| Paparrazi | Tyre wear again Looking at my tyres today (215/45/17 on my Abarth), they're pretty much worn down on the inside and will need replacing pretty soon. Now this may be a tracking issue, but I do wonder about the dreaded suspension issue. Mine's a later model Stilo and I was under the impression this was essentially cured on 54 models etc. The present fronts are Avon ZZ3 and I'm not at all impressed with their wear - they're only 7000 miles old and on the part of the tread that's not wearing due to tracking etc, they're down to about 3mm at best. Any suggestions as to this suspension issue ?
__________________ -- Neil Barker Techno Grey 3dr Abarth Selespeed now replaced by a 2008 Toyota Avensis TR 2.2TD Sadly, I am unable to recommend Sunwin Fiat Derby due to my experiences there | ||
| Whaddya mean too old? | Re: Tyre wear again Besides wearing your tyres out, I'd be pretty cheesed at the lack of grip as you're skating on only half your tread. It's almost always tracking so have you had your wheels tracked accurately and reliably recently? Bear in mind the figures they originally gave for Stilos has been amended I had track rod end shot to pieces when I bought mine, the front wheel was actually waggling about and it still wasn't burning off the tread irregularly so the tracking has got to be way off to burn tread like you're experiencing or, less likely, you have major suspension/steering alignment problems
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 22-10-2005 at 19:15. | ||
| | #3 | ||
| Re: Tyre wear again If the part of the tyre that is not worn is down to three millimetres in 7000 miles, then you are driving fairly hard, new tyres generally have between 7 and 8 mm of tread and the legal minimum is 1.6mm over the central 75% of the tyre, the outer 12.5 % on each side of the tyre is allowed to be bald. It sounds like you could have an issue with tracking but the wider wear may just be down to driving style etc. Get a good four wheel alignment done. I have Goodyears, the same size on my JTD and they have about 6 mm left after 7k miles.
__________________ NumanR | |||
| | #4 | |||
| It's about GO! not SHOW! | Re: Tyre wear again
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | |||
| | #5 | ||
| Re: Tyre wear again My 04 1.4 only has the wear on the inner drivers wheel, but it falls outside the 75%, in that 75% area I have about 5-6mm on inside. The outside 1cm is down to about 2 to 3mm. This is now at 14k.
| | #6 | ||
| Join Date: Jan 2004 Location: Fife, Scotland, United Kingdom.
Thanks: 0 Trader Rating: (0) | Re: Tyre wear again I've done 22,000 on a set of 15" Dunlops! Rotated the tyres at about 16,000miles. 3mm on the back, and 5mm on the front! Plenty to get me through the winter, and finally get my alloys on in the sprint. I was looking into the Avon ZZ3's, so your not happy with wear rate, but they are softer compound tyres, but whats the grip like? and do they sound pretty quiet? (thats one of their design point)
__________________ 53 plate, Stilo 3-door, Sassy grey, 17" Claw Alloys, Falken Ziex Z512 tyres, 1.2 Active -- 45mpg! | ||
| | #7 | |||
| Paparrazi | Re: Tyre wear again
I genuinely though, do not hammer my car/tyres and I'm not at all impressed with their wear rate. These tyres are knackered because of the tracking issue, but if that hadn't happened then they'd still be worn out in about another 3-4000 miles, giving a lifespan of just over 10,000 miles. I'm looking into a pair of Kumho tyres now, having read very good write-ups about them in their sector.
__________________ -- Neil Barker Techno Grey 3dr Abarth Selespeed now replaced by a 2008 Toyota Avensis TR 2.2TD Sadly, I am unable to recommend Sunwin Fiat Derby due to my experiences there | |||
| | #8 | ||
| Whaddya mean too old? | Re: Tyre wear again If you've only got a third of your tyre in contact with the road then it's going to wear out 3 times faster than normal. It's probably nothing to do with your driving style. Where you've lost 5mm on one side in 7k miles should have been 1.6mm across the whole tread in 7k miles which puts you in the "more acceptable wear" band
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 24-10-2005 at 09:19. | ||
| | #9 | ||
| Paparrazi | Re: Tyre wear again As an update, I had my car's tracking done today - both front wheels pointing outwards dramatically. Thanks crap roads / speed bumps ![]() Also, when I was looking around for tyres at my usual source (http://www.mytyres.co.uk) I also had a look on Ebay - go to the automotive section and enter your tyre size, eg 215/45/17 and you might be amazed at some of the deals to be had. Got two Kumho tyres in the aforementioned size for 115 quid plus 12 quid delivery. Only took a day to arrive, too.
| | #10 | ||
| Whaddya mean too old? | Re: Tyre wear again Good stuff! Did you have any trouble finding someone to fit them? Some places here charge £35 per wheel for fitting our size tyres
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 27-10-2005 at 08:03. | ||
| | #11 | ||
| All Hail the Woodsman | Re: Tyre wear again Kumho = budget tyre hence the price. My experience of them is not good in comparison to a quality michelin, bridgestone etc....
__________________ Fiat Bravo T-Jet Sport / Strada 130TC (currently undergoing restoration) www.strada130.com | ||
| | #12 | |||
| Re: Tyre wear again
The only problem with having such worn ones on the back is the lack of grip they'll have in the snow compared to the fronts. The back of mine actually got blown off course by a gust of wind last winter while driving down a perfectly straight piece of road that had a light covering of snow. Since I was driving quite quickly (about 70ish) I got a fairly massive fright and 2 new tyres (and new pants ) ASAP after that
__________________ 2003 Fiat Stilo Multiwagon JTD Dynamic 1999 Fiat Coupé 20 valve turbo 1992 Mitsubishi Shogun TD 7 Seater | ||||
| | #13 | ||
| 5vp3r m0d | Re: Tyre wear again Indeed - and one reason why if I was to get 2 new tyres on the car due to fronts being worn down, I would move the backs to the front and put the new tyres on the rear... As for tyres branding - stick with quality! I use Bridgestones on mine, and Michelins on the Ulysse
__________________ Electroclash Panda 100HP ![]() Red brake calipers - done / Red highlights on engine cover - done Red GSR kit - done / Red badges - done / Cobra springs - done ![]() ![]() | ||
| | #14 | |||
| | #15 | |||
I don't detect any grip difference so far between them and the Avon's I had on before and I have no intention of potentially spending 120/tyre on the likes of Michelins.
| | fiatranger | Stilo | 8 | 08-10-2005 20:55 |
| Tyre Wear - Again! | VillaBadger | Ulysse | 18 | 24-08-2005 11:27 |
| Uneven Tyre wear on New style Ulysse | Pat H | Ulysse | 15 | 04-03-2005 13:06 |
| | cmk12342000 | Stilo | 4 | 10-01-2005 18:26 |
| | pugwash | Stilo | 1 | 02-05-2004 00:00 |
