The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 18-08-2005   #1
Trader Rating: (0)
does anyone know what is for
my stereo has stoped working so i pulled out fuse 39 and it wasnt blow so i pulled out the stereo to see the back of that and the fuse wasnt blow on that to.but the was a red wire just hanging around does anyone know what is for thanks.
does it pull in to that little bit of highlighted
johnemerson38 is offline
Old 18-08-2005   #2
The Negotiator's Avatar
Trader Rating: (0)
The Negotiator has donated! United Kingdom
Re: does anyone know what is for
That blue block is a scotch block, somebody has used one to take off an extra wire from the positive feed.
Now drives: '52 Megane 1.9dCi
Past:
Y-reg Fiat Brava JTD (Pale Blue) (2006)
M-reg UNO (2003-2004)
'51 Fiat Brava 80 SX (black) (2006)
The Negotiator is offline
Old 18-08-2005   #3
Trader Rating: (0)
Oh and the bottom picture, that's a cage lug, it's there for when you fit the stereo, you push it down and it means that the stereo is locked into position.
Past:
Old 18-08-2005   #4
Trader Rating: (0)
so you dont think that that plugs into that bit on the stereo
on the 2nd pic
Old 18-08-2005   #5
Trader Rating: (0)
even if i put a next cd player in it still wont work i have tryied 4 of them
Old 18-08-2005   #6
5vp3r m0d
Stu DemonD's Avatar
Trader Rating: (1)
Stu DemonD has donated! United Kingdom
Don't Stilos have different ISO adaptors?
Electroclash Panda 100HP
Red brake calipers - done / Red highlights on engine cover - done
Red GSR kit - done / Red badges - done / Cobra springs - done
Stu DemonD is offline
Old 18-08-2005   #7
Trader Rating: (0)
THen I would start with the following, either use a test lamp or multimetre to see if you have power between the black and red wires (using the metal parts on the connector).
Past:
Old 18-08-2005   #8
Trader Rating: (0)
i anit to sure has anyone got a wire diagram.
Old 18-08-2005   #9
jud
Trader Rating: (0)
hi
ive got the same it was a live feed for a nokia car kit
(since removed)
jud is offline
Old 19-08-2005   #10
Grim_Evil's Avatar
Trader Rating: (0)
below is the stilo wiring of the iso plugs(from the radio side)
Protection fuse
D 10A protection fuse for radio
Power Connections
A1 CAN B Line Signal
A2 Not Connected
A3 CAN A Line Signal
A4 Connection to +12v Switching on voltage(at car starting)
A5 Radio Aerial Connection
A6 Not Connected
A7 Connection to +12v(permanet) supply Voltage
A8 Earth connection
Speakers
B1 Rear speaker(right+)
B2 Rear Speaker(right-)
B3 Front Speaker(right+)
B4 Front Speaker(right-)
B5 Front Speaker(left+)
B6 Front Speaker(left-)
B7 ARear speaker(left+)
B8 Arear Speaker(left-)
Additional Connections
Line out - connection presetting for power aplifier (Booster) or active speakers.
C1 Positive sound input for external TMC Module
C2 Negative sound input for external TMC Module
C3 Mute signal input for external TMC Module
C4 Not connected
C5 Not connected
C6 Not Connected
Phone input
Connection presetting for handsfree phone kit(through radio)
C7 Positve sound input for external phone pressetting
C8 Negative sound input for external phone pressetting
C9 MUTE signal for external phone presetting
C10 Not connected
C11 Not connected
C12 Phone earth
CD Changer Connection
C13 CDC bus line
C14 CD Changer data bus
C15 CD Changer +12v supply voltage
C16 CD Changer swithc voltage
C17 CDC bus earth
C18 Sound signal earth from CD changer
C19 LH CDC sound channel
C20 RH CDC sound channel
hope that helps
Grim_Evil is offline
Old 23-08-2005   #11
Trader Rating: (0)
If its got a scotch lock in there it means the previous owners who clearly knows sod all about electronics has been fiddling about!
53 plate, Stilo 3-door, Sassy grey, 17" Claw Alloys, Falken Ziex Z512 tyres, 1.2 Active -- 45mpg!
StiloBoy is offline
Old 23-08-2005   #12
Orka inte
Seraph's Avatar
Trader Rating: (1)
Seraph has donated! United Kingdom
No, it probably just means he had a Nokia hand free kit fitted then had it removed.
I personally don't think that red wire is anything to worry about. but i would tape it over with insulation tape to stop it shorting on any metal perts of the car.
Then make sure you're using the correct fittings for reinstaling the new head unit (i.e. if you're installing a panasonic head unit, they often use different adapters to the Alpine headunits, which are also different from the blaupunkt ones that it comes with)
I'm also suggesting here that the head unit you previously took out was damaged, hence it not working, and that the new ones just aren't fitted right
HO! HO! HO!
Den som väntar på nåt gött väntar aldrig för länge
I think you'll notice when I turn this way, I'm done talking to you!
Seraph is offline
Old 24-08-2005   #13
Trader Rating: (0)
Anyone that uses scotchlock blocks should not be allowed near a car! If your gonna do a job do it properly!
StiloBoy is offline
Old 27-08-2005   #14
Trader Rating: (0)
then red wire isa perminant feed to something that has been removed nothing to worry about!!
05 broom yellow stilo abarth (manual) now for sale......... check out the classifieds section for a bargin
mat-nos is offline
