| power socket in boot My Stilo does not have the power socket in the boot, I have the stupid hook thing instead. does anyone know if the wiring is still there behind it? and therefore would it be a simple job to fit a lighter socket in place of the hook ? I know there is a small inspection flap which gives easy access, any chance someone with the socket could take a piccy ? (have a small fridge I want to be able to occasionally run in the boot without the wire coming through the seats.) cheers
__________________ '03 Stilo Abarth Sillyspeed, Silver | |||
| doM repuS | Re: power socket in boot Hi Have a look on this thread - it may be of some help ![]() http://www.fiatforum.com/showthread....t=stilo+socket
__________________ Electroclash Panda 100HP ![]() Red brake calipers - done / Red highlights on engine cover - done Red GSR kit - done / Red badges - done / Cobra springs - done ![]() ![]() | ||
| | #3 | ||
| Re: power socket in boot Apologies - I should know better and search first before posting........
| | #4 | ||
| Re: power socket in boot OK so having read through the various threads on the subject and PM'ing PJP and Rich291, I still don't know the answer. having looked in the boot of my car I cannot find an obvious plug or part of the loom. My car has the small black plug as shown in one of the threads with a small diode fitted into it. (2 red wires). I can see no white plug - but maybe I am not looking hard enough? apparently someone tried measuring the voltage at the small black plug and shows 3v so that doesn't sound right anyway..... when you pull the diode out the boot light goes out ? tried connecting to ePer but can't. Help?
| Guide: How to wire an Amp | Luke | I.C.E | 3 | 11-07-2005 17:33 |
| Using the boot power socket for an amp?? | Stemondo | Stilo > Technical | 0 | 06-04-2005 11:59 |
| Power to the boot, earthing question. | arc | I.C.E | 4 | 03-02-2004 02:35 |
| Simple question - hope it's a simple answer! | DotSPF | Uno | 6 | 11-11-2003 22:18 |
| 12v Socket in boot | boywonder | Stilo > Technical | 30 | 06-11-2003 19:09 |
