The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo > Stilo > Technical
Old 10-10-2007   #46
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
Re: Replacing Rear Brake Pads
Originally Posted by koe_182 View Post
honest oppinion needed, is this procedure a bit tricky for someone without much knowledge? managed to do the front ones ok but this looks harder.
considering getting a local garage to this one.
It's easy enough with the proper tool (if you can do the front)
You just need to weigh paying £15 for the tool vs paying someone to do it.
Personally, I'd rather pay an outlet to change the front pads as that way you can moan and take it back if they start squealing
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is offline
Old 10-10-2007   #47
Trader Rating: (0)
well my front ones squeal like hell but ive given up on that, not sure what the problem is.
i've just been quoted £137.29 for new disks and pads on the rear, does that sound about right?
koe_182 is offline
Old 10-10-2007   #48
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
PNL has donated! United Kingdom
Cool Re: Replacing Rear Brake Pads
And cant you remember our stilo sweet heart Twinny trying to change his back pads ..he got in such a tizzy I thought he was having a sex change
PNL is offline
Old 10-10-2007   #49
Argonought's Avatar
Trader Rating: (0)
Kinda makes my point I guess
.....but what the hell are you considering changing discs on the rear for All you need is a set of rear pads.
For £137.29 you should be able to get pads changed on BOTH front & rear at a brake centre (sort out that squealing too)
Old 03-11-2007   #50
Nello's Avatar
Trader Rating: (0)
Guys can you use just something like a screwdriver to wind back the rear calipers like you used to in my old X1/9's or do you really need that special tool?
Nello is offline
Old 03-11-2007   #51
Argonought's Avatar
Trader Rating: (0)
If you read up all the threads on this then you shouldn't need any more convincing.
Mind you - most of us learn the hard way
...but I promise you you'll feel sick if you do ruin a rear caliper
Old 08-11-2007   #52
Nello's Avatar
Trader Rating: (0)
Well guys did the pads today - boy did they need doing too! Originals after 44K.....
And yes OK..................I would reccomend getting the FIAT tool.....got w*nkers cramp manually turning them darn rear calipers!!!!
Nello is offline
Old 20-05-2008   #53
Trader Rating: (0)
Exclamation Re: Replacing Rear Brake Pads
Watch out when you do the rear pads. The tool can be made with bolts and plates but Fiat price is quite good as against LASER tool £20-£22 which may not quite fit.
BUT BE CAREFUL NOT TO TURN THE WRONG WAY AND END UP WITH THE PISTON IN YOUR HAND.
DOES ANYONE KNOW HOW TO GET IT BACK PLEASE??
THE HAND BRAKE CABLE SHOULD BE DISCONNECTED ACCORDING TO THE MANUAL - ( I HAVE IT ON DISC IF ANYONE NEEDS IY )
lewbaker is offline
Old 1 Week Ago   #54
Trader Rating: (0)
Thumbs up Re: Replacing Rear Brake Pads
Originally Posted by Gems11 View Post
Hi, we changed our brake pads on our 1.2 16v stilo at the weekend the front ones went on fine but we had a problem when it came to the back ones, we had problems with the piston not moving, so we could slide them out. Does anyone know if we have to do something different than we did at the front? We can't find a haynes manual anywhere for a fiat stilo to answer our question?
Hi, I have just fitted new pads on the rear of our stilo, I had great problems with rewinding pistons, tried for hours. The very simple solution was to use a rewind cube from draper or sealey at under £10, I fitted a socket extention bar on to the cube and fitted it to an electric drill, reverse gear for near side and forward gear for offside, I pushed the drill hard to engage lugs on piston and pulled trigger for about 5 seconds and that was it, the piston went back like a dream. Dont forget to open the lid on brake resevoir as the fluid will back up, it was so simple. You can jam the caliper against the shock absorber to hold in place. Each side took only 5 minutes in total. Good luck Barry
Barry the Inventor is offline
Old 1 Week Ago   #55
Argonought's Avatar
Trader Rating: (0)
Barry, Welcome but there's very little point in posting a reply after pretty much two years (do you think they even still have the car?)
Have a read through this complete thread - you should find it interesting
vB code is On
Where to copper grease rear brake drums? 4paws Uno > Technical 2 21-06-2006 16:50
Rear brake pads M@nticore Uno > Technical 5 10-06-2006 02:45
Wanted: Uno turbo rear discs, pads, hubs and brake cable (Parts Wanted) Firewarrior For Sale / Wanted 0 30-10-2005 08:22
Brake Pads? Ian_Dublin Punto 1 03-06-2005 00:31
Rear disc pads. cmk12342000 Stilo > Technical 3 21-10-2004 07:41
