| Free dentistry available | Stilo Wheel alignment... When my car was lowered they tracked it at the same time, this was done at a motorsports garage that actually sell tyres too, but even they said it idealy needs to be done by computer tracking and they recommended a place called Christchurch tyres because they had all the right equipment and their ramp was suitable for a lowered car. I didn't bother at the time because I thought they were being perfectionists and I couldn't be arsed to go anywhere else. My car felt a little bit odd, it was pulling strongly to the left but I ignored it for a while. I then had the tyre wear problem so I got Fiat to look at it and they tracked it at the dealers, but my car was still pulling left, I took it back to Fiat, they looked at it and said it was tracked perfectly. I then took it to christchurch tyres who stuck it up on the ramps and aligned the wheels using computers and gave me a readout at the end. The wheels were WAY out of alignment. As soon as I got back in the car it felt unbelievably stable at low and high speeds.. Taken Directly from the christchurch tyre website.. http://www.christchurchtyre.co.uk/ What Everyone Should Know About Total Wheel Alignment On this vehicle, the front wheels are not aligned to the rear thrust line. This can happen from normal wear and stress, whether your vehicle has adjustable or non-adjustable rear suspension. To steer straight ahead, you would have to steer the front wheels slightly to the right. A common result would be that the vehicle would "dog track" and possibly pull to one side.Of course, the angles are exaggerated so you can more easily see the condition. But it takes only a small misalignment to create problems. Why Four Wheel Alignment? Reduced Tyre Wear Improper alignment is a major cause of premature tire wear. Over the years, a properly aligned vehicle can add thousands of miles to tyre life.Better Fuel Consumption Miles per gallon/litre increase as rolling resistance decreases. Total alignment sets all four wheels parallel which, along with proper inflation, minimises rolling resistance.Improved Handling Does your car pull to one side? Does the steering wheel vibrate? Do you constantly have to move the steering wheel to keep your car traveling straight ahead? Many handling problems can be corrected by total alignment. With all the system components aligned properly, road shock is more efficiently absorbed for a smoother ride.Safer DrivingA suspension system inspection is part of our alignment procedure. This allows us to spot worn out parts before they cause costly problems. Here's What We Do: For vehicles with non-adjustable rear suspensions ![]()
Q. How important is wheel alignment?A. Think of it this way. Research indicates that the average car is driven about 12,000 miles per year. A car with toe alignment just 0.34 degrees (Just 0.17 inches) out of specification has dragged it's tyres sideways for more than 68 miles by the end of the year!!Q. What are the "symptoms" of wheel alignment.A. Have your car checked if you notice any of the following:
-------------------------------------------------------------------------------------------- Here's the before and after wheel alignment readout I was given... The link below with the red Toe alignment is the one before it was done so there was quite a difference considering it had just been tracked at Fiat before this, it shows it needs doing properly. I left both pictures as large as possible so it was easier to read the numbers. Before it was computer aligned After it was computer aligned
__________________ ![]() Last edited by Koa : 28-11-2005 at 14:22. | ||
| Hi mate, I had exactly the same thing done earlier this year. I gave up on fiat as they said it was perfectly tracked with 4 wheel laser alignment! So I took it to a local specialist alignment place in Perivale, London. The difference it made was amazing cornered better and felt much smoother, and it corrected the steering wheel as it was skew. When It comes to the tyre problem FIAT DO NOT HAVE A CLUE, take it to an independent specialist and send the bill to Fiat UK.
__________________ KK | |||
| | #3 | ||
| Free dentistry available | Re: Stilo Wheel alignment or something :) Hiya KK1. It was your original recommendation that made me enquire into this in the first place after I discovered I had tyre wear problems, I did mention on the other thread that you had got yours seen to at a specialists too so cheers mate But no sign of uneven wear now and I'd be very surpised if it comes back without me noticing because the car feels so much smoother and like you say it corners better too.
