The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo > Stilo > Technical
Old 24-07-2006   #1
Trader Rating: (0)
Exclamation Replacing Rear Brake Pads
Hi, we changed our brake pads on our 1.2 16v stilo at the weekend the front ones went on fine but we had a problem when it came to the back ones, we had problems with the piston not moving, so we could slide them out. Does anyone know if we have to do something different than we did at the front? We can't find a haynes manual anywhere for a fiat stilo to answer our question?
Gems11 is offline
Old 24-07-2006   #2
not Dogspods
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
Re: Rear Brake Pads
covered a lot in the stilo section(should be a sticky stilo gurus
rear pistons need wound in not pushed.tool required though im told the tool from an angle grinder fits
custard is offline
Old 24-07-2006   #3
Whaddya mean too old?
Deckchair5's Avatar
Trader Rating: (0)
Deckchair5 has donated! United Kingdom
Re: Rear Brake Pads
The rear pistons need to be turned whilst retracting.
You need something like this
http://cgi.ebay.co.uk/Sykes-Pickavan...QQcmdZViewItem
or if you're making a career out of it then one of these
http://cgi.ebay.co.uk/BRAKE-CALIPER-...QQcmdZViewItem
Look at the threads on the piston as they wind back in different directions
One clockwise the other anticlockwise
Fun isn't it
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline
Old 24-07-2006   #4
www.ukpolicef0rum.co.uk
robertk2003's Avatar
Trader Rating: (0)
robertk2003 has donated! United Kingdom
Re: Rear Brake Pads
I changed mine last week, as best as i can recall-
Near side ones turn the piston in anti clockwise
Off side turn the piston in clockwise.
I found oin both sides the pistons needed to be tapped (and i do mean "TAPPED"), slightly with a mallett every so often to keep them turning freely.
Was quite an easy job, and the brakes feel great now.
Dont forget to release the handbrake so that you can move the pads.
And i found removing the handbrake tension spring ((located to the rear of the caliper)) helped, i used a pair of pliers for this to take of and put on,no problems.
(Tip:You should use chocs on the front wheels, or ideally jack up the whole car and use good axel stands- as i reckon a car falling on your head will sting a little in the morning)
If i can help in anyway, as i did this last week, let me know
Rob
Weeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeee
robertk2003 is offline
Old 24-07-2006   #5
Glutton for Punishment
Rich's Avatar
Trader Rating: (1)
Rich has donated! United Kingdom
Re: Rear Brake Pads
Excellent post there Rob, as suggested this is going to become a sticky and recorded in our little list of Stilo solutions
07 Bravo TJet Sport, Maranello Red
Factory Options: Dual Zone Climate, 18" Alloys
Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates
Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion
Rich is offline
Old 24-07-2006   #6
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
PNL has donated! United Kingdom
Cool Re: Rear Brake Pads
Fun isn't it
No criticism intended here to our good friend Decks but the second link for the kit is no good for the stilo because the stilo as previously stated has caliper pistons which screw in on different rotations and therefore you need a kit which has TWO thrust bolt in the kit for screwing back in either direction the job can also be done using a large G clamp and the disc fitting spanner from a small angle grinder as previously stated as well. I found that when doing mine it was much easier to remove the calipers from their mountings and cover the disc and put the caliper on top and work on it from there good luck its fiddly but NOT an impossible DIY job.
PNL is offline
Old 24-07-2006   #7
Stilo_ste's Avatar
Trader Rating: (0)
Re: Rear Brake Pads
As Phil said. Use a G clamp, small angle grinder spanner and rest the caliper on top of the disk assembly. Relatively easy to do.
Ciao - 1.6 Fiat Stilo, Konnichiwa - 2004 Mazda 6 2.0 D(137) TS.
2004 1.8 Vauxhall Vectra - 5 Door
1974 3.5 V8 Triumph Stag - 2 Door
Stilo_ste is offline
Old 25-07-2006   #8
Trader Rating: (0)
Re: Rear Brake Pads
Use a Caliper wind back tool, You can get them off Ebay, or through Draper, for £5. You use this with a decent socket and extension bar and it allows you to put pressure on the caliper via the socket.
