The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo > Stilo > Technical
Old 07-07-2006   #1
tkmking's Avatar
Trader Rating: (0)
Engine Cover Tool
Hey guys and girls
I've tried searching the forum, but can't seem to find the name of the tool to remove the engine/battery cover...
Having had the car for a couple of months now, i'd like to remove the cover and have a general poke-about.
Does anyone know what the tool is, or where i can get one; or any botch alternatives?!
Thanks,
Rob
Running in a:
Broom Yellow 1.8 Dynamic - 3 Door
Mintex Brake pads all round; GMax springs, Sony Head Unit, Eagle F1 GSD3 tyres
Saving for: Side skirts/Upgraded shocks/Twin exhaust
Current problems: Slight Exhaust leak
tkmking is offline
Old 07-07-2006   #2
Trader Rating: (0)
Re: Engine Cover Tool
You need a Torx bit on the end of your screwdriver.
Fiat Stilo 1.6 16v Dynamic
Leather Interior, 16" Alloys
Connect Nav+
Cruise Control + Comfort Pack
myworlduk is offline
Old 07-07-2006   #3
popping out
dan-the-man's Avatar
Trader Rating: (0)
dan-the-man has donated! United Kingdom
I just use an allan key
dan-the-man is online now
Old 07-07-2006   #4
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
PNL has donated! United Kingdom
Cool Re: Engine Cover Tool
I was shopping ith the wife at Asda one day when I saw a set of 9 torx bits these though were alan key shaped and will offer you more leverage have a look at a branch near you to see if they have them and if i remember correctly you need the T45 one cheap to at £3.80p
PNL is offline
Old 07-07-2006   #5
popping out
Trader Rating: (0)
I just got a pair of pliars around the alan key for extra leverage
Old 07-07-2006   #6
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
Torx is sort of star shape Dan you could eventually naff up the torx head if your not careful torx set was cheap at £3.8op so get yourself one the covers are not the only thing you will need them for either
PNL is offline
Old 07-07-2006   #7
popping out
Trader Rating: (0)
I may invest in a set of those then I've only ever took the cover off once to have a gander.
Old 07-07-2006   #8
Whaddya mean too old?
Deckchair5's Avatar
Trader Rating: (0)
Deckchair5 has donated! United Kingdom
They're not done up too tight, it's plastic after all so I've managed easily with a correct fitting flat blade screwdriver up til now wthout needing to dive into the torx bits
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline
Old 07-07-2006   #9
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
Well mine had been done up by Samson no less and a flat blade would have definatly damaged the torx head
PNL is offline
Old 07-07-2006   #10
Deckchair5's Avatar
Trader Rating: (0)
Probably installed by a no brainer with an air gun and a new torx bit set for Xmas
It's only got to hold a bit of plastic to another bit of plastic
99 Bravo 1.2SX
Old 07-07-2006   #11
tkmking's Avatar
Trader Rating: (0)
Cheers guys, did think about torx, but was worried i might break something heh; will give the screwdriver and torx a go tomorrow, what's the worst that could happen eh?!
Running in a:
tkmking is offline
Old 08-07-2006   #12
popping out
Trader Rating: (0)
I had a look at mine today and i definatley have the torx ones on my battery cover but alan key ones on my engine cover
Old 08-07-2006   #13
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
Alan key ones on your engine cover Dan Here we go again first its the space saver and now its different bolts holding on the engine cover YES you've guest it I have 10mm bolts on mine
PNL is offline
Old 08-07-2006   #14
Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
Sorry for being 'nerdy' Phil but it's a T40
T14086 is offline
Old 08-07-2006   #15
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
Nitt picking again Eh
PNL is offline
vB code is On
Uno 1.0 ie. Smelly smoke and knocking noise. SilentPartner Uno > Technical 17 27-03-2006 16:00
Wanted: ROCKER COVER FOR A 1.1 SPORTING CINQ ENGINE (Parts Wanted) Rob_Randomcruisers.co.uk For Sale / Wanted 0 14-02-2006 23:39
Multijet available in the UK? blackJTD Stilo 20 19-01-2006 07:31
undetermined engine in a 81 Fiat Spider 2000 RESAT Spider 0 07-06-2004 08:33
Engine mountings/cam cover ! minislapper Uno 3 03-05-2004 02:11
