The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 25-08-2005   #1
choppertoo's Avatar
Trader Rating: (0)
1.6 Oil Level
I reported my stilo as running roughly to my dealer .... he reckoned the oil level was seriously low??? I've been checking the oil level every week and the dipstick has never moved from the top of the indented part .... when I got it back from the dealer according to the dipstick it is now overfilled ??? As it is no longer within the indented bit .....but actually over it by almost a cm???
Am i reading the dipstick wrong
EX - 53 1.6 Dynamic - Broom Yellow - Sold and now badly missed
choppertoo is offline
Old 25-08-2005   #2
Whaddya mean too old?
Deckchair5's Avatar
Trader Rating: (0)
Deckchair5 has donated! United Kingdom
Re: 1.6 Oil Level
Are you saying it's running smoothly now and the cure was just putting oil in even though you check your oil regularly? That's sounds unbelievable.
If it's over the max level now then they've obviously put too much in. Did they check it on a 1 in 5 hill or something? Overfilling oil is a common mistake as the oil is almost colourless
If you had VERY low or no oil it would sound terrible and be doing serious damage. You'd feel it, hear it and probably even smell it isn't right.
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline
Old 26-08-2005   #3
Peek a boo!
SLOVAC's Avatar
Trader Rating: (0)
SLOVAC has donated! South Africa
Re: 1.6 Oil Level
Putting too much oil in a car can be just as damaging to the engine as putting too little in.
If the rough sound is still there, I would get rid of the excess oil.
SLOVAC is offline
Old 26-08-2005   #4
choppertoo's Avatar
Trader Rating: (0)
Re: 1.6 Oil Level
It's running smoother now ???? Will just have to keep an eye on it ... as according to the dealer the oil consumption is quite high .... I haven't quite made 15,000 miles yet
Old 26-08-2005   #5
147,Boxster S,GP Multijet
paulmacs's Avatar
Trader Rating: (0)
paulmacs has donated! Ireland
Re: 1.6 Oil Level
The oil consumption on my Stilo is unreal. It uses 10 times the oil my 1.6 Bravo does and has done since I bought it. But then, my stilo has been riddled with faults so it does not suprise me if the engine is screwed too. Are you getting the 'low oil pressure' message often?
Paul M
paulmacs is offline
Old 26-08-2005   #6
Trader Rating: (0)
Re: 1.6 Oil Level
Don't check the oil with a cold engine or a hot engine! Let it run for 5 minutes to warm, then leave it 30mins to cool a bit then check it! Perfect conditions. Also check it while the car is parked on level ground, not just front to back, side to side too!
53 plate, Stilo 3-door, Sassy grey, 17" Claw Alloys, Falken Ziex Z512 tyres, 1.2 Active -- 45mpg!
StiloBoy is offline
Old 26-08-2005   #7
Trader Rating: (0)
Re: 1.6 Oil Level
The handbook says leave it 5 mins after turning the engine off....is it best to wait 30 then?
HornetUK is offline
Old 26-08-2005   #8
5vp3r m0d
Stu DemonD's Avatar
Trader Rating: (1)
Stu DemonD has donated! United Kingdom
Re: 1.6 Oil Level
Check it at 5 mins and then 30 mins - see if there is a difference
Electroclash Panda 100HP
Red brake calipers - done / Red highlights on engine cover - done
Red GSR kit - done / Red badges - done / Cobra springs - done
Stu DemonD is offline
Old 27-08-2005   #9
Yfstilo's Avatar
Trader Rating: (0)
Re: 1.6 Oil Level
every time i turn the engine on i get stop engine warning on dash and it sais oil pressure fault its out of waranty now anyone have any ideas!!
2002 broom yellow stilo 1.6 16v dynamic, 17" rims kenwood h/u and jl audio speakers all round custom boot install. profesional window tints with 1 off rear screen pattern!!! debaged custom grille,
Yfstilo - aka - Nick!!!
http://img224.imageshack.us/img224/9...ckstilo4ki.jpg
Yfstilo is offline
Old 27-08-2005   #10
Deckchair5's Avatar
Trader Rating: (0)
Re: 1.6 Oil Level
The fact you're losing huge amounts of oil AND you have low oil pressure doesn't sound good. Somewhere oil is escaping and if you can't see an external leak then it's going internal and out the exhaust. Can't run an engine with low oil pressure without doing damage so it's going to need some work by the sound of it
Possible internal oil seal or head gasket or oil pump problems but that's purely a guess
Oh sorry I thought you were choppertwo and losing copious amounts of oil too. Is it a feature of yellow Stilos?
If it's saying low oil pressure then check oil level and check the warning is correct first. Done an oil filter change recently?
99 Bravo 1.2SX
Old 28-08-2005   #11
Trader Rating: (0)
Re: 1.6 Oil Level
5 mins will probably be ok, just so long as the engine is only just warm, not fully heated up. 5-10 mins should be enough to let the oil level to settle in the sump but not every drop drain back (like if you left it overnight before checking).
I check my oil pretty frequently, thats from owning a mini! Need to check the oil frequently!
StiloBoy is offline
Lets clear up a common misconception (oil viscosity) oilman Lets Talk FIAT 19 06-07-2005 14:47
(T) Oh dear, gearbox oil leaks Blondeinapunto Punto 4 04-07-2005 17:19
(T) oil sensor failure / engine disaster Heather's Stilo Stilo 24 07-05-2005 00:16
(T) Stilo Oil Level Shminkypinky Stilo 9 22-03-2005 14:30
Electronic Oil Level Indicator Lou Ulysse 2 12-05-2004 19:38
