| | #31 | ||
| Re: Replacing Rear Brake Pads Argo, can your dealer still get this tool? The ones near me are denying all knowledge of it
__________________ My Stilo Is Big And Black And Mine Fabbrica Italiana Automobili Torino | |||
| | #32 | ||
| It's about GO! not SHOW! | Re: Replacing Rear Brake Pads
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #33 | ||
| Re: Replacing Rear Brake Pads Ok, folks, I've read all the stuff about changing the rear brake pads and which tool I need to get. I've been quoted about £40 for discs and pads, and £10 for the wind back tool. A lot better than £120 at a local brakes, exhausts, etc, type centre. I've got the new discs fitted, the pads are in and I'm ready to put the caliper back on. Do the pistons simply re-seat themselves once it's all together again? I've done my front discs and pads, that was fun, undoing the bolts holding the caliper on! They were rock solid! I pulled muscles I didn't know I had that day! Anyway, advice please. Thanks Stilo 115 JTD, 5door, Scilla Red, with 76k on the clock and ready for a BIG service. (£650 locally!!!!)
| | #34 | ||
| Driver Extraordinaire | Re: Replacing Rear Brake Pads you have to wind the pistons into the calliper using the tool, then after all refitted, pressing the brake pedal will push them back out so pads are touching the discs. Hope this answers what you were asking?
__________________ ![]() 3 Door Sprint Blue JTD with Skyroof, 17 inch Fox R1 alloys,-30mm Eibach Springs, Boge Turbo shocks, OMP Strutbrace, Mattig Badgeless Grill, RED.DOT Grooved brake discs and pads RED.DOT RACING TUNED - to153BHP/201FTLB TORQUE | ||
| | #35 | ||
| The modfather | As Minimad said you have to wind in the pistons on the caliper on each side the [passenger side] anti clock wise and the [drivers side clockwise using the tool or what ever way you are going to use when you have the piston in the caliper wound back in you will see that the rear pad has little up stands that slot into the piston face [which have recesses] if my memory serves me well as I did it some time ago now ..you should be able to work it out from there
| | #36 | ||
| Re: Replacing Rear Brake Pads one garage told me if the pads are really worn, the piston can jam out meaning new callipers required- is this the case or just a scare story? Never seen it mentioned here
| | #37 | ||
| It's about GO! not SHOW! | Re: Replacing Rear Brake Pads Scare story I think you'll find. You'd have said goodbye to your discs long ago anyway ![]()
| | #38 | ||
| The modfather | Thats more of a Scorey than scary story tho Argo ![]()
| | #39 | ||
| | #40 | ||||||
| Back once again w'the... | Re: Replacing Rear Brake Pads
I've changed a few down-to-the-metal pads but, strangely enough, never in my own cars. I'd hope that most people would pay just a little attention to such things :shakehead It doesn't take much - one or two checks a year... -Alex
| | #41 | ||
| Re: Replacing Rear Brake Pads Thanks, that's what I wanted to know.
| | #42 | ||
| Re: Replacing Rear Brake Pads honest oppinion needed, is this procedure a bit tricky for someone without much knowledge? managed to do the front ones ok but this looks harder. considering getting a local garage to this one. cheers
| | #43 | |||||
| The modfather |
| | #44 | ||
| Re: Replacing Rear Brake Pads how much should i be looking at for rear disk and pad replacements? gonna ring round for a price but dont wanna get stung! cheers
| | #45 | ||
| The modfather | Cant quote for parts but I would give them around two and a half hours labour on top of the bits ..you can get a rough idea of disks and pads from ebay ..be warned though the mintex pads squeel like a stuffed pig if your getting those ..discs are very good quality tho
| Where to copper grease rear brake drums? | 4paws | Uno > Technical | 2 | 21-06-2006 16:50 |
| Rear brake pads | M@nticore | Uno > Technical | 5 | 10-06-2006 02:45 |
| Wanted: Uno turbo rear discs, pads, hubs and brake cable (Parts Wanted) | Firewarrior | For Sale / Wanted | 0 | 30-10-2005 08:22 |
| Brake Pads? | Ian_Dublin | Punto | 1 | 03-06-2005 00:31 |
| Rear disc pads. | cmk12342000 | Stilo > Technical | 3 | 21-10-2004 07:41 |
