| | #121 | |||
| Glutton for Punishment | Re: cruise control
__________________ 07 Bravo TJet Sport, Maranello Red Factory Options: Dual Zone Climate, 18" Alloys Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion | |||
| | #122 | |||
| Join Date: Aug 2003 Location: Fife, Scotland, United Kingdom.
Thanks: 0 Trader Rating: (0) | Re: cruise control
Not looked in the engine bay yet though.
__________________ Scorg 01 Brava 80SX - Ink Black 02 Stilo Dynamic 1.6 - Sky Blue 03 Punto 60 Active - Silver Blue Last edited by Scorg; 18-03-2006 at 08:19. | |||
| | #123 | ||
| Glutton for Punishment | Re: cruise control Erm no, ours had the connector behind the steering wheel, although it was well hidden . . .
| | #124 | ||
Thanks: 0 Trader Rating: (0) | Re: cruise control I might just have a good look for it myself, was my dad that done it last time. That and i'll check the Chassis number in the morning/afternoon
__________________ Scorg 01 Brava 80SX - Ink Black 02 Stilo Dynamic 1.6 - Sky Blue 03 Punto 60 Active - Silver Blue | ||
| | #125 | ||
| Glutton for Punishment | Re: cruise control Ok, can't see why it should't be there, although my 03 1.8 has it and rob's (1.8 Stilo)'s doesn't!!
| | #126 | ||
| Re: cruise control hi ive got a 1.6 and already have the plug.what if any alterations had to be made to the cover to attach the new stalk
__________________ stillo 1.6 | |||
| | #127 | ||
| Glutton for Punishment | Re: cruise control Well if you get a FIAT stalk (only available as a complete £180 unit) then all you need is a new lower steering shroud. If you get the ALFA stalk (£35), you'll need to modify the new shroud. Just needs a bit of filing I believe . . .
| | #128 | ||
| Re: cruise control its only a slot about an 1" deep and half an inch wide
| | #129 | ||
| Re: cruise control right...i am digging this one up...!! 2day i (fiat garage) followed the instructions given i connected the the brown connector to the cruise control (from an alfa)..(mine is a 1.6 03 stilo)....they checked the brake an clutch pedals and said they are ok to fit the cruise control.... after we finished, SADLY NOTHING HAPPENS when playing with the cruise control.......!!!...they followed the wiring that rrope said.... any clues why???PLZZZZZZZZ help...
__________________ stilo 1.6lt 16vT and a whole page of xtras.....! | |||
| | #130 | ||
| Re: cruise control you seem like you've gone through the same sernario as me, unfortunetly i am not able to help.. But ive done the same on the brake and clutch pedals and still nothing and everything is wired up correct so im jus stumped really... ive given it a rest atm to get on with otha modifications!
__________________ Grande Punto Sporting 1.9 8v Mjet - GSR Stilo 1.8 16v 155.9Hp - Kawasaki Z1000 ![]() | |||
| | #131 | ||
| Re: cruise control i had a chat with an other stilo owner.... he said that all 03 and back stilos do have the ecu programmed for the cruise control but there is also a plate (the actual cruise control unit) that should connect to the brown connector...this costs about 270Euros....i don't know if that is true... Rrope....did u actually make it work on a 1.6 stilo connecting just the brown connector to the cruise control stalk???
| | #132 | ||
| Re: cruise control THE BLOODY THING FINALY WORKED...... (i am so happy i wanted to share it with you )i wanna thank rrope...if it wasn't 4 his post, i wouldn't even think, to try it on! ( i folllowed the instructions on page 5 (brown connector)..Luckily my 03 1.6 had the apropriate swiches on the brake and cluch pedals)
__________________ stilo 1.6lt 16vT and a whole page of xtras.....! Last edited by face; 19-05-2006 at 09:34. | |||
| | #133 | ||
| Glutton for Punishment | Re: cruise control Ah ha! ![]() So face, what was the final step that made it work? The other end of the brown connector goes to the Engine Node; without that your car isn't going anywhere! I've checked the switches on ePER and there is no difference between Cruise and non-Cruise equipped vehicles!
| | #134 | |||
| Re: cruise control
....really it is pretty straighforward...searching in the fiat cds i discoverd these....the whole cruise control wiring diagram...hope it 'll help anyone that is still trying..!! ![]() ![]() it clearly shows that the cruise signal initiates from M10 (control unit) and through D4(B)-brown connector [D4(A) is on M10] it ends at H7 (fiat or alfa stalk-it is exactly the same as rrope' already said )...!!!!1.8 stilo check your connections again..
__________________ stilo 1.6lt 16vT and a whole page of xtras.....! Last edited by face; 19-05-2006 at 13:58. | ||||
| | #135 | ||
| Re: cruise control This mod is one I'd like to do, and I think there's a good chance that my 04 plate 1.6 MW is predisposed to the fitting of cruise control, since it is offered as an optional extra ( I've yet to check this out ). My question is does fitting this affect the warranty in any way ?. TIA
__________________ Jack | |||
| | Rich | Stilo | 3 | 12-01-2004 00:45 |
| cruise control help | jamesant | Ulysse | 9 | 05-01-2004 19:50 |
| | Obie | Stilo | 5 | 28-12-2003 00:46 |
| | 4452valp | Stilo | 8 | 21-11-2003 00:37 |
| | mossy | Stilo | 4 | 01-10-2003 20:41 |
