The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 30-06-2005   #1
Big Black Stilo's Avatar
Trader Rating: (0)
Creaking window
When you lower the drivers window, say half way (doesnt do this all the way down), when it stops it creaks and clicks. When it does back to the top from whatever position and stops, it creaks and clicks.
Sounds painfully broke and not getting better.
Any ideas before I go mental?
IMPORTANT ANNOUNCEMENT!!!
Fabbrica Italiana Automobili Torino
Big Black Stilo is offline
Old 05-07-2005   #2
Trader Rating: (0)
Re: Creaking window
Its still doing it.
Old 05-07-2005   #3
The Last Starfighter
RichyV's Avatar
Trader Rating: (0)
RichyV has donated! United Kingdom
Re: Creaking window
Originally Posted by Big Black Stilo
Its still doing it.
Does it seem to be getting worse?
I only ask as mine's been doing this (albeit not loudly & it's hardly noticeable...) since I bought it and I just thought it was a 'quirk'.
RichyV is offline
Old 05-07-2005   #4
Trader Rating: (0)
Re: Creaking window
Na not getting worse but it never made a noise when new. Is also getting slightly slower than the passenger side, and will always go another mil with another push of the button when at the top.
Goddam annoying
Old 06-07-2005   #5
Trader Rating: (0)
Re: Creaking window
That's exactly the same as mine. When the window gets to the bottom of its travel it makes a high pitch squeek, like a hamster being strangled. I just put up with it, a bit like the chirruping from the left rear parcel shelf area which I am unable to cure.
On a side note, has anyone tested the anti-trap facility on the windows using their own fingers? I have'nt got the bottle to try it myself, just in case!
Phil
04 Stilo 1.6 Dynamic, 3 door, black, 17" alloys, MP3 player, steering wheel buttons, (cr@p radio reception )
PhilB is offline
Old 06-07-2005   #6
Rothwell999's Avatar
Trader Rating: (0)
Rothwell999 has donated! United Kingdom
Re: Creaking window
same here and what a pain yet again, i wanted to get windows tinted but dreded that it all could be ruined by a press of a button!!!! i think it may be the motor but mine sounds like a piece of metal grinding against glass. not good!! its an '02' reg now so out of waranty i wouldn't pay for the third as they are gits anyway when it comes on whom to blame.
Rothwell999 - Fiat Stilo active, crystal green 3 door, 17" fiat alloys, 5 disc changer, de-badged, leather interior and lods of little problems. As per fiat
Rothwell999 is offline
Old 02-08-2005   #7
Trader Rating: (0)
Re: Creaking window
Its getting worse so im thinking something is getting loose somewhere. Also its slower than the passenger one now.
doh
Old 02-08-2005   #8
Trader Rating: (0)
Re: Creaking window
i,ve got an 05 plate jtd and it has been making the same noise as described since day one.
flashman is offline
Old 02-08-2005   #9
ChrisF's Avatar
Trader Rating: (0)
Re: Creaking window
And when your driving with the window halfway down,the window kinda rattles a bit....its you window regulator.
I have had mines replaced once already, and it did sort it. But the replacement just started doing the same thing. It is covered under warranty. So i'm taking it back to get replaced again at a different garage.
I find it strange, that it only happens on the drivers side.
The fiat tech at arnold clark said its common on puntos but first time he had seen it on a stilo and that fiat had moved the goal posts, they used to be screwed on but now they are riveted so they had to drill out the rivets to fit the new one. No doubt they botched it.
Put the window half way and the put a bit of downwards pressure on it, if you feel it creak and see it move a bit your regulator is gone.
ChrisF
54 Plate on the outside 07 plate on the inside...Vroom
ChrisF is offline
Old 02-08-2005   #10
Trader Rating: (0)
Re: Creaking window
Effing hell- it dropped about and inch into the door.
Old 02-08-2005   #11
ChrisF's Avatar
Trader Rating: (0)
Re: Creaking window
Thats the regulator. Does it also sound like a rubber band stretching?
ChrisF
ChrisF is offline
Old 02-08-2005   #12
Trader Rating: (0)
Re: Creaking window
Yes!!!! Thats it!!!
Thats the exact frigging noise driving me mental!
Only problem is now car is in third year warranty, is it covered?
Old 02-08-2005   #13
ChrisF's Avatar
Trader Rating: (0)
Re: Creaking window
Yes!!!! Thats it!!!
Well its worth a shot, my car is a 54 plate and its done it from new more or less. I would be surprised if it isn't covered. They might try and fob you off with a wear and tear story, really depends on how good your dealer is.
It starts with that rubber band noise, then the window start rattling when anywhere between fully up and fully down. I'm getting it fixed again soon, because i suspect the next step is it goes pop and the window is stuck open.
Im taking it back to the paisley reg vardy fiat/alfa dealer they seemed very professional. And my clutch has not creaked or squeaked since they sorted it. Even in the 30oC summer days we had a few weeks, heat always triggered it. I need to get pics of tha damage to the door card that arnold clark did replacing the regulator the last time.
ChrisF
ChrisF is offline
Old 02-08-2005   #14
Trader Rating: (0)
Re: Creaking window
Mine makes a pop noise when it opens when raining and rattles as well.
Will try it on with the dealer as it sounds as though could be expensive.
Old 02-08-2005   #15
Grumpy Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
Re: Creaking window
Covered by 3rd year warranty aslong as you had 12 & 24k services.
Bit of a swine to change to be honest,if you dont reseat the foward grommet correctly the wiring loom gets caught on the glass coming down.....causing fun with the electrics
T14086 is offline
(T) Marea ELX Driver's Electric Window Stuck OilBurner Marea 2 04-08-2005 01:31
(S) Rear Window Removal (Window Tinting) killa_bees2k Punto 4 06-04-2005 22:11
Electric Window plastic part. Felipe Doblo 2 25-01-2005 02:23
(S) Removing rear window Adamski Cinquecento / Seicento 2 28-10-2004 18:36
(T) Electric window jambo Punto 7 09-08-2003 20:39
