| Airbag Problem I have just become the proud owner of a 3 dr 1.9 JTD Stilo Dynamic and as soon as the garage I purchased it from shut for the day the driver's airbag light come on for no apparent reason and I keep getting the warning on the LCD to stop the engine due to airbag failure.As I am unable to speak to them until the morning I was just wondering if anyone has experienced any similar problems
| Whaddya mean too old? | Re: Airbag Problem It's often caused by the connectors underneath the seats which are tacky to say the least on most cars these days. Thankfully on the Stilo, once you hit the jackpot, the air bag light goes out on its own and doesn't need taking to a dealer just to reset the warning light. Dealer should be able to fix in no time but there's a lot to airbag systems so they often come on again NB the airbag warning light is saying it's found a fault and the airbag system is shut down (rather than watch out it might go off in your face!) so it's up to you whether you drive it or not
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 31-07-2005 at 08:21. | ||
| | #3 | ||
| 5vp3r m0d | Re: Airbag Problem Mine used to come on all the time, mainly when there was a passenger present... Now currently fixed - dealership had two attempts at fixing it, and ended up being the passenger weight sensor in that seat.
__________________ Electroclash Panda 100HP ![]() Red brake calipers - done / Red highlights on engine cover - done Red GSR kit - done / Red badges - done / Cobra springs - done ![]() ![]() | ||
| | #4 | ||
Thanks: 38 Trader Rating: (0) Drives: | Re: Airbag Problem "NB the airbag warning light is saying it's found a fault and the airbag system is shut down (rather than watch out it might go off in your face!) " Not true, the airbag warning light and message comes on to indicate a fault with the system, the airbag ecu SHOULD shut the system down BUT if the fault is with the ecu then there is no way of telling what the airbag system will do. Personally I would be ok with driving it but it is up to the driver to make his/her choice.
| | #5 | ||
| Grumpy Forum Moderator | Re: Airbag Problem If customer wants to take away/drive his/her car with the airbag light on I ask them to sign a decleration to that effect or tell the customer infront of a witness....I dont fancy getting sued if airbag does not go off in a accident!
| | #6 | ||
| Whaddya mean too old? | Re: Airbag Problem Are you sure NumanR? ALL of the many criteria must be met before an air bag can be allowed to trigger to go off and one of them is no faults found in the self test system. Whilst, taken to extremes, absolutely anything can happen regardless of whether the airbag light is on or off, the air bag system should be non functional if the warning light is on
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 31-07-2005 at 13:02. | ||
| | #7 | ||
Thanks: 38 Trader Rating: (0) Drives: | Re: Airbag Problem Yes I am sure, if the ecu is faulty it does not have to follow ANY criteria before it fires any airbag.
| | #8 | ||
| Whaddya mean too old? | Re: Airbag Problem So when we manually switch the passenger air bag off and the passenger air bag warning light comes on to tell us it's non functional your saying the passenger air bag could still go off? Or is that different? If someone intends driving with an air bag warning light on then should they pull the air bag fuse to isolate the whole system?
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 01-08-2005 at 09:00. | ||
| | #9 | ||
Thanks: 38 Trader Rating: (0) Drives: | Re: Airbag Problem When you operate the switch for passenger airbag you do not interrupt the wiring to the airbag you send a signal to the ecu to do it. The ecu can still IF FAULTY fire that airbag. Strictly speaking it should be an AA recovery, if you go by the book. Personally knowing how few ecus I change I would carry on driving, but thats my risk, I certainly wouldnt have children in a front seat with an airbag malfunction warning light on.
| | #10 | ||
| Whaddya mean too old? | Re: Airbag Problem Thanks for the info NumanR. That's very interesting. Someone is truly having a laugh with airbag systems. If you turn an air bag off then it should be off- off- OFF, fail safe no ifs or buts or maybes but completely non functional with no hope of life. As the dodo. Quite frightening some of the systems that can kill you but totally rely on 10p microchip having a good day
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX | ||
| | #11 | |||||
| Re: Airbag Problem
| | #12 | ||
| Re: Airbag Problem Regular occurance with my JTD and my 1.6. I get under the seat, disconnect and reconnect. Works everytime, somebody will tell you how dangerous this can be but when you see the dealer do exactly the same thing then I wont waste my time taking it to them. If they effected a permanent fix then I would.
| | #13 | |||||
| Re: Airbag Problem
| | #14 | |||||
| | #15 | ||
| Re: Airbag Problem hi i had this constant problem with my 1.6 and after 4 attempts at numerous things at dealers - they finally took it in for 2 weeks and completely replaced the loom and all wiring units under the seats - havent had it since !!! and it didnt cost me anything even though it wasnt under warranty
| | Thomas P | Uno | 10 | 23-08-2006 20:04 |
| | sallyanderson | Punto | 2 | 30-06-2005 17:44 |
| | andre79ge | Punto | 2 | 10-02-2005 23:43 |
| Mid-throttle injection problem in Lancia Y10 | FatNote | Panda (Classic) | 26 | 30-07-2004 18:58 |
| Brava lockup problem | Kensho | Lets Talk FIAT | 1 | 11-11-2003 03:05 |
