| Water in Drivers Footwell Hi - getting excessive water in drivers footwell Also seem to get dripping from drivers footwell side after the car has had a run. Any ideas - dealers says the aircon unit is at the passenger side so this can't be the problem.
| <Team TD> | Re: Water in Drivers Footwell I would think its the aircon my old man had the same problem with a land rover discovery when that things aircon went wrong near enough the whole floor was wet back and front. Is it only wet in the drivers footwell and not the passenger as well? Personally id get the car down fiat and get them to look at it.
__________________ Bob In Disguise Ex Fiat Owner EX: Grande punto sporting ![]() Former: Fiat Stilo 3 door Former Former: Mk1 Punto 3 door ![]() | ||
| | #3 | ||
| Re: Water in Drivers Footwell Thanks Bob - it is only the drivers footwell. Passenger one is dry and the proverbial bone. Had it into Fiat - they can't find a problem. Said they need to dismantle the dash at a cost of 500 nickers. Not too keen on that as you can understand
| | #4 | ||
| Whaddya mean too old? | Re: Water in Drivers Footwell Do you usually have the air con on? Do you have a sunroof? Does it only happen when it rains? Do you have roof bars? Do you have a different aerial? Is it rain water or does it have antifreeze smell eg heater leak? Losing engine coolant? Frequently topping up? Do you always park on the same kind of slope? Are the door drains clear?
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX | ||
| | #5 | ||
| Seicento Type R | Re: Water in Drivers Footwell My dad had the same problem with his punto it was in fiat 5 times under warenty untill i finaly found the problem. there's was leaking on the passenger side It was a cracked air con pipe fiat finanly agreed to fix it as it was just out of warenty but because they hadnt found the fault previously they fixed it
__________________ James www.clubcento.co.uk http://mysei.mysite.wanadoo-members.co.uk/ | ||
| | #6 | ||
| Re: Water in Drivers Footwell on a previous car it was the heat exchanger that dumped antifreeze into the passenger footwell. it's a pain of a job if it is this as the dashboard had to come out
| | #7 | ||
| Re: Water in Drivers Footwell I had the same problem http://www.fiatforum.com/stilo/27992-water.html
__________________ Fiat Bravo Trofeo 1.6 X Reg Fiat Stilo Dynamic 1.8 02 now Fiat Stilo arbath 2.4 what next | |||
| | #8 | ||
| GP T-Jet Owner | Re: Water in Drivers Footwell I had the same kinda problem in a punto i used to own, unfortunately i never found out the cause because i wrote the car off which stopped me havin to worry about a water leak!
__________________ Sold: 02 (52) Sassi Grey Stilo 1.6 Active, Full Merkur Bodykit, MS Design Spoiler, 18" Lenso Shu Wheels, 50/40 Drop, Ragazzon Quad Exhaust Now: 07 (57) Crossover Black Grande Punto 1.4 Tjet 120 Sporting....Standard | ||
| | #9 | ||
Thanks: 38 Trader Rating: (0) Drives: | Re: Water in Drivers Footwell Stilo drain for the aircon is on the DRIVERS side, it can be inspected in minutes by pulling off the side panel of the centre console. Not a common problem but its likely the hose has either disconnected itself or is blocked.
| | fiatbravaross | Bravo / Brava | 8 | 19-04-2005 02:44 |
| | meirion | Punto | 5 | 19-05-2004 04:18 |
| | Steven | Uno | 18 | 06-04-2004 03:57 |
| | meirion | Punto | 3 | 15-03-2004 05:55 |
| | edmoff | Punto | 8 | 26-01-2004 22:32 |
