The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo > Stilo > Technical
Old 29-05-2008   #241
Trader Rating: (0)
Re: After market Cruise control
The only one I could find on the german ebay was a a starting bid of 79 euro plus postage if it is the one you spotted , compare that to the alfa stalk of £40 new at the most, I think the alfa one I have fitted does not look out of place and does just the same as the standard stilo cruise stalk, plus even if you get the origenal stilo stalk you still have the lower shoroud to sort out which ever you choose between the alfa or stilo stalk,,,still they do seem to have a lot more service items for the stilo on the german ebay guess if I could read german that would help or I would just end up buying a packet of german sausage without even knowing about it.
mhowse is offline
Old 30-05-2008   #242
wotnowarninglight's Avatar
Trader Rating: (0)
Ordered the 147 stalk Wednesday and it came today, cost 49 odd quid.
Plug & Play on mine... makes one hell of a difference
Only wish I had done this a whole lot sooner...
Black 115 JTD, 15' Steelies with Doblo trims & debadged
+147 Cruise Control NOW with added Millers Diesel Power Sport 4
wotnowarninglight is offline
Old 31-05-2008   #243
EgyTuner.com...
OzMoSiS's Avatar
Trader Rating: (2)
OzMoSiS has donated! Egypt
i took off both cowlings the other day and had a damn good look for the 3rd time, and again no luck.
so looks like its going to have to be wired in. i've got some nice 7 core trailer board wiring which is perfect, only problem is to get to either the engine node or the plug under to fusebox, wire up to it, and run the cable to the steering column.
Originally Posted by dan-the-man View Post
i only have one nipple
OzMoSiS is offline
Old 31-05-2008   #244
lifeline's Avatar
Trader Rating: (1)
Anyone know of an Abarth being broken at the moment where i can source a cruise control stick?
lifeline is offline
Old 31-05-2008   #245
Trader Rating: (0)
Netherlands
i have a brand new original one for the Stilo for 99 euro (79 pound) plus shipping costs from the Netherlands to UK...
just PM if interested...
yellowstilo is offline
Old 25-08-2008   #246
HFStuart's Avatar
Trader Rating: (0)
In case any of you would like to try this with Stilos that haven't had all the nice bits costed out by accountants (Guess whose 54 plate Dynamic isn't even partially wired....)
This http://www.fiatforum.com/auction-wat...ml#post1690197 is now surplus to requirements.
Stuart
HFStuart is offline
Old 30-08-2008   #247
Trader Rating: (0)
Hi!
I can't find brown connector in batery bay. Where should it be mounted? Any tips? Is it coonected to sth or just put freely?
Are all Stilos prepared to installation the cruise control?
Where is the engine node required when no connector under wheel and no brown connector in battery pack.
Regrads,
Slavomir
slavomir is offline
Old 3 Weeks Ago   #248
Trader Rating: (0)
This is a great guide. Just retro-fitted cruise to my Schumi and it went like a dream. A couple of extra tips:
1. To ease access for tightening the screws securing the stalk to the column, turn the steering wheel so that the large space in the top of the wheel is opposite the area you want to access. Gives you much more room to work. Same things applies to refitting the lower half of the steering column shroud. Much easier to do with the steering wheel turned 180 degrees from the straight ahead.
2. The part number for the plastic cover shrouding the steering column which has been pre-cut for the cruise stalk is F07353069997.
Phil Thomas
Yellow Peril
Then:Yellow Stilo 1.6 16V 3-door - not quite standard
Now: Red Stilo Abarth Schumacher GP Prodrive
Yellow Peril is offline
Old 3 Weeks Ago   #249
Trader Rating: (0)
P.S There's more info on retro-fitting cruise here:
http://www.alfaowner.com/Forum/alfa-...ive-guide.html
It's a long thread, but there are some useful extra bits of info and a couple of exploded drawings.
Phil Thomas
Yellow Peril
Old 1 Week Ago   #250
Stilatos's Avatar
Trader Rating: (0)
Greece
Guys i have a question i was looking if my car is prewired with the connector on the steering column and i found this
Is this the connector for the cruise control? i have a feeling that it is but the connector is different because i remember some time ago the idiots at the garage changed the wiring in the car cause they believed it was faulty cause of the airbag problem and i have a feeling the electrician put this connector instead of the white one. If not than anyone have any idea what the heck this is?
1.6 silver dynamic 3d with skywindow, Schumacher Look, Abarth Pedals,Brembo Brakes,Bilstein Eibach Suspension, Eagle F1 Tires, K&N Filter,Sport Steering Wheel,Sport Knob,3M tint.Philips New Vision Lights. Founder & Admin of the Greek Stilo club www.stiloclub.gr
Stilatos is offline
Old 1 Week Ago   #251
Trader Rating: (0)
Don't know what that is, but I can tell you the connector on the cruise stalk won't fit that block. Sorry.
Phil Thomas
Yellow Peril
Old 1 Week Ago   #252
Stilatos's Avatar
Trader Rating: (0)
Greece
anyone? where are the elearn gurus to give a helping hand?
Stilatos is offline
vB code is On
Active (Radar) Cruise Control & Easy-Go Rich Stilo 3 11-01-2004 23:45
cruise control help jamesant Ulysse 9 05-01-2004 18:50
Cruise Control Obie Stilo 5 27-12-2003 23:46
cruise control ,aftermounting 4452valp Stilo > Technical 8 20-11-2003 23:37
Cruise Control mossy Stilo 4 01-10-2003 19:41
