| Scottish and proud | Got very noisy tappets when engine is hot, suspect blocked followers. anybody else had this problem on a 1.8 stilo?
| Join Date: Jan 2004 Location: Fife, Scotland, United Kingdom.
Thanks: 0 Trader Rating: (0) | Re: noisy hydraulic tappets If the tappets were at fault would the problem not be more apparently when the engine/oil was cold?
__________________ 53 plate, Stilo 3-door, Sassy grey, 17" Claw Alloys, Falken Ziex Z512 tyres, 1.2 Active -- 45mpg! | ||
| | #3 | ||
| Re: noisy hydraulic tappets Yup, problem shoud be more apparent when the engine is cold. If the engine doesn't make that kind of noise when cold, it's unlikely to be the tappets.
__________________ WAS: 1.6 16v Active Sport, Powerflow twin exit exhaust, Custom Pipercross Induction kit, lowered on Eibach shocks and springs, 17" Wolfrace alloys, Headlight masks, HID's, Front upper OMP strut brace NOW: Seat Leon FR+ 150TDI with remap - 200bhp & 306lb/ft! | |||
| | #5 | |||
Not like a tractor but noisy tappets for about 30secs, yeah!
__________________ WAS: 1.6 16v Active Sport, Powerflow twin exit exhaust, Custom Pipercross Induction kit, lowered on Eibach shocks and springs, 17" Wolfrace alloys, Headlight masks, HID's, Front upper OMP strut brace NOW: Seat Leon FR+ 150TDI with remap - 200bhp & 306lb/ft! | ||||
| | #6 | ||
| Scottish and proud | Re: noisy hydraulic tappets Hydraulic followers can be noisy ven when hot, oil becomes too thin reducing pressure inside follower. Spoke to Fiat today, they have heard oproblem. said they will try different oil. May have to start telling them that I am actually an engine technician!
| | #7 | ||
| Re: noisy hydraulic tappets My 1.8 dynamic (petrol) sounds like an old diesel hackney taxi always has, probably always will. Don't know if that helps your case any...It's epecially bad starting from cold, or if I've tanked it down the motor way at 90, stopped, then started it 15 minutes later. I always thought that it was that crap italian pizza oil they put in it. Maybe lacking in the viscous department.
__________________ Stilo '02, 3dr 1.8 Dynamic. Passenger side door randomly refuses to unlock. / Driver side door internal door handle link broken. / Timing Variator and/or Water Pump . / Driver Side Inside Door plastic door panel knackered. "ASR Failure, ESP Failure, Security System Failure, Loose Connection..." Last edited by euan; 06-08-2005 at 21:55. | |||
| | #8 | ||
| Scottish and proud | Re: noisy hydraulic tappets Just got my car back from the dealers, they fixed gearbox oil leak, no questions asked. They replaced oil with fiat recommended oil, (selinia) excuse the spelling. Guess what. no more tappet noise - fantastic. praise where praise is due, Arnold Clark in Elgin were really good for a change, service manager couldn't have been more helpful!!!
| | #9 | ||
| the 1.8 is a very silent engine and if you have a 1.8 which makes that noise then you have a broken timing-variator which needs to be replaced once this part is changed the engine is very silent also at start up many 1.8 had a bad variator mounted and this was a japanese part of the engine guaranteed solution
__________________ Italian Stilo Captain Stilo,1.8 Dynamic | |||
| | #10 | ||
| Re: noisy hydraulic tappets My 1.8 Dynamic had recently started to be diesel-like for about 5 seconds at start-up. This happens mostly at work however where other people can hear it... when no-one else is around its as silent as anything. Is this serious... yet another thing to get fixed (the list is long enough already)... or can it be left alone? I remember my Brother's old VW Polo's tappets were really noisy at start up and nothing ever happened to that...
| | #11 | ||
| Re: noisy hydraulic tappets the damaged/broken variator causes the diesel noise if left unchanged, a 1.8 engine with a damaged variator is not affected at all and it will not get damaged (same performance), potentially the broekn variator could be left on the engine for good, but then the noise will be there for ever!!! the variator can be changed under warranty, and once you have a new variator your car is as silent as you would expect and you will regret the fact that u left the noise for so long with a new variator the quick tappets
| | #13 | ||
| Re: noisy hydraulic tappets This is all fascinating. My Stilo is very quiet - depending on the position of the accelerator! I'm not sure what a variator is or it's function. Would one of you gentlemen enlighten me please?
| | #14 | |||
A variator is a little gadget in the engine somewhere, which, when working correctly, stops it from having noisy tappets! (Could'nt help that, sorry)
__________________ Phil 04 Stilo 1.6 Dynamic, 3 door, black, 17" alloys, MP3 player, steering wheel buttons, (cr@p radio reception ) | ||||
| | #15 | ||
| All Hail the Woodsman | Re: noisy hydraulic tappets The variator regulates the camshaft timing across the rev range. If it isn't working properly/broken then you'll lose performance so get it fixed under warranty. I had the same problem in the Alfa GTV got it replaced along with the cambelt and tensioners, no more diesel impressions.
__________________ Fiat Bravo T-Jet Sport / Strada 130TC (currently undergoing restoration) www.strada130.com | ||
| | paul_treg | Cinquecento / Seicento | 8 | 05-04-2006 12:00 |
| Has the JTD got hydraulic tappets? | Shepherd | Multipla | 1 | 13-07-2005 22:24 |
| | peterdg | Cinquecento / Seicento | 5 | 19-04-2005 13:54 |
| | hangten | Punto | 3 | 04-04-2005 17:23 |
| | marclanchester | Cinquecento / Seicento | 6 | 23-11-2003 15:25 |
