| | #16 | |||||
| Re: High oil level warning.....?
I believe it was a pressure check that was conducted before buying the car-i never saw it take place and was only told by the salesman- "Nothing to worry about" was his words-hope he was right
| | #17 | |||||
| Re: High oil level warning.....? I read this the other day: http://www.fiatforum.com/stilo/77719...urbo-pipe.html I took comfort from:
| | #18 | ||
| Re: High oil level warning.....? Here's a look-see: ![]() Red arrow points to where the oil is. Its only in this area. Icidentally-what is the silver/blue canister that the green arrow is pointing to? And a little closer: ![]() What do you think?
| | #19 | ||
| It's about GO! not SHOW! | Re: High oil level warning.....? The canister is your diesel filter. This gets changed during many services and also has a tendency to leak. I'd say the oil leak shown in your photo needs to be resolved without any question. Can you not trace the leak back to its source. Take off the engine cover and it might be obvious. ......otherwise one of the techies might have an idea.
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #20 | ||
| Re: High oil level warning.....? The leak was my main concern when buying, but after it was supposedly checked I was reassured. I figured if it were to be anything serious something would become obvious within the (Huge) 3 month warranty. I cleaned it immediately and kept checking every few days. After a couple of weeks there was no obvious return and pretty much forgot about it. Its only since I got the oil level warning that i've had a nose around under the bonnet and found its return. Like you say I can take the engine cover off and see exactly where its coming from???
| | #21 | ||
| Grumpy Forum Moderator | Re: High oil level warning.....? As mentioned diesel cars oil becomes black within literally seconds of putting it in,its not cause dealer hasn't changed oil. Could be pressure sensor fault,wiring,cluster or battery voltage problems causing your display to show high oil level.Often(as on multiplas)simply disconnecting battery for few minutes can cure this.
__________________ IF YOU'RE HERE TO MOAN OR SLAG FIATS - DONT BOTHER! | ||
| | #22 | ||
| Re: High oil level warning.....? Thanks for the advice, If the battery was disconnected is there anything else that resets that i should know about-trip A+B readings etc. Will I need the code for the stereo etc etc. Cheers
| | #23 | ||
| It's about GO! not SHOW! | Re: High oil level warning.....? You'll lose all trip data and have to reset the date/time but that's about it
| | #24 | ||
| Re: High oil level warning.....? Argonought, I had a quick zip into Halfords earlier looking for Castrol Edge and found they only sell 4 litre bottles of the stuff! The GTD Magnatec came in 4.5 litre bottles (Which is what I'll probably opt for) Correct me if I'm wrong but the Stilo oil capacity is something like 4.7 litres, and with the filter a little bit more-is Castrol available in 5 litre bottles or do you buy in bulk or have to buy a litre bottle as well??? Price wise I thought Castrol good value at £36 for GTD, and £42 for Edge. The Halfords own came in a 5 litre bottle and was pretty much half the price. Now why cant Castrol supply larger capacity bottles??? I'm seriously considering using Selina turbo diesel as I'm sure they come in 5 litre bottles and are obviously the recommended choice of Fiat. Kid in a sweet shop!!!!
| | #25 | ||
| Re: High oil level warning.....? Mine sometimes throws up the high oil level warning... when facing up hill. Mostly have one to two spots missing off the display when i'm facing down hill, depending on the severity of the hill... if in doubt I park it on a level surface, leave it a few hours and then dip it with the stick... normally up to the level on the dipstick
__________________ Black 115 JTD, 15' Steelies with Doblo trims & debadged +147 Cruise Control NOW with added Millers Diesel Power Sport 4 | |||
| | #26 | |||
I agree that Selina turbo diesel would be a good choice
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | |||
| | #27 | ||
| Glutton for Punishment | Re: High oil level warning.....? Halfords own brand oil is Comma; it's not bad but always go down the Castrol route if you can afford it, or Selenia; our Stilo 1.6 seems to burn any oil thats not Selenia, but when it runs on Selenia it doesn't drink a drop!
__________________ 07 Bravo TJet Sport, Maranello Red Factory Options: Dual Zone Climate, 18" Alloys Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion | ||
| | #28 | |||
I think many people with high oil consumption take the view that using expensive oil is rather a waste and therefore avoid the more expansive brands. There are quite a few posts from peeps complaining about oil consumption but I wonder how many relate this to the actual brand of oil they're using I may be just lucky, with my engine, but is does seem rather odd that I've got very low oil consumption (close to zero) and yet I'm using one of the thinnest oils available.
| | #29 | ||
| Hi everyone, I've had problems with the oil level sensor for a couple of weeks now. Each time I started the car the oil level display was different - it varied from 2 black circles to 6 And I checked the oil level on the dipstick almost every second day - it was ok. A few days ago I had the oil and and the oil filter replaced but guess what happened after that? I got the high oil level warning But the dipstick shows a perfect oil level of course... And now my question: does any one know how to get rid of that **** sensor? Is it possible to disconnect it or something like that? I just don't want the oil level to be displayed during start-up (of course I can leave the the door open and the message will read door open ) And I have never got the message oil sensor fault Thanks for Your answers
| | #30 | ||
| It's about GO! not SHOW! | Re: High oil level warning.....? I suspect the sensor is just dirty. Make more sense to try to clean it than to disconnect it surely
| finally managed to cure the high temprature, and get the oil changed. | christopher watson | Panda (Classic) | 4 | 09-09-2005 00:13 |
| | Heather's Stilo | Stilo | 24 | 07-05-2005 00:16 |
| | nickphonics18 | Punto | 10 | 30-03-2005 10:18 |
| | tomideli | Stilo | 14 | 08-09-2004 10:41 |
| Help... water level warning light | Retro23 | Tipo | 0 | 27-04-2004 20:45 |
