The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 11-06-2005   #1
Trader Rating: (0)
Nav+ Gone Bonkers!!
My map display has just gone completely bonkers and as you drive the map just spins around your present location.
I can only assume that something has worn/dropped off the front wheels which is used in part to calculate your movement relative to the map/satellite position.
Does anyone have any ideas what it could be (and cost) as my car is going in on Monday for new discs and pads (80% worn so may have just knackered a sensor or something!)
Barbarian
3dr Grande Punto Sporting T-Jet, Leather, Caribbean Orange
barbarian is offline
Old 11-06-2005   #2
Trader Rating: (0)
Re: Nav+ Gone Bonkers!!
is it built in to car? or one you buy from a shop? if its one you buy from a shop i fink u will find that it is your sat nav as it sends and recives signals from a satalite. and doen not have anything to do with your wheels... i hope this helps
spike2002 is offline
Old 11-06-2005   #3
Trader Rating: (0)
No, it's the SatNav+ built into the car.
Barbarian
Old 11-06-2005   #4
Trader Rating: (0)
ok im not to sure then ther mite be sensors on the wheels but to be honest i dont fink there will be. if it came as standard in the car check the book that you should of got with it. it mite tell u wether its conected to the wheels in any way
Old 11-06-2005   #5
Banned
Trader Rating: (0)
Ben R has donated! Christmas Island
No sensors on the wheels mate as your position is tracked by satellite. Could be a software problem or a problem with the CN+ itself( I hope not) best bet is just to get your dealer to have a look. What software are you running?
Ben R is offline
Old 11-06-2005   #6
Trader Rating: (0)
Ok, if you had an ABS problem this would effect the SATNAV as it uses a speed signal from the ABS to establish how fast the vehicle is travelling and also for the countdowns to junctions, (by the way these are much more accurate if you have the measurements set to metres).Unfortunately if the speed signal is faulty it reverts to a slightly less precise operation but still works.
Are you sure that you havent just reset the map display? You can have the map displayed so it always faces north so the arrow turns in relation to the direction you face OR you can have it so the whole map rotates and the arrow stays static pointing upwards. I would check this if I were you.
NumanR is offline
Old 12-06-2005   #7
Paparrazi
Trader Rating: (0)
Neil Barker has donated! United Kingdom
Teh STA NVA deos take signlas fr0m teh wh33ls.
Neil Barker
Techno Grey 3dr Abarth Selespeed now replaced by a 2008 Toyota Avensis TR 2.2TD
Sadly, I am unable to recommend Sunwin Fiat Derby due to my experiences there
Neil Barker is offline
Old 12-06-2005   #8
Trader Rating: (0)
wot do you mean mate?
Old 12-06-2005   #9
Paparrazi
Trader Rating: (0)
It was a parody on the truly awful English/text speak being used !
"The SAT NAV" does take signals from the wheels"
Meaning that the Nav+ system does take an input from the rotation of the wheels to aid in accurate positioning.
Neil Barker
Old 12-06-2005   #10
Trader Rating: (0)
It's got to be something on the off-side as the map updates perfectly when the latitudes change. Since the map just spins anti-clockwise around the current position I'm assuming it's the off-side sensor in the wheel and the car simply thinks I'm constantly turning in a circle.
I've only just noticed the problem and since it was in for its service the week before last, and it's going in again tomorrow to have the brakes done, I think they (hopefully) forgot to plug something back in.
Fingers crossed it's nothing major and something they've forgotten to do as my service is already up to £850!!
Barbarian
Old 12-06-2005   #11
braden's Avatar
Trader Rating: (0)
mine did this slowly cleared itself
braden is offline
Old 13-06-2005   #12
Trader Rating: (0)
If it rotates only in one direction it sounds like a unit fault which may be possible to fix using software update. The wheel speed sensors are used via the abs only for speed signal not direction, for that it uses the onboard compass.
NumanR is offline
Old 14-06-2005   #13
Trader Rating: (0)
Phew! All sorted.
Could have been the software - now updated to 8.3 (not latest, but better than 7.4 I had before) plus new discs and pads. Even the rattle from the front suspension I've complained about for the past three years (with numerous attempts to fix it) has stopped.
A result - I'm well chuffed!!
Barbarian
Old 14-06-2005   #14
5vp3r m0d
Stu DemonD's Avatar
Trader Rating: (1)
Stu DemonD has donated! United Kingdom
8.3? Why not do the jump to 9.8 as well, lol.
Anyway, at least it is all sorted now
Electroclash Panda 100HP
Red brake calipers - done / Red highlights on engine cover - done
Red GSR kit - done / Red badges - done / Cobra springs - done
Stu DemonD is offline
(G) Standard Sat Nav? benparkes Punto 5 07-02-2005 09:07
Sat Nav Aux input help!!! fieldy I.C.E 0 05-02-2005 22:37
(T) Sat Nav failure - no reception boywonder Stilo 2 15-06-2004 22:47
(G) sat nav, nav tec,,, is it voice activated leon_in_uk Stilo 7 11-06-2004 22:54
(T) SOS button + no manual for connect nav coolchef Stilo 5 04-09-2003 04:46
