The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 12-09-2005   #1
Big Black Stilo's Avatar
Trader Rating: (0)
Changing front pads
Is this dolly dimple?
anybody got a guide?
I previously used haynes books but there isnt one for the stilo.
IMPORTANT ANNOUNCEMENT!!!
Fabbrica Italiana Automobili Torino
Big Black Stilo is offline
Old 12-09-2005   #2
__________
dave's Avatar
Trader Rating: (10)
dave has donated! Saint Kitts and Nevis
Re: Changing front pads
be same as other cars, rember cooper slip on moving bits and thread lock on caliper bolts
Binki
dave is offline
Old 12-09-2005   #3
5vp3r m0d
Stu DemonD's Avatar
Trader Rating: (1)
Stu DemonD has donated! United Kingdom
I am sure Rich Chromegrey did his recently.
Electroclash Panda 100HP
Red brake calipers - done / Red highlights on engine cover - done
Red GSR kit - done / Red badges - done / Cobra springs - done
Stu DemonD is offline
Old 12-09-2005   #4
All Hail the Woodsman
thepottleflump's Avatar
Trader Rating: (0)
thepottleflump has donated! United Kingdom
Piece of p. Remove 2 caliper bolts, slide caliper off, remove old pads (remove wear indicator wire where fitted), fit new pads, slip caliper back on and screw bolts back in.
Fiat Bravo T-Jet Sport / Strada 130TC (currently undergoing restoration)
www.strada130.com
thepottleflump is offline
Old 12-09-2005   #5
Trader Rating: (0)
Yes it is easy, I changed the front pads on my 02 1.6 yesterday and it took me about 20 - 25 mins altogether and I am not quick.
Push the piston back into the caliper, undo the two bolts on the rear of the caliper and pull out the centre section then pull the pads out along the grove housing them. Fitting new pads is the reverse of removing them.
There is a sensor in one of the N.S. pads for the pad wear warning light. This fits onto the caliper at the connector by pushing over a piece of metal, you release this by pulling the connector upwards off the metal and seperate the two wires.
I used Ferodo pads and these were slightly different to the pads I removed as there were two small studs protruding from the back of the pad and the position of these studs was different depending on whether the pad fitted against the piston or not, it is easy enough to work out which pad is which. New bolts complete with thread lock came with the pads.
Chris
cmk12342000 is offline
Old 12-09-2005   #6
Trader Rating: (0)
Sorry about posting when the topic had already been answered, I took a phone call after starting to answer and posting and the other reply came in between
Chris
Old 12-09-2005   #7
Trader Rating: (0)
cheers guys
Just wondering, i have found some pads at a reasonable price, £17, but i dont know what make they are. The place came reccomended by a couple of mates who work in garages. Is it likely this is going to seriously effect the braking of the car?
Old 13-09-2005   #8
Peek a boo!
SLOVAC's Avatar
Trader Rating: (0)
SLOVAC has donated! South Africa
Dunno... depends on the pad. Personally I would rather pay extra for the recommended pads as braking is an essential safety feature
Wouldn't want some cheap pad to fail just when you really need them...
SLOVAC is offline
Old 14-09-2005   #9
Glutton for Punishment
Rich's Avatar
Trader Rating: (1)
Rich has donated! United Kingdom
Changed mummie's a month ago or so. The best bet is to get the originals from shop4parts.co.uk. These come with new metal clips that sit on the caliper to retain the pad; i've never seen them before, but it's probably best to replace them as they'll get bent out of shape and not be as tight (hence you'd get brake shudder).
Plus they have proper FIAT instructions in them, and I think they were about the same price (if not just a bit more) than I could get a set from halfrauds.
07 Bravo TJet Sport, Maranello Red
Factory Options: Dual Zone Climate, 18" Alloys
Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates
Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion
Rich is offline
Old 14-09-2005   #10
Trader Rating: (0)
Thing is I have used cheaper pads on different cars and not notice any real difference, never had em fail. when i mean cheap i mean £8 for a full set of front pads for a seat ibiza.
Looked at getting parts on the net but because of the weight its cost a lot to post and therefore means I might as well get them from fiat for £39
Old 14-09-2005   #11
__________
dave's Avatar
Trader Rating: (10)
oem fiat pads are cheepos just priced high, the ones your mates have recomended, they from a motorfactor? if so they will be trade price, when they fit um to a car customer will be charged double that, if they dont come with new bolts dont forget to clean up your old ones and use thread lock
Binki
dave is offline
Old 15-09-2005   #12
Trader Rating: (0)
Yeah, they are from a motorfactor. chances are that if i go to a local garage to do em, this is where they are from.
So your saying the £17 ones are no different to the fiat ones then?
Old 15-09-2005   #13
__________
dave's Avatar
Trader Rating: (10)
ah they be diffrent alright, they be better, wont wear out as quick as blooming fiat ones
Binki
dave is offline
Old 15-09-2005   #14
Trader Rating: (0)
Lol, ya reckon?
I got about 15k out the £8ers on the ibiza- saying that, from different place and were johnny no brand.
Old 15-09-2005   #15
Trader Rating: (0)
I have always carried out my own servicing when the car came out of warranty and have always changed brake pads and shoes myself as I saved money even when the car was being serviced by a dealer for warranty considerations, .
I also "saved" money by buying cheaper pads and shoes at times but I have had problems with some of them wear, fading, squealing. I now only use Ferodo pads (which were fitted as OE on my 1.6 Stilo). They are more exensive about £29.00 if you shop around but I get no problems.
Is the extra tenner or so that much when spread over 20000+ miles!
Chris
Front Brake pads and Warrenty Pat H Ulysse 6 20-07-2005 08:05
Front bumper and o/s front wing needed? Kerios Barchetta 1 06-06-2005 21:07
(G) Brake Pads? Ian_Dublin Punto 1 03-06-2005 00:31
(T) Noisey brake pads stiloactive Stilo 4 08-11-2003 07:06
