| popping out | Is my driveshaft had it? I'm getting a clunking noise when accelerating/deccelerating and changing gear which really is the same thing, it sounds like 2 metal parts hitting together. also when i took my wheels off and spun the discs from side to side it makes a similar clunking noise then, haven't heard of many driveshafts going on Stilo's could it be that on mine though? ![]() EDIT: I know I put Is instead of *Has on the title but I can't change it, i've had a long day at work
__________________ MR2 owner!!!!!!! | ||
| Re: Is my driveshaft had it? cant say it was excatly the same but i was getting a clicking noise, that sounded like to metal parts rubbing together and when i took the wheel off, i could here the clicking but couldn't located it? But then i found it was the gaurd on the rear of the brake disk,as suggested in this thread: http://www.fiatforum.com/stilo-techn...ide-wheel.html Also a suggestion in there how to test to see if your driveshafts are going?
__________________ Grande Punto Sporting 1.9 8v Mjet - GSR Stilo 1.8 16v 155.9Hp - Kawasaki Z1000 ![]() | |||
| | #3 | ||
| popping out | Re: Is my driveshaft had it? Right so I've put it off for a while and I've done a video here http://www.fiatforum.com/gallery/data/500/MOV00025.3gp not a very good one i know but thats the sound i'm getting when putting my foot on/off the accelerator, and theres about just under an inch play when spinning the discs as you can kind of see in the video. Any ideas?
| | #4 | ||
| It's about GO! not SHOW! | Re: Is my driveshaft had it? I reckon with a bit of practice you could play tune with that Quite a bit of play there although a fair bit of it might be taken up by the diff. I'm sure one of the techies will be along soon to give the definitive bad news
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #5 | ||
| Re: Is my driveshaft had it? CV joint kaput ??... I seem to remember that sort of noise years back on a Cortina
__________________ Jack | |||
| | #6 | ||
| Re: Is my driveshaft had it? i'd say diff or CV joint- shall we get a book running on it?
__________________ | |||
| | #7 | |||
| The modfather |
__________________ International man of mystery ![]() Wit ..sarcasm you get it all.. | |||
| | #8 | ||
| popping out | Re: Is my driveshaft had it? how much are cv joints and how much does it cost to replace? I haven't got time to change it now until next month, damn work
| | #9 | ||
| Whaddya mean too old? | Re: Is my driveshaft had it? You'd need to find out which one it is, inner or outer CV joint. Put your hand on each whilst someone rocks and rotates the wheel in gear 1, you'll soon feel where the knocking is Do you have lowered suspension by any chance?
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX | ||
| | #10 | ||
| popping out | Re: Is my driveshaft had it? Nope haven't lowered the suspension but my drivers shock is leaking and I need a new set of those in the next few months
| | #11 | ||
| Re: Is my driveshaft had it? How did you solve that problem? I have the same noise, but if i put the car into neutral gear i don't have that noise so i hope it's not something with the gearbox or what.
| | #12 | ||
| popping out | Re: Is my driveshaft had it? Nope didn't solve it. 2 FIAT mechanics couldn't hear a noise so i took it to an independant who could hear the noise but he said he didn't know what it was, he checked over the car but couldn't find anything wrong
| | #13 | |||||
| | #14 | ||
| Re: Is my driveshaft had it? I had a vibration when I bought the current Faultiwagon, had the wheels balanced 3 times and swapped about but it didnt sort the issue. Had the car looked at a Fiat Specialist and it was diagnosed as a dead drive shaft. The car has 53k on the clock, the car was very noisy and shuck like mad under load and the vobration lessened but didnt go away when coasting. Cost £380 all in, I didnt pay for this though as the fault was there when I baought the car.. the bad thing is the car was sat in the garage for nearly 3 weeks while the driveres side drive shaft came over from Italy!
__________________ 52 plate Stilo Multiwagon Dynamic JTD 115- Skyroof,Connect+,Leccy seats,Cruise,Sliding rears, 17" factory wheels, Eibach Pro 30mm springs, Eibach Pro damper front/Koni Sport Rear, OH and a tow-bar with no ball! and lots of flipping scratches | |||
| | #15 | ||
| | ste wall | Cinquecento / Seicento | 4 | 10-09-2006 08:36 |
| Driveshaft gaitors & Sod's law | Vin | Panda (Classic) | 1 | 26-08-2006 21:33 |
| Driveshaft gaiter replacement | Vin | Panda (Classic) | 3 | 29-03-2006 13:25 |
| Driveshaft outer boot.. | John H | Panda (Classic) | 3 | 30-11-2003 19:23 |
