The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 21-06-2005   #1
ProtoFJ's Avatar
Trader Rating: (0)
IS this the CD changer I need ?
I know this has been covered many times....
it this Here
the CD changer kit I need for my Stilo Abarth to fit with my Connect Nav+ head unit ? - is that a glovebox insert and does it look right ?
(probably shot myself in the foot now by leading eveyone to the auction )
cheers
'03 Stilo Abarth Sillyspeed, Silver
ProtoFJ is offline
Old 21-06-2005   #2
Trader Rating: (0)
timr69 has donated! United Kingdom
Re: IS this the CD changer I need ?
That looks like same changer & glovebox fitment that I've got.
Dunno if it'll connect ok to everything else as I haven't got the Nav+ but I'm sure someone will be along in a minute to tell you
2003 Fiat Stilo Multiwagon JTD Dynamic
1999 Fiat Coupé 20 valve turbo
1992 Mitsubishi Shogun TD 7 Seater
timr69 is offline
Old 21-06-2005   #3
purplemonday's Avatar
Trader Rating: (0)
purplemonday has donated!
That's definitely the Stilo CDC - it fits all standard Stilo head units and is a doddle to fit.
Basically you have two Torx screws in the roof of the upper glovebox (T25 iirc) which you need to remove - once removed you then need to give the liner a firm tug as it has a couple of clips holding it in.
Then remove the head unit - not sure what the Connect Nav+ is like but the tape/cd ones have four release holes to insert a suitable tool into. These holes are non standard in so much as you cannot use the two prong keys from Halfords as they are too small so the keys don't fit - you will need to make a set from some thin wire. I have found that some copper wire from a length of 2.5mm twin and earth cable works fine (strip the insulation from the live and neutral cores as the earth core is slightly thinner)
Once the head unit is removed, feed the supplied cable though from the glovebox and connect to the appropriate socket on the back of the head unit (Stilo Audio Manual has a diagram) and replace the head unit.
Fit mounting cage to glovebox liner and install in upper glovebox ensuring that you feed the cable through to connect the CDC. Replace screws, connect CDC and insert it into the mounting cage.
You should now be able to switch to the CDC from the head unit and you will be asked for a four digit code which should have been supplied with the CDC (the picture on the auction shows the code card tucked under the top of the mounting cage) and this should be entered in accordance with the instructions in the Stilo Audio Manual.
Once that's done you're in business - only gotcha with the CDC is they are prone to occasionally lock up (signified by all the lights on the front of it flashing and head unit saying check disc). If this happens it is normally reset once the ingnition has been switched off for a while - it's a pain in the arse when it happens but it's not something that happens that often.
John
Stilo 1 Volvo 0
Old: Stilo 1.6 Active 5 door in Crystal Green
New: Audi A4 SE 1.9TDI 115
purplemonday is offline
Old 23-06-2005   #4
ProtoFJ's Avatar
Trader Rating: (0)
Well hope you were all right - coz it's now mine
got it for a fairly reasonable price I think so quite pleased
Cheers for all your help.
Dave
ProtoFJ is offline
Old 08-07-2005   #5
ProtoFJ's Avatar
Trader Rating: (0)
Cheers guys
fitted it last night, no problems
It didn't ask for a key code to be entered though ?
was just as described in the auction - all brand new
for £110 I think i did OK
thanks for your help
Dave
ProtoFJ is offline
Old 08-07-2005   #6
5vp3r m0d
Stu DemonD's Avatar
Trader Rating: (1)
Stu DemonD has donated! United Kingdom
Were you stroking something at the time
Electroclash Panda 100HP
Red brake calipers - done / Red highlights on engine cover - done
Red GSR kit - done / Red badges - done / Cobra springs - done
Stu DemonD is offline
CD Changer problems benfredjosh I.C.E 1 06-06-2005 09:38
(T) Need help with DVD changer???? coghlac3 Stilo 0 09-05-2005 09:38
(T) Cd Changer Help Please!! Stilo Multijet 140bhp Stilo 5 17-12-2004 23:36
CD Changer help Stilo Multijet 140bhp Lets Talk FIAT 2 16-12-2004 20:56
(T) cd changer reuven Marea 4 22-11-2004 14:46