Remember to buy some copper grease too, so you can grease up the wheel hub and the area around the handbrake cable etc ((Making sure not to get any on Disc or Pads!!!!)), this will help prevent corrosion and future problems associated with age and wear/tear.
Good luck and remember SAFETY, UNSURE?..............................THEN ASK FIRST!!!!!
p.s. Cheers Rich
Old 15-12-2006   #9
Deckchair5's Avatar
Trader Rating: (0)
Re: Rear Brake Pads
Thought I'd put this in here
There is a wind back tool from Fiat specifically designed for the Stilo with wind back on left hand and right hand threads
Name:	rear brake 4.JPG
Checked it out and it costs £11.46 from Fiat, available 2 days special order
Name:	rear brake caliper  <a href='http://www.fiatforum.com/autolink.php?id=1&script=showthread&forumid=19' target='_blank' title='Fabbrica Italiana Automobili Torino' class='gal'>fiat</a> tool.JPG
Part Number 1.870.886.000
99 Bravo 1.2SX
Old 15-12-2006   #10
wotnowarninglight's Avatar
Trader Rating: (0)
Re: Rear Brake Pads
Aha! The blisterless option Think I will be at the JTD's brakes shortly not liking the feel of them much at the mo...
Black 115 JTD, 16' 16vt Coupe alloys & debadged +147 Cruise Control
wotnowarninglight is offline
Old 15-12-2006   #11
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
Get greenstuff for the front and standard pads for the rear THEN you will see the differance MASSIVE
PNL is offline
Old 15-12-2006   #12
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
Re: Rear Brake Pads
Here's the tool in the flesh:
As supplied it actually needs to be modified since the locking bolt is far too long and strikes the side of the caliper after only half a turn. You could either cut the bolt in half or do as I did and find another shorter bolt that screws directly into the spindle (as shown).
It's quite important to easily be able to unlock/remove this screw as I was to discover on my 1st attempt. Once the piston is fully retracted you need to remove the tool - but as soon as you try to loosen it you start to wind the piston back out The answer, of course, is to unlock the rotating disc so that it's able to freewheel.
Using this tool turns a job you're dreading into a job you can actually look forward to doing and in my view is fantastic value at £13.14 (inc)
I used a proper retractor for the front pads but as a bonus I could have used one of these to do that job too.
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is offline
Old 15-12-2006   #13
Argonought's Avatar
Trader Rating: (0)
Re: Rear Brake Pads
Phil, just fitted GreenStuff all round on mine.
Is there any particular reason you only recommend them for the front?
Heard a slight squeak from the front this afternoon I think those pads might need a bit more copper grease. Didn't want to grease em up too much as was quite liking the green pads/read calipers effect
Old 16-12-2006   #14
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
Sorry I missed this Argo I simply found that as the fronts did the majority of the work I didnt need them on the rears you possibly might get a slight improvment tho by useing them I didnt have any squealing from mine spos you did fit the stick on shims that were supplied I stuck some copper greas in all the usual places and everything was a ok funnily enough tho my lad did have squealing on one side of his car but its gone now its all bedded in you got red calipers I'm gonna rename you now Chavystilo
PNL is offline
Old 16-12-2006   #15
Argonought's Avatar
Trader Rating: (0)
Re: Rear Brake Pads
Oh no , not that
I put the rubber shims on the rears OK (they’re nice and quiet) but didn’t find any in the box for the fronts
I think I'll whip them out and grease them up a bit better
vB code is On
Where to copper grease rear brake drums? 4paws Uno > Technical 2 21-06-2006 16:50
Rear brake pads M@nticore Uno > Technical 5 10-06-2006 02:45
Wanted: Uno turbo rear discs, pads, hubs and brake cable (Parts Wanted) Firewarrior For Sale / Wanted 0 30-10-2005 08:22
Brake Pads? Ian_Dublin Punto 1 03-06-2005 00:31
Rear disc pads. cmk12342000 Stilo > Technical 3 21-10-2004 07:41
