| Stilo pulls left! I've just fitted 16" alloys to my stilo to replace the 15" steel wheels. All seemed fine. (although I only drove it home before going on holiday!) I had the car serviced at my local Fiat dealer this week and it now feels as though the car is pulling to the left constantly. Have they messed about with the tracking? (it was the 48,000m service), or do I simply need the tracking checking? If so where do you go? Kwick Fit etc or back to the dealer? Thanks for your help
| 5vp3r m0d | Re: Stilo pulls left! Why not get it done at a local tyre place that does proper laser-tracking...To be honest, I avoid the Kwik-Fit type places. There is a place in Rugby called TW Tyres, who bend over backwards to help and advise.
__________________ Electroclash Panda 100HP ![]() Red brake calipers - done / Red highlights on engine cover - done Red GSR kit - done / Red badges - done / Cobra springs - done ![]() ![]() | ||
| | #3 | ||
| Join Date: Jan 2004 Location: Fife, Scotland, United Kingdom.
Thanks: 0 Trader Rating: (0) | Re: Stilo pulls left! This was talked about about a year ago about cars tending to pull to the kerb. I read somewhere that due to road camber etc, that this is a design feature, i.e. if you have a stroke you won't typically plow into oncomming traffic, just mince a few peds. ![]() Anyhoo, the bigger the wheel foot print the more noticeable it will be.
__________________ 53 plate, Stilo 3-door, Sassy grey, 17" Claw Alloys, Falken Ziex Z512 tyres, 1.2 Active -- 45mpg! | ||
| | #4 | ||
| Grand Stilismo | Re: Stilo pulls left! Worth finding a good independant tyre place and get it laser tracked, Dont bother with the quick fit places ... you will go in for tracking and be told your Discs are warped, your pads are dangerous and your exhaust is blowing
__________________ http://photobucket.com/albums/y20/Bo...h_IMG_0646.jpg http://photobucket.com/albums/y20/Bo...h_IMG_0310.jpg http://photobucket.com/albums/y20/Bo...h_IMG_0315.jpg ***************** Broom Yella Fella **************** | ||
| | #5 | |||
__________________ Electroclash Panda 100HP ![]() Red brake calipers - done / Red highlights on engine cover - done Red GSR kit - done / Red badges - done / Cobra springs - done ![]() ![]() | |||
| | #6 | ||
| Join Date: Aug 2003 Location: Fife, Scotland, United Kingdom.
Thanks: 0 Trader Rating: (0) | Re: Stilo pulls left! mines is pulling to the left now after it had its tracking done its by a 5deg angle. ive just not had the time to have it rechecked out again. the pull is rather strong so it does gives your arms a bit of a strain after a while too
__________________ Scorg 01 Brava 80SX - Ink Black 02 Stilo Dynamic 1.6 - Sky Blue 03 Punto 60 Active - Silver Blue | ||
| | #7 | ||
| Grand Stilismo | Re: Stilo pulls left! You been bumping up any curbs .... That will throw it out after a while.
| | #8 | ||
| Whaddya mean too old? | Re: Stilo pulls left! How many miles have you clocked up? A worn track rod end can give you a pull to the left too. Mine did before I sorted it recently on 36K miles
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX | ||
| | #9 | ||
| Re: Stilo pulls left! I'd go back to the dealer first. Say the car was fine before they serviced it ![]() On a side note - I went to my local tyre dealer to have a nail removed from one of my tyres today. I showed him the tyres with the inner wear and asked if he thought it was worth getting the tracking checked. He said he wouldn't do it, as the last time he did the tracking on a Stilo it ended up pulling all over the place, dispite being adjusted to spec.
__________________ I used to have: 2003 Stilo 1.6 Dynamic 3dr, Orion Grey, 17" Alloys, Dual Zone Climate Control, Aluminum Sills, Clarion DXZ928R, Kenwood DualMags, Clarion SRX1784, de-badged, Merkur grill I accept no responsibility for the content of my posts, nor any decisions you make based on them. Audi A4 Avant 2.0 TDI S-Line | |||
| | #10 | ||
| Whaddya mean too old? | Re: Stilo pulls left! If your tyres have been running off track and have worn at an angle then when you get the tracking set up correctly the car will still probably pull until the tread wears down evenly again. If it's been really bad then it really takes some flat worn or new tyres to see if the tracking is now running ok. Then there's the new tyre problem. Sometimes even new tyres will track "off". I've had two new tyres on the front (on a different car) and it pulled left so, after finding absolutely nothing wrong with the suspension or steering, checking and rechecking many times, I change the front two tyres around and it pulls right! Great! You've got to keep an eye on your tyres regularly chaps! At least every week. They're the most important thing on your car! Waiting until the metal is showing through on one edge is chronic for your safety and your wallet I do my own tracking by old methods and is always 100% and more reliable than that done by the tyre shops. They don't even check whether you have any wear in the suspension/ steering BEFORE they do the tracking. Pointless trying to accurately track worn components
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 17-06-2005 at 15:55. | ||
| | #11 | ||
| Re: Stilo pulls left! Thanks for your advice. I had it checked by my local independant Fiat specialist and they checked the tracking and claim its ok. I reckon it probably is just because the wheels are bigger and its a question of getting used to it! Also my main dealer will have road tested it as part of the service won't they? They won't have missed an opportunity to charge for something would they!? I actually went to a local tyre place and they point blank refused to track a stilo! Apparently they have had nothing but trouble in the past with people complaining about the car being "messed up" after restoring it to Fiats recommended geometry. The mechanic said a number of local garages wouldn't touch Stilo tracking anymore and your only hope was a main dealer.
| | #12 | |||
Were all doomed
__________________ http://photobucket.com/albums/y20/Bo...h_IMG_0646.jpg http://photobucket.com/albums/y20/Bo...h_IMG_0310.jpg http://photobucket.com/albums/y20/Bo...h_IMG_0315.jpg ***************** Broom Yella Fella **************** | |||
| | #13 | ||
Thanks: 0 Trader Rating: (0) | Re: Stilo pulls left! Had it checked yesterday. it was one of the bloody tyres on the front that was to blame, so switched them around and it now pulls to the right. it isnt as bad though as it was at the time it pulled to the left, but I think the newest tyre will be comming off (some cheep thingy my dad bought and not the same as the other front) and the spare dunlop is coming out the boot
| | #14 | ||
| Whaddya mean too old? | Re: Stilo pulls left! Excellent! Can't always blame the car you see. I'll keep an eye out for you wandering into my lane as you're used to pulling it right all the time
| | #15 | ||
Thanks: 0 Trader Rating: (0) | Re: Stilo pulls left! Never buy Halfords own tyres, ever they always wear badly and often warp causing very weird driving characteristics!
| | 1.8Stilo | Stilo | 59 | 23-12-2005 21:38 |
| | Dongle | Stilo | 107 | 10-02-2005 00:15 |
| | BrianK | Stilo | 9 | 28-01-2005 23:42 |
| | Vanquish | Stilo | 11 | 11-01-2005 15:24 |
| | Roberto | Stilo | 0 | 14-07-2002 22:06 |
