| | #31 | ||
| Glutton for Punishment | Re: After market Cruise control Don't think the Student Loan will stretch to another £200, but it would be cool, seeing as I'm always up and down the M5 going from Uni (Warwick) to home (glorious Torquay). EDIT: Pretentious comment removed ![]()
__________________ 07 Bravo TJet Sport, Maranello Red Factory Options: Dual Zone Climate, 18" Alloys Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion | ||
| | #32 | |||
I'm not so sure about this now, might be a bit beyond me.
__________________ Fiat Stilo 1.9 JTD, 5 Door, Dynamic, Sky Roof | ||||
| | #33 | ||
| Glutton for Punishment | Re: After market Cruise control Did anyone actually ever retrofit the Cruise Control column stalk and get it working??
| | #34 | ||
| Glutton for Punishment | Re: After market Cruise control Well I did and it works . My car was predisposed as it has ESP, so the connector was already there! The only problem is is that the light on the dash won't come on; my local FIAT garage plugged the Examiner in, and they forced the light to come on, but it won't go on with the program. Apart from that it all works fine. Anyone (i.e. a Tekkie) know what menu on the Examiner it's in?
| | #35 | ||
| Re: After market Cruise control how much did the stalks cost you
| | #36 | ||
| Glutton for Punishment | Re: After market Cruise control £15.51 including postage Got them off ebay though so chances of them reappearing are slim. However, the Alfa 147 stalk may work as it's the same connector and looks like the same fitment to the stalk controls, and thats £40. Is SLIGHTLY different in shape so can't guarntee the fit on the plastic shrouding. Although it depends if your car is prewired; apparently all Stilo's fitted with ESP are, if not then you'll have some wiring to do!
| | #37 | ||
| cruise control hi guys iv just aquired the above (genuine fiat) i have looked behind my steering colum for the connecter for the cruise control and it is not there. i was wundering if any 1 had traced the wires from the connecter to see were they go and if it would be posible to run new wires so i could fit thanks stripey
| | #38 | ||
| Glutton for Punishment | Re: cruise control
| | #39 | ||
| | #40 | ||
| Re: cruise control yep got that wat next
| | #41 | ||
| Whaddya mean too old? | Re: cruise control Emigrate to a country with straight roads, no road works or traffic lights so you can use your cruise control ![]()
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX | ||
| | #42 | ||
| Glutton for Punishment | Re: cruise control Ok next step is to feed a wire from the steering column into the engine bay near the battery compartment. There is a bulkhead wire conduit on the drivers side A-Pillar I believe. The wire will be need to be 4-pin (2 sets of speaker cable should be ok). Please let me know your engine cc so that I can give you the correct pin out configuration! Ta!
| | #43 | ||
| Re: cruise control its 1.4
| | #44 | |||||
| Re: cruise control
| | #45 | |||
You can either chop the connector off (as long as it only has 4 wires going in, there isn't any other useage for it), or wire in-line to keep the original (yet useless) wiring in tact. The connections are as follows: D4B (Brown Connector) ------> H7 (Cruise Control Stalk) Pin A02 ------> Pin 1 (Green) RESUME Pin A03 ------> Pin 6 (Orange/White) SPEED -VE Pin A04 ------> Pin 5 (Orange/Black) SPEED +VE Pin A05 ------> Pin 4 (Violet) ON/OFF Remember: The pin out diagrams for D4B are for the non-existent connector that would go into D4A (D4A is the one on your car). Although its damned obvious: the row with the wires is obviously Row A, and there is one pin not-connected (A01), then moving along the next 4 are connected, so A06 to A08 are also not connected. All you need to do then is connect Pin 2 of the Cruise Control Stalk (Blue) to a +12V feed. Let me know how this goes; am thinking of making up a guide, who knows!
__________________ 07 Bravo TJet Sport, Maranello Red Factory Options: Dual Zone Climate, 18" Alloys Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion Last edited by Rich : 13-02-2006 at 01:35. | |||
| Active (Radar) Cruise Control & Easy-Go | Rich | Stilo | 3 | 11-01-2004 23:45 |
| cruise control help | jamesant | Ulysse | 9 | 05-01-2004 18:50 |
| Cruise Control | Obie | Stilo | 5 | 27-12-2003 23:46 |
| cruise control ,aftermounting | 4452valp | Stilo > Technical | 8 | 20-11-2003 23:37 |
| Cruise Control | mossy | Stilo | 4 | 01-10-2003 20:41 |
