| im sure this has been covered before but can i wire an amp to my connect + and do i need any special connectors and stuff or does it just plug in like a normal stereo??
__________________ 06 grande punto sporting 130 in car crash orange | |||
| Banned | Re: amp for connect+ Hello mate I'm having the same problem at the moment, but hopefully will be sorted tomorrow. I was told by someone on here originally to go to Halfords & get a PC3-11 connector from autoleads, don't bother it doesn't fit I'm hopefully getting the Fiat wiring diagrams tomorrow so I'll post back when I get it sorted.
| | #3 | ||
| Re: amp for connect+ hey mate i have had no joy whatsoever around my area getting someone to find anything out about fitting an amp even the fiat technicians had no idea how to do it so im going to try the old fashioned way of speaker to rca converter using the bandpass on the amp to try and keep mainly low level going to the sub im going to have a go at it tomorrow ill post back when ive done it we shall see!!!!
| | #4 | ||
| Banned | Re: amp for connect+ Good news mate. I have mine working now! What I did in the end is I spliced the amp remote into the green remote wire from the autochanger, then wired the amp rca's into the rear speaker cables. Also I recommend if you go this route to wire the rca's(amp end) to the high level bandpass as you might damage the speaker going the other way round.
| The following user says "Thank You!" to Ben R for this useful post: | ||
mr_k1 (03-05-2008) | ||
| | #5 | ||
| Re: amp for connect+ I Wish I found this sooner!!! grr. My amp Is i think a little out of date maybe. i've Had it 2 years its a Voodoo PX 1002 1000w. I the High level basspass is a prong and i cant seem to find it anywhere. Any Help on where would be much appreciated.
| | #6 | ||
| Re: amp for connect+ Ok, most amps have 2 types of input. 1 type is two rca connectors, one red and one white circular plugs. these are the low level inputs. The other type is a block of 4 screw terminals, which look the same as your speaker connection terminals. These are called Hi-level inputs. Not all amps have hi-level inputs. If yours havent got them, you need to go and buy a hi-level to lo-level convertor. Costs around £10 from halfords, or you can buy one like this from Ebay http://cgi.ebay.co.uk/Boss-Audio-Hig...QQcmdZViewItem
| Guide: How to wire an Amp | Luke | I.C.E | 3 | 11-07-2005 18:33 |
| Amp and sub help | sparky762 | I.C.E | 6 | 26-01-2005 12:36 |
| Need A New Amp | bravaboy | I.C.E | 5 | 30-01-2004 16:51 |
| | DotSPF | Uno | 6 | 11-11-2003 23:18 |
