| My 02 stilo diesel air con compressor is not turning we have traced back to the relay in the fuse box not pulling in (fuse is 0k), if you manually work the relay the compressor works. Air con light is on on the dash. Has anyone any info?. If the refrigerant is low on pressure is there a pressure switch to stop the compressor running? also the main fan doesn't run when the air con light is on. Anyone got a wiring diagram?
| Banned | Re: 02 Stilo diesel air con problem Sounds like you need a new compressor, You can manually switch it off buy pressing the snow flake button.
| | #3 | ||
| Whaddya mean too old? | Re: 02 Stilo diesel air con problem I'm still finding my way around the Stilo A/C but I believe there's a low pressure switch which stops the compressor running for instance if there's no gas. Have you checked for the common fault of the aircon pipe cracked therefore no gas? There's some useful reading here http://www.fiatforum.com/marea/27956-2-4-jtd-wiring-diagram-air-con.html although it's for the Marea 2.4JTD
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 09-07-2005 at 23:28. | ||
| | #4 | ||
| Re: 02 Stilo diesel air con problem Thanks for that I will pop a bit of 134 in it and see if it starts up and then have a look for that pipe problem.
| | #5 | |||||
Hi ive got a sim prob to yours and am working back from the compressor (where the clutch kicks in if a live feed is applied ), can you tell me which relay was problematic please, thanks paul
| | #6 | ||
| Join Date: Jan 2004 Location: Fife, Scotland, United Kingdom.
Thanks: 0 Trader Rating: (0) | Re: 02 Stilo diesel air con problem Forgive me for being thick, but if you manually work the relay and it works, does this not suggest the relay is at fault?
__________________ 53 plate, Stilo 3-door, Sassy grey, 17" Claw Alloys, Falken Ziex Z512 tyres, 1.2 Active -- 45mpg! | ||
| | #7 | ||
| :) | Re: 02 Stilo diesel air con problem Possibly but it also can suggest whatever is feeding the relay isn't happy.
__________________ Now drives: '52 Megane 1.9dCi ![]() Past: Y-reg Fiat Brava JTD (Pale Blue) (2006) M-reg UNO (2003-2004) '51 Fiat Brava 80 SX (black) (2006) | ||
| | Balthar | Stilo | 3 | 27-06-2004 03:48 |
| | bobster | Stilo | 2 | 20-08-2003 08:37 |
| | buckster | Stilo | 9 | 11-08-2003 15:53 |
| | Silver_Sei | Punto | 3 | 09-08-2003 17:07 |
| | monk | Bravo / Brava | 1 | 24-04-2002 02:43 |
