The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 28-02-2004   #16
pjp
Trader Rating: (0)
Mine creaks on corners when its cold (below zero) - sounds as if the creaking is coming from near the passenger side A-post, but I've not investigated it yet
Paul
Stilo Abarth 3dr, Broom Yellow (Nov '03)
pjp is offline
Old 29-02-2004   #17
Italian Stallion
Trader Rating: (0)
twincamms has donated! United Kingdom
Mines not creaking, it sounds like a vibrating from behind the clocks.
FIAT Stilo Sport. Pretty Much Bog Standard Really. Rear Roof Spoiler,
Sill Protectors, Aluminium Foot Pedals, Eibach 30mm Drop Springs.
twincamms is offline
Old 01-03-2004   #18
Trader Rating: (0)
[quote]Originally posted by pjp
Paul
[When I had a three door Stilo it used to creak from the A pillar when cornering. One day when cleaning the car I noticed if you pressed on the front wing where it meets the A pillar it made the same noise. I sprayed the bolt behind the wing with WD40 and it stopped. although it came back after about a month so I had to do it again. It's never happened on my 5 door though.
2002 1.6 Dynamic 5dr. Steel grey./quote]
stiloactive is offline
Old 15-03-2004   #19
KK1
Trader Rating: (0)
KK1 has donated! United Kingdom
Hi all im a new forum user, had my Abarth since may 2002 and had the same creaky dash prob the dealer couldnt sort it,
I found the problem after hours of driving over speed bumps, its the front passenger side pillar, my solution was to take off the pillar trim and spray lots WD-40 through the many holes along the pillar.
Hope this helps a few people.
kk
KK1 is offline
(S) FAQ - Dash Switch Illumination Little Red Devil Cinquecento / Seicento 21 02-11-2007 18:34
(G) Dash lights CHARLIE-CINQ Cinquecento / Seicento 17 25-12-2006 01:35
(S) Dash Switch Illumination arseofbox Cinquecento / Seicento 18 30-04-2004 06:15
(T) removing the dash jmarson Cinquecento / Seicento 10 30-03-2004 01:19
(T) Dash problem RoadRunner Punto 2 18-02-2004 00:40
