| Wheel Nuts ive just fitted some 16 inch alloys 215/40/16 to the stilo but im a bit concerened the bolts taken from standard wheels are not long enough not sure whats caused my concerns anyone any ideas or suggestns (cant spell wont spell) to what length bolts should be or from what model i can adopt some fromthanks ian
| | #3 | ||
| The modfather | I have a set of locking bolts here and just measured one for you its 25 mm in length from the base of the taper to the end the standard one measures 22mm its only 3mm I know but dont use them get the correct length and if you need lockers for your alloys the set I have are for sale PM me
| | #4 | ||
| Re: Wheel Nuts hi pnl wheels came with locking nuts but thanks all the same for the offer found these on ebay M12 X 1.50 (26mm long) 60 deg taper nuts about 21.00 pound in total for 16 not sure about the m12 x 1.50?
| | #5 | ||
| ate too much | Re: Wheel Nuts IIRC its a 12mm diamater and 1.5 thread p[itch.cant remeber but i think fiat use a 1.25 thread pitch
__________________ need to contact a mod? click me _need to contact admin? click me_FAQ's_ Guides_events ![]() Want +20BHP for £2? | ||
| | #6 | ||
| __________ | Re: Wheel Nuts
__________________ Binki | ||
| | #7 | ||
| Re: Wheel Nuts so if i order m12 .1.25 28mm this should be about right?
| | #8 | ||
| Re: Wheel Nuts You do know that your wheel tyre combo is much smaller than standard I assume?
__________________ Stilo JTD Active, 16" VT, Celtic remap, Eibachs, Mintex discs/pads, beam wipers, clear front indicators, Sony headunit Suzuki RGV 250N Gilera Runner 180 Puma Trainers | |||
| | #9 | ||
| Re: Wheel Nuts sorry cris i dont understand?
| | #10 | ||
| doM repuS | Re: Wheel Nuts Because standard 16s are 205/55/16s aren't they?
__________________ Electroclash Panda 100HP ![]() Red brake calipers - done / Red highlights on engine cover - done Red GSR kit - done / Red badges - done / Cobra springs - done ![]() ![]() | ||
| | #11 | ||
| Re: Wheel Nuts i dont know ? anyhow i called my friendly fiat dealer and computer said no only one type of bolt for the stilo whatever type of wheels you have?
| | #12 | ||
| Re: Wheel Nuts Put Abarth alloys on my Jtd and used same bolts, sure accessory brochure said same bolts used on all wheels, just need locking ones for security. Not had any problems so far but after reading this i'm slightly worried!
| Wheel nuts | StiloBoy | Stilo | 9 | 14-03-2006 18:45 |
| Wheel Nuts | minimad99 | Stilo > Technical | 5 | 27-05-2005 08:20 |
| 3 wheel nuts in all 4 wheels, is it safe? | spongmonkey | Cinq/Sei > Technical | 20 | 09-01-2005 23:14 |
| Sei Sporting alloy wheel nuts needed | andy279 | Parts Wanted | 2 | 05-08-2004 07:21 |
| new Wheel nuts for sei sporting | andy279 | Cinq/Sei > Technical | 1 | 21-05-2004 20:36 |
