The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 07-06-2005   #1
Yfstilo's Avatar
Trader Rating: (0)
Help!!!! misfire problem!!
hello a couple of months ago i picked up a misfire so took the car to fiat they found a coil pack had gone!!! they replaced it under warranty,
sunday was driving down the road and it happened again so i found out which coil was misfiring and ordered another but!!!! it has not made a change dose anyone have any ideas!!!!!!!!?????
2002 broom yellow stilo 1.6 16v dynamic, 17" rims kenwood h/u and jl audio speakers all round custom boot install. profesional window tints with 1 off rear screen pattern!!! debaged custom grille,
Yfstilo - aka - Nick!!!
http://img224.imageshack.us/img224/9...ckstilo4ki.jpg
Yfstilo is offline
Old 07-06-2005   #2
Banned
Trader Rating: (0)
Ben R has donated! Christmas Island
Re: Help!!!! misfire problem!!
Could be HT lead gone?
Ben R is offline
Old 07-06-2005   #3
Trader Rating: (0)
Don't drive it. (full stop). Backfiring isn't good for the CAT, and you don't want fuel detonating in the CAT and then costing your £££ on a new CAT. Get it towed to the garage and tell them you don't want it back until its fixed, and you also want the CAT verified as being ok!
53 plate, Stilo 3-door, Sassy grey, 17" Claw Alloys, Falken Ziex Z512 tyres, 1.2 Active -- 45mpg!
StiloBoy is offline
Old 07-06-2005   #4
Whaddya mean too old?
Deckchair5's Avatar
Trader Rating: (0)
Deckchair5 has donated! United Kingdom
It's got to be said, did you change the right one? How did you check which one was causing the grief? Is it a spark plug? Did you take the plugs out? Are all the connectors on properly?
Cats can take a lot more grief than the scribes would have us believe. An occasional misfire won't do any harm and even an engine not starting and flooding it with fuel has proven to not do any lasting damage. Cats more often die of old age, physical damage or breaking up. Now sticking diesel in your car is pushing your luck a bit but otherwise they're pretty robust
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline
Old 07-06-2005   #5
Banned
Trader Rating: (0)
I agree with Deckchair5 I would check plugs & leads before anything else & the airfilter & air flow meter.
Ben R is offline
Old 08-06-2005   #6
tagoso's Avatar
Trader Rating: (0)
New Zealand
Mine was coughing and spluttering - they replaced all the spark plugs and that fixed the problem for about 2 weeks. When it happened again, they diagnosed a faulty coil and replaced it.
Sorry - probably not too much help in solving your particular problem - but some background info anyway...
2002 Fiat Stilo Abarth 2.4L Selespeed Yellow 42K
tagoso is offline
Old 08-06-2005   #7
Trader Rating: (0)
spike192 has donated! United Kingdom
I used to have this problem with my Megane (not anymore mind you) They changed the coils, leads etc. and it was still doing it. Eventually, they had it for 6 days and had to replace the entire engine wiring loom! Joke.
Not much help, but it proves that it can be caused by a lot of different things.
spike192 is offline
Old 09-06-2005   #8
Trader Rating: (0)
The 1.6 has four coils fitted directly over the plugs The way to diagnose if its a cylinder or plug fault or a coil fault is to move the coils position, If the misfire moves the fault is the coil, if the misfire doesnt its a cylinder specific problem (probably plug). Either way if you have a misfire I would change the plugs as they get coated when misfiring and dont always recover. As stated earlier catalytic converters on Fiats are very tough and I can honestly say I have changed 4 in 8 years due to failure. Also sometimes if you get a coil go down it spikes the efi ecu, and produces an injector error. It could be the ecu has stopped firing that injector to protect the engine, so a trip to the dealer may be required.
Good luck.
NumanR is offline
(T) Windscreen wiper motor problem Thomas P Uno 10 23-08-2006 20:04
(T) Punto Sporting problem Mary Cochrane Punto 10 12-02-2005 01:21
(T) Punto (second version) Dualdrive problem andre79ge Punto 2 10-02-2005 23:43
Mid-throttle injection problem in Lancia Y10 FatNote Panda (Classic) 26 30-07-2004 18:58
Brava lockup problem Kensho Lets Talk FIAT 1 11-11-2003 03:05
