you said it was one of the most expensive i really didnt think you meant that expensive lol
Old 30-09-2006   #6
Argonought's Avatar
Trader Rating: (0)
Yep - that's the one!
Castrol now recommend EDGE TURBO DIESEL 5W-40 for the JTD which is a bit cheaper. Not sure why they've changed (a year ago they recommended 0W-30) but if my garage can offer a good price then I think I'll stick with it. As I've said before it runs great in mine but I don't think it would be a good idea to try the 0W-30 in any engine that's started to wear.
Old 30-09-2006   #7
waynem325's Avatar
Trader Rating: (0)
I prefer the thought of 5w-40 i must admit. Though I thought the recommended was 10w-40???
Silly question maybe.......but how would i know if the engine has started to wear?
The car is 3.5 years old with 38K on the clock-i've put 2K of them on in the 4 months i've owned the car and i have no idea how the car was driven before me.....except it had 1 lady owner. (which means nothin these days)
Ho hum
Old 30-09-2006   #8
Argonought's Avatar
Trader Rating: (0)
I think I'd just assume it's had minimal wear unless you have any reason to believe otherwise.
In your position I'd go for the 5W-40. The "5W" means it will be thinner when you start it on a cold morning which is a good thing for reducing startup noise and of course means less wear.
The "0W" part of 0W-30 gives even better cold protection to an extreme degree. The "30" part means the oil is thinner at running temperature which is where the extra performance and better fuel economy comes from and you can see why it wont work with a worn engine. The critical issue here is that only a fully synthetic oil remains stable at these viscosities (a conventional oil would be likely to breakdown - become even thinner - too thin to protect the engine) which means you get performance and good protection both at the same time
I guess the fact it’s so expensive speaks for itself
Old 01-10-2006   #9
waynem325's Avatar
Trader Rating: (0)
Thanks for the info Argonought
Its now been a few days since i last got the warning, so either the blockage has cleared (and there is a lot of crap flowing round the engine ready to block again?) or the little gremlins are playing tricks on my wigglies???
Either way I have a filter ordered and will do some oil shopping later on. This is my first diesel engine and have always used Magnatec on past petrol engines. I prefer staying with quality as opposed to cheaper alternatives-I know its an ongoing debate as to whether Halfords own oils and the like offer the same protection/performance as Castrol?
I am ignorrant enough to use Halfords own, however, I would feel uneasy driving around knowing I could offer my engine more protection by using Castrol-and lets face it-the more you care for your car, the longer it should last! (Theoretically anyway )
Aaaaaaaaannnnnnddddddd-the money I would save by doing the job myself means I can afford the good stuff and still have plenty of change left over
Old 01-10-2006   #10
its stilo the best's Avatar
Trader Rating: (0)
diesel oil will go dark colour or black quickly because it has a detergent in it to clean the inside of the engine , so that would explain why your oil is that colour , if the level is correct the oil level sensor could be a bit dodgy ?
its stilo the best is offline
Old 01-10-2006   #11
Argonought's Avatar
Trader Rating: (0)
....by doing the job myself means I can afford the good stuff and still have plenty of change left over
Good move
This is very true especaily if you've just moved to a synthetic oil (obviously is dependant upon how dirty the engine is in the first place).
However my oil, after 11 months, is certainly not black and still shows a tint of green.
Old 01-10-2006   #12
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
PNL has donated! United Kingdom
Cool Re: High oil level warning.....?
Only a thought here and I dont want to panic you Waynem but many years ago when completely rebuilding an engine for my Hillman minx series 5 I decided to change the oil pressure relief valve on the engine fitted it and along with reground crank /new bearings /pistons ect refitted the engine and on start up the oil pressure gauge shot up to 100psi and duly blew the oil filter of the block it turned out that he new relief valve was completely seized when inspected by the parts department that sold it to me they put a claim in for me to the rootes group [now Chrysler] and a letter came back saying I should have not started the engine with a seized relief valve so do I have to check that a new off the shelf part is faulty they never settled the claim just past the buck just a thought though as this MAY be a reason for your High oil pressure readings maybe muck obstructing it and jamming its operation
PNL is offline
Old 01-10-2006   #13
waynem325's Avatar
Trader Rating: (0)
Thanks for the replies,
Originally Posted by PNL
as this MAY be a reason for your High oil pressure readings......
The warning I was getting was "High oil level". Should that be interpreted as high oil pressure.
I kinda figured the oil could have backed up, caused through blockage, to the level sensor hence the high reading. If the pressure was high then surely i would have got a "high oil pressure" warning?
But then i guess if there was a blockage then the oil pressure must rise???
I do have a thin covering of oil inside the engine bay-it was checked out before I bought the car and came back as clear of any leaks. I cleaned it up when i got home, and now after 2000 miles the engine bay is coated again. I've read on here that for a diesel that is normal. Its not excessive by any means-and has certainly never dumped any one the road, and hasn't altered the reading on the dipstick. (Does make me wonder where it comes from though, and why? Surely not normal???)
Gutted for you mate! In fact I'm shocked they sold you a faulty part and never accepted responsibility??!!!! Surely a consumer rights issue?
Mine is definitely black! No sign what-so-ever of the original colour. Looks like crude oil
Old 01-10-2006   #14
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
I wouldn't think the two are not related and as our cars are now full of electronic sensors and not in many cases mechanical devices you may not even have a mechanical pressure relief valve I would ask someone like T14086 if this is the case I have found out though that electronic diagnostics are NOT 100% accurate in its operation as a recent injector job has turned out to be a inlet manifold air leak a leak that's cost me £400 to put right with the diagnostic examiner showing No4 injector fault and a replacement of the injector and the car still misfiring after it was fitted give me old fashioned technical know how before a damn machine any day
PNL is offline
Old 01-10-2006   #15
Argonought's Avatar
Trader Rating: (0)
This doesn't sound right at all. My engine bay is pretty much pristine. There's small amounts of seepage under the engine cover but that's about it.
All modern engines are closed systems so the only way oil can escape (apart from a leak) is from damaged vapour return pipes and the like. I'd inspect all pipework carefully and also be wary if anyone has modified the induction (air filter etc).
vB code is On
finally managed to cure the high temprature, and get the oil changed. christopher watson Panda (Classic) 4 08-09-2005 23:13
oil sensor failure / engine disaster Heather's Stilo Stilo > Technical 24 06-05-2005 23:16
Urgent! Oil Warning Light nickphonics18 Punto > Technical 10 30-03-2005 09:18
High oil consumption tomideli Stilo > Technical 14 08-09-2004 09:41
Help... water level warning light Retro23 Tipo 0 27-04-2004 19:45
