The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 12-08-2005   #1
Trader Rating: (0)
Ignition Coils
My engine has started to misfire on my 1.6 dynamic and the engine warning light comes on intermitently. This happend a couple of months ago and I was told that an Ignition Coil had failed. The simptoms are exactly the same this time but I have decided to save the £85 it cost last time and do the job myself.
Can anyone give me a quick 'how to' guide/advise and what tools do I need?
thanks
Ian.
3dr Dynamic, 1.6, skyroof and spoiler pack
>>>IAN>>> is offline
Old 12-08-2005   #2
5vp3r m0d
Stu DemonD's Avatar
Trader Rating: (1)
Stu DemonD has donated! United Kingdom
Re: Ignition Coils
If an ignition coil has failed, you shouldn't be driving the car - it can cause damage to your CAT due to unburnt fuel getting through....
Quite an easy job to do - do you know which cylinder it is?
Electroclash Panda 100HP
Red brake calipers - done / Red highlights on engine cover - done
Red GSR kit - done / Red badges - done / Cobra springs - done
Stu DemonD is offline
Old 12-08-2005   #3
Trader Rating: (0)
Re: Ignition Coils
No I don't know which cylinder it is, I was planning to check them one by one until I find which coil it is.
thanks
Ian
>>>IAN>>> is offline
Old 12-08-2005   #4
5vp3r m0d
Stu DemonD's Avatar
Trader Rating: (1)
Re: Ignition Coils
Yep, unless you got a spark tester, I suppose you could just release each pack and work it out by trial and error [well, thats what the AA man did when mine went ]
Old 13-08-2005   #5
one with the dark side
fiattech's Avatar
Trader Rating: (1)
fiattech has donated! United Kingdom
Re: Ignition Coils
With most modern fuel injection systems 2000> EOBD especially, if a coil goes down the ecu will also cut that cylinder injector as well to prevent unburnt fuel going through to the cat - clever that.
On the 1.6 engine you will need a 10mm socket and rachet.
Take the 4x nuts for the engine cover off and remove- watch out for the washers.
You'll be able to see the coils now- they are bolted down with 1x 10mm bolt.
its a straight swap once you've found out which one is at fault.
Previously Had P2 Stilo Abarth GT - Now VW Golf GTi
"power is nothing without control"
Originally Posted by kayl0rz View Post
im gagging just thinking about it
Originally Posted by Lolita View Post
i only want cock
fiattech is offline
Old 13-08-2005   #6
147,Boxster S,GP Multijet
paulmacs's Avatar
Trader Rating: (0)
paulmacs has donated! Ireland
Re: Ignition Coils
Yeah the AA can check...
all of mine, yes ALL died on mine in March!
Paul M
paulmacs is offline
(T) Ignition Coils! markwartd Punto 1 02-06-2005 18:36
(T) Ignition coils.... wizgti Stilo 9 08-04-2005 09:53
(T) Faulty Ignition Coils Jimbo24 Stilo 8 22-12-2004 20:55
(T) knocking ignition coils?? weewillywinky Punto 4 24-12-2003 04:15
(T) ignition coils!! welsh-lad Punto 3 10-10-2003 02:38
