| | #46 | |||
| It's about GO! not SHOW! | Re: Replacing Rear Brake Pads
You just need to weigh paying £15 for the tool vs paying someone to do it. Personally, I'd rather pay an outlet to change the front pads as that way you can moan and take it back if they start squealing ![]()
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | |||
| | #47 | ||
| Re: Replacing Rear Brake Pads well my front ones squeal like hell but ive given up on that, not sure what the problem is. i've just been quoted £137.29 for new disks and pads on the rear, does that sound about right?
| | #48 | |||||
| The modfather |
And cant you remember our stilo sweet heart Twinny trying to change his back pads ..he got in such a tizzy I thought he was having a sex change ![]()
| | #49 | |||
.....but what the hell are you considering changing discs on the rear for All you need is a set of rear pads.For £137.29 you should be able to get pads changed on BOTH front & rear at a brake centre (sort out that squealing too) ![]()
| | #50 | ||
| Re: Replacing Rear Brake Pads Guys can you use just something like a screwdriver to wind back the rear calipers like you used to in my old X1/9's or do you really need that special tool?
| | #51 | ||
| It's about GO! not SHOW! | Re: Replacing Rear Brake Pads If you read up all the threads on this then you shouldn't need any more convincing. Mind you - most of us learn the hard way ![]() ...but I promise you you'll feel sick if you do ruin a rear caliper ![]()
| | #52 | ||
| Re: Replacing Rear Brake Pads Well guys did the pads today - boy did they need doing too! Originals after 44K..... And yes OK..................I would reccomend getting the FIAT tool.....got w*nkers cramp manually turning them darn rear calipers!!!!
| | #53 | ||
| Watch out when you do the rear pads. The tool can be made with bolts and plates but Fiat price is quite good as against LASER tool £20-£22 which may not quite fit. BUT BE CAREFUL NOT TO TURN THE WRONG WAY AND END UP WITH THE PISTON IN YOUR HAND. DOES ANYONE KNOW HOW TO GET IT BACK PLEASE?? THE HAND BRAKE CABLE SHOULD BE DISCONNECTED ACCORDING TO THE MANUAL - ( I HAVE IT ON DISC IF ANYONE NEEDS IY )
| | #54 | |||||
Good luck Barry
| | #55 | ||
| It's about GO! not SHOW! | Barry, Welcome ![]() Have a read through this complete thread - you should find it interesting ![]()
| Where to copper grease rear brake drums? | 4paws | Uno > Technical | 2 | 21-06-2006 16:50 |
| Rear brake pads | M@nticore | Uno > Technical | 5 | 10-06-2006 02:45 |
| Wanted: Uno turbo rear discs, pads, hubs and brake cable (Parts Wanted) | Firewarrior | For Sale / Wanted | 0 | 30-10-2005 08:22 |
| Brake Pads? | Ian_Dublin | Punto | 1 | 03-06-2005 00:31 |
| Rear disc pads. | cmk12342000 | Stilo > Technical | 3 | 21-10-2004 07:41 |
