| Banned | Hi all, about a week ago I was showing a friend my engine bay & he pointed out that my coolant resevoir was empty, so on thursday I topped it up to just underneath the MAX line on the resevoir & looked at it yesterday & it's virtually all gone again yet there are no puddles under the car & no warning lights coming up on the dash! Does anyone have an idea what this could be? I'm hoping it was just almost empty in the first place & just needs more in it because the car doesn't run hot! Please don't tell me it is a blown headgasket!
| Drives a Punto | Re: Missing coolant? Have you started it up on your drive yet? let it get up to temperature so the water is pressurised, you might see any leaks then.
__________________ 3rd Fiat - luck as good as ever | ||
| | #3 | ||
| Banned | Re: Missing coolant? Thanks mate but I've done all that already at work when I topped it up!
| | #4 | ||
| Re: Missing coolant? hi ben. take the top of the header tank,fill up to mark,and run with cap off.if you see bubbles in the coolant,you have gasket problems.have you been running your aircon? could have a leak there.checked the oil for water spots?way forward i think is a pressure test at the header tank.this will for sure tell if you have a leak somewhere which obviously you do.needs sorting perhaps when you change cams eh?
| | #5 | ||
| Whaddya mean too old? | Re: Missing coolant? It won't be a thermostat, that just regulates the water flow. The water's going somewhere. If you haven't got a heater leak inside the car (wet mats) then there's a possibility that something like a water pump leak dribbling onto a hot engine surface can evaporate the water but that usually deteriorates fast into an easy to see steady trickle. No signs of blue deposits around radiator or elsewhere? Other than that I'd be thinking head gasket. They'll sometimes only leak when the engine gets really hot.
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX | ||
| | #6 | ||
| Banned | Re: Missing coolant? That's what I was thinking! I cant 'see any blue deposits anywhere. I'll get one of the technicians at work to have a look tomorrow. I am now seriousl ****ting a brick!
| | #7 | ||
| Whaddya mean too old? | Re: Missing coolant? How quick is it going down? How many miles? Could try Radweld and hope for the best. Probably won't do any harm if the the next step is head off
| | #8 | |||||
It will when you haven't got the money mate!
| | #10 | ||
| Banned | Re: Missing coolant? Update! First it appears good news! the headgasket is fine & functioning. Bad news I think I need a new rad! which even at trade is about £130ish!
| | #11 | ||
| Was VXR enough :( | Re: Missing coolant? Thats weird, my dads car is doing the same thing! I'll give him some advice from this thread Hope your car gets sorted soon Ben
__________________ Fiat Punto Active Skoda Fabia vRS Vauxhall Astra VXR SEAT Ibiza 20VT FR Renault Clio 182 & Honda CB600FA Hornet | ||
| | #12 | ||
| Drives a Punto | Re: Missing coolant? Ben, try doing what I said earlier and rev the engine a bit when you up to temperature. Aslong as its not over heating, and you got some coolant in there it won't do any harm... Then you will see if it is a rad leak or not. Good news about it not being HG though!
| | #13 | ||
| 5vp3r m0d | Re: Missing coolant? And still no warning lights coming up? ![]() Useful
__________________ Electroclash Panda 100HP ![]() Red brake calipers - done / Red highlights on engine cover - done Red GSR kit - done / Red badges - done / Cobra springs - done ![]() ![]() | ||
| | #14 | |||||
No not really! As it means I can't buy H's spare turbo now! Balls!
| | #15 | ||
| Re: Missing coolant? hey, i had this exact problem...every few days my coolant would be virtualy empty despite regular coolant top-ups it came to a head and my radiator gave up thus resulting in a new raditor being fitted. My car being in its last year of its warranty meant that the raditor was not covered (its only covered in first 2 years of m warranty). The radiator is around 130quid and thats before installation costs and anti-freeze. It cost me something like 270quid from a fiat dealership for the job unfortunatly i did not have time to shop around as i needed my car back, so may be repaced for a lesser cost elsewhere, assuming your problem follows the same path as mine.
__________________ Streaky Previous: 1.2 W-Reg Punto Previous : 3dr 02 Stilo, 1.6, Black Now: VW Golf 1.4FSI | |||
| | phil_harry | Cinquecento / Seicento | 10 | 14-04-2005 19:36 |
| | Carltonleon | Stilo | 0 | 28-02-2005 10:38 |
| | HornetUK | Stilo | 4 | 12-02-2005 20:38 |
| | Punto Mad | Punto | 8 | 01-10-2004 15:06 |
| | boywonder | Stilo | 20 | 13-09-2003 04:19 |
