| Having fitted a Blaupunkt A09 CD changer, part no 7607 769 150, the changer does not play. The head unit is the NAV+ system, which is running 9.8 firmware. Blaupunkt say the cd changer does not work with 'special software'. I suspect that the 9.8 is 'special' and I should have kept the original 8.5 firmware. I want to downgrade to the 'standard' firmware. Any ideas?
| Re: Nav+ 9.8 CD Changer Sorry M8, but you need the special FIAT version of the A09 to work with connect+.The gits have put special software in the CD changer !
| | #3 | ||
| Re: Nav+ 9.8 CD Changer Hi, Thanks for the response. The problem is that, the changer is supposed to be compatible. There are two versions of the changer, as discussed in a previous thread. The incompatible one ends with part number 100. The Fiat part number for my changer is 735 273 184, can anyone verify that the is correct? Thanks for any help.
| | #4 | ||
| Re: Nav+ 9.8 CD Changer To follow up: The changer is recognised by the head unit, disks can be selected, and tracks selected, but it is impossible to play the cd to hear the music. Could this be due to the following: 1. faulty changer 2. incompatible changer 3. security code not entered before device was removed from previous installation. Does anyone have an idea?
| | #5 | ||
| All Hail the Woodsman | Re: Nav+ 9.8 CD Changer
__________________ Fiat Bravo T-Jet Sport / Strada 130TC (currently undergoing restoration) www.strada130.com | ||
| | #6 | ||
| Re: Nav+ 9.8 CD Changer Hi jamesannesley! I had a same problem. I sovled with my wife's Punto. You need a Blaunpunkt head unit for 2 minutes. Attach the CD-hanger to the head, switch off the code as in the manual. And DON'T switch off the radio after that, just pull down the changer. (it's the trick) After that it will work with CN+ 9.8. (the CN+ didn't suppot the code handling) Regards peterdif
__________________ PF 1.6 - 3d - CN+ - SkyWindow - ESP - ... | |||
| | #7 | ||
| Re: Nav+ 9.8 CD Changer Thanks, I figured this out myself finally. I didn't have another Blaupunkt head unit so I have sent it off to be reset. Fingers crossed.
| CD Changer problems | benfredjosh | I.C.E | 1 | 06-06-2005 09:38 |
| | craig 980 | Punto | 4 | 17-01-2005 10:36 |
| CD Changer help | Stilo Multijet 140bhp | Lets Talk FIAT | 2 | 16-12-2004 20:56 |
| Who makes Connect nav unit?What CD changer? | leighc | Ulysse | 13 | 17-07-2004 19:16 |
