| | #16 | |||
| The modfather |
| | #17 | ||
| Glutton for Punishment | Re: Rear Brake Pads Well I've just put Mintex on the back of the 1.6(5dr) and adjusted the handbrake cable as per FIAT's instructions, and it's so much better! Even my "It's only a car" mother agrees! The caliper-piston windback tool is great too, although the bolts are far too long, so you really need to hold it in place at the piston too. Job for tomorrow; fit new pads and discs to the front of mine. Going to do my rear brakes in the week.
__________________ 07 Bravo TJet Sport, Maranello Red Factory Options: Dual Zone Climate, 18" Alloys Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion | ||
| | #18 | |||
| The modfather |
| | #19 | ||
| It's about GO! not SHOW! | Re: Rear Brake Pads They seemed fine when I did mine Only problem I had was with the locking bolt (had to fit a shorter one) ![]()
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #20 | ||
| The modfather | | ||
| | #21 | |||
| Re: Rear Brake Pads
__________________ Phil Thomas Yellow Peril Then:Yellow Stilo 1.6 16V 3-door - not quite standard ![]() Now: Red Stilo Abarth Schumacher GP Prodrive | ||||
| | #22 | ||
| Glutton for Punishment | Re: Rear Brake Pads FIAT's Instructions say to adjust the handbrake as part of the procedure of replacing the rear brakes, which I followed, and was well worth it. Access to the adjustment nut is a bit of a nightmare, so I'll post up my version of the procedure later today.
| | #23 | ||
| It's about GO! not SHOW! | Re: Replacing Rear Brake Pads This is true as it makes winding back the pistons easier. However, you can do it without adjusting the handbrake cable as long as you make sure the handbrake is completely off. The handbrake is fully auto adjusting so even when moving from worn to new pads it will still find near enough the correct position. Quite important to keep an eye on the brake fluid reservoir though as it's likely to overflow if you're not careful.
| | #24 | ||
| The modfather | Re: Replacing Rear Brake Pads I disconected the handbarake cables copmpletely when doing the rear pads the first time but dont think they need to be really I use a hypo for sucking out excess fluid from the master cylinder tried it with a tube once and got a gob full of fluid YUCK LOL but at the time I didnt laugh ![]() | ||
| | #25 | ||
| Glutton for Punishment | Re: Replacing Rear Brake Pads Disaster strikes . . . Went to do my rear brakes today (then apart from fluid change all the brakes on both our Stilos are done ), did the drivers one no problem. Went to do the rear passenger, started winding the piston in, then without warning . . . SNAP.Eeek, so i took the tool out and it had snapped around the hole where the grub screw goes in. Now I'm left with a Stilo with no handbrake! Phoned the parts guy just now (2:15pm) who said, and I quote, "Those tools are sh!t anyway", and he's put another one on VOR (Vehicle Off Road). It's coming from Italy, will be in the UK at 0430 this morning, then at the dealer for 0900. Got to say, from Italy to Paignton in under 19 hours, not bad!
| | #26 | ||
__________________ | |||
| | #27 | ||
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic Last edited by Argonought : 18-05-2007 at 13:50. | ||
| | #28 | ||
| Re: Rear Brake Pads Many thanks chaps, done all my own brakes etc in the past.. ( want it done properly ) ,,,,but wow that turning to get brake cylinder back was new on me, but with all the advice on the forum, it's done, made a tool out of 6 mm bar, heated it up bent it in the middle, made a big U shape,,,, thanks again, Wireman1
| | #29 | ||
| Re: Replacing Rear Brake Pads Mmm, another job waiting to be done. It this tool any use? Only £6.67.
| | #30 | ||
| It's about GO! not SHOW! | Re: Replacing Rear Brake Pads Several members have used it OK but in my view not a patch on the proper Fiat tool ![]()
| Where to copper grease rear brake drums? | 4paws | Uno > Technical | 2 | 21-06-2006 15:50 |
| Rear brake pads | M@nticore | Uno > Technical | 5 | 10-06-2006 01:45 |
| Wanted: Uno turbo rear discs, pads, hubs and brake cable (Parts Wanted) | Firewarrior | For Sale / Wanted | 0 | 30-10-2005 08:22 |
| Brake Pads? | Ian_Dublin | Punto | 1 | 02-06-2005 23:31 |
| Rear disc pads. | cmk12342000 | Stilo > Technical | 3 | 21-10-2004 06:41 |