__________________ ![]() | ||
| | #4 | ||
| Re: Stilo Wheel alignment or something :) I got through 3 sets of fronts in 15000m! Make sure you send the bills for your tyres and alignment to fiat uk with a stern letter, and also mention trading standards as they supplied a car with incorrect steering settings.
| | #5 | ||
| Free dentistry available | Re: Stilo Wheel alignment or something :) Problem is, the wheels camber is altered from lowering the car, therefore Fiat are under no obligation to refund any money or replace the tyres, so I didn't bother myself as I replaced my wheels and tyres with 18's. My car being a 54 plate was apparently not at risk from the uneven tyre wear problem as it was fixed on the newer Stilos and the only reason mine was out was from the lowering.
| | #6 | ||
| Re: Stilo Wheel alignment or something :) does anyone no how much this costs?? think mine needs doing as its lowered and my tyres dont last long on the front :-(
__________________ 05 broom yellow stilo abarth (manual) now for sale......... check out the classifieds section for a bargin | |||
| | #7 | ||
| Re: Stilo Wheel alignment or something :) Ah a subject close to my wallet... TOO CLOSE! Bought my Stilo with 15K and had a 4 wheel alignment done soon after getting it (May '05) at tyre place I have used for tyres/alignment last 15 years. Just dad it done again (Nov/30K) as front anti roll bar links shot and rears wearing outer edges... due to rear track being out Price usually £30-£40 but worth it as quality tyres in any stilo size not cheap... local Fiat Dealer ok, did repair and subbed tracking out to specialist... MUCH BETTER NOW Usually get my 4 wheel alignment checked every 6 months... So much revenue Mr Brown and soo little investment in Highway Maintainence (don't get me started )
| | #8 | ||
| Re: Stilo Wheel alignment or something :) Does anyone know of a full wheel alignment place in manchester? As ive been looking around but cant find anywhere. Ive found a place in liverpool and one in nottingham...
| | #9 | ||
| Fiat; Fun not function | Hi, noticed a lot of concerns over tyre wear on earlier stilo's but not so much on the later ones. Ok,KoArAnG says it doesn't affect 54 plated cars but I just wandered if this is the case or some are luckier than others. Thanks.
| | #10 | |||
| It's about GO! not SHOW! | Re: Stilo Wheel alignment or something :)
).It's not that expensive anyway - about £13 for mine ![]()
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | |||
| | #13 | |||
| It's about GO! not SHOW! | Re: Stilo Wheel alignment...
| | #14 | ||
| Re: Stilo Wheel alignment or something :) I recently noticed a mild juddering at speed, especialy when accelerating and it was particularly bad at 90+. This occured in the cars 4th year. I could be driving comfortably at 80 but when I accelerated the juddering started and eased off when I stopped accelerating. Only ever noticable on motorways/dual carriageways. I noticed uneven wear on my front tyres, 2mm less on the inside of one and they did seem to wear quicker. The tracking was out by almost 2% at the front and 1% at the back. After the tracking wasorted the juddering disappeared completely and the car seemed more responsive, hard to quantify how much but noticable. At the next MOT one of the front wheel hubs needed replacing though I'm not sure if this is related. My stilo has done abou 35k.
__________________ Mike Stilo Active 5 Door JTD (115bhp) | |||
| | #15 | ||
| Paparrazi | Re: Stilo Wheel alignment or something :) Hmmm. I'm on my second Stilo now, purchased in Sep 2004, therefore 54 plate. I am now experiencing pretty awful tyre wear problems - the insides of my tyres (215/45/17) wore very quickly. I think this last set lasted about 8000 miles before they were illegal ![]() I've just replaced them and had the tracking checked and suitably adjusted by National Tyres who I have a good relationship with. It was out, but not massively. Therefore, just what is causing this pattern of wear ? At my last service at JCS Kegworth, I queried this and it was taken up with Fiat's area manager who seems as much use as a chocolate fireguard - he basically doesn't want to know and won't entertain any contribution towards tyre replacement costs. This despite tacit acknowledgement by the service technicians that they've seen this problem before on Stilo's. So, just what do I do about it, to prevent my car trashing this current pair of front tyres in a few thousand miles ?
__________________ -- Neil Barker Techno Grey 3dr Abarth Selespeed. Sadly, I am unable to recommend Sunwin Fiat Derby due to my experiences there | ||
| Thessaloniki Greece Stilo Meeting Pics | john_stil | Stilo | 20 | 03-07-2007 22:16 |
| Repossesed STILO :( | 1.8Stilo | Stilo | 59 | 23-12-2005 20:38 |
| fiat stilo great review | Legsakimbo | Stilo | 29 | 01-11-2005 18:59 |
| Stilo 2.4 GT? | BrianK | Stilo | 9 | 28-01-2005 22:42 |
| Stilo 140 multijet? | driver33 | Stilo | 7 | 19-05-2004 00:48 |
